asanka_rg
Everything posted by asanka_rg
  1. fan is working fine. And I have flushed the radiator with some chemical and refilled the coolant?. No idea about the pump anyway
  2. hello everyone, I recently bought a 2003 Suzuki swift jeep model. I have noticed a heat indicator going above the middle mark (3/4) but it went down in few minutes. Moreover I drived in Katunayaka highway and heat indicator was on and below middle mark or the heat gauge. I doubt that radiator got some blocks and i flushed and refill the coolant. But the same issue is still there. Is this a bad thermostat or give me some advice on this will be highly appreciated.
  3. Passo has feminine look so i already removed that from my list. i don't think that swift indian is a good choice for me either. what about some peugeots??
  4. yes of course I am facing the same shitty experience now. for that price tag the Jeep model is seriously overpriced now. I have seen around 10 cars now and most of them are brokers and even the car is not in good condition. As you guys mentioned lot of cars have only power shutters. No ABS, PM, etc. Could you guys give me any better alternatives for this car with good spare availability for a maximum budget of 2.3mil ?
  5. Hi guys, I am planning to buy a used car for around 2.4mil these days. could you guys please comment on below cars on given aspects. Suzuki Swift 2004/2003 vs Honda fit 2004 fuel economy maintenance (part availability) comfortability safety features thanks you-- awaiting comments
  6. Thank you all very much and i'm bit relieved with your valuable comments.
  7. Hi all, I am confused to make a decision. first of all i have to mention i have put a fixed deposit of some money on my hand (only for 3 months, it will end in 4th January 2017). I was planning to buy a car in 2017 jan. With the price hike of small cars in the budget 2017, I am in a trouble to make a decision that i should cancel the FD and buy a car right now or wait until January 2017. cars i am looking for is swift 2003/4, fb15, mazda BJ5p, 110. So will the price of those cars affect ? what should I do? to save some money!! please help
  8. Thanks for the comment. Won't happen again.
  9. TRY PARTSFAN.COM OR MEGAZIP.NET YOU CAN SEARCH PARTS BY CHASSIS NO OFTHE VEHICLE
  10. As you this is gonna be your first car, I strongly suggest to buy a common car with good maintainability. you have few cars for that budget like starlet, vitz 2000/2001 , march k12, alto japan, etc.
  11. Thank you very much to share this experience with us. I am gonna follow this asap
  12. Yeah I got some good encouraging stuff here. thanks for your valuable comments. I think I have changed my mind.
  13. Yeah for this budget Cruze is good car to own. I know. But some cons say some spares are hard to find and expensive. that's why I am going for a change.
  14. WHAT ABOUT THE FUEL ECONOMY IN LANCER CS2?
  15. I have found some spares are hard to find and costly.
  16. Actually I am not having a issue with the cruze. I am only having a doubt on spares fuel economy.
  17. Now i'm owing a cruze. Recently I'm planning to change the car with following requirements . I just prefer Japanese vehicle but comment on others brands are also welcome. Good Ground clearance Fuel Economy (14-15km/L) Spare Parts availability Comfort Drive Personally I found following cars Toyota :Starlet, AE110, Vitz old one, ??? Nissan: FB15, Suzuki: kei, alto 2003/4, Mitshubishi: Lancer CS2 Please give your comments on above vehicles as well as your suggested cars will be highly appreciated
  18. I have replaced a sensor and fix the issue. tahnk you for your help. I really fedup on A*W and other mechanics who wrongly judge the situation and screw me up!!
  19. Thanks guys and I wondered why the agents for Suzuki also misjudge the situation. I wasted time and money due to that. I will do the sensor replacing asap. By the way lots of used sensors found with cable cut off. Is it safe to use one of them??
  20. Yeah could you tell me while scanning, can ABS light is on. Bcz I sacnned two times. Once it was off. Once it is on. Which is right.
  21. Should be a plug coil. I got this once. I got the car scanned and found the fault.
  22. Hey guys, I am starting new thread as the story getting large. I got the Chevrolet Cruze 2004 limited. And I got abs warning lamp on few times and went off. Then I cleaned sensors and got this creepy brazzze sound atevery stop of the car. I check with a mechanic at avissawella said the problem is abs unit. Then I again scan the car with A M W and said no sensor fault. They also Sai the abs unit is the fault. While they scannng no abs light is on and that creepy sound came. Then I go found a abs unit and fix and the issue is terrible. This done with a different mechanic at nugegoda. Sound came bit aggressively. Need to mention that the abs unit is not the exactly same one with the original. There are few pins in the connector is different. It was a swift module. But after fixing no warning lamp was on. Then the mechanic re scan the car at his own place with the already fixed module not the original. And I saw the abs warning lamp is on while rescaning and no creepy sound (hopefully as abs is off. There he showed a one wheel sensor read a 0 kmph speed when we running lower 11kmph speed. At higher speeds sensor read the correct speed.then he asked to replace that sensor it was front left. That day was really hard for me and I'm so confused. What is to do. After all these I returned the new module and fixed the original. And check the left sensor getting out and fixed again. Now the Abs light is on. Need to try replacing the sensor. Could you all give me some explanation what's happening.
  23. Hi all, Sorry to mention that i am still having the issue. couldn't get it fixed. one of my friend at A*W says this is a common issue in SWIFT and CRUZE and also mention that the swift rack is not compatible with cruze. this is a damn headache now. !!
  24. I really thank for your advice and I will do it as you say. I should say this sound even comes without pressing the brake at low speeds. but the ABS light remains off. According to your experiment i should get a light on ABS driving 3 mins very slowly?? if the issue is with the sensors right?
