SachiNayar
Everything posted by SachiNayar
  1. Reason: Sensors fail temporarily because of ice or water I had the same issue. Turn the engine off, handbrake on and select reverse, get down and listen to each sensor, and you should hear a clicking. Make sure every sensor is clicking. If not, then check connection at the back of the sensor (you have to remove the bumpers!) and also check the loom for any damage.
  2. Below are the certain pros and cons of upsizing and thus help you further in deciding if you should be upsizing or not. Pros - Traction: Bigger tyres will generate more grip. It is simply because a larger section of the tyre is in contact with the tarmac. - Braking: Thanks to a larger contact patch, the tyres grip the tarmac better and in turn reduces the braking distances by a fair margin. Cons - Fuel efficiency: A bigger set of tyres will reduce the efficiency of the car. - Ride quality: The ride quality of your car will take a direct hit once you upsize the tyres of your car.
  3. Great information Davy on interior cleaning ! Going to try this at the time of car interior cleaning.
  4. Yeah, I'll try it! I also used brasso and it worked like magic, now my car's headlights are crystal clear.
  5. I will suggest you below mentioned car navigation system. Portable Navigation Systems Pros : - It is less expensive than a factory system. Prices can range from $50 for a basic unit to more than $200. - Portable navigation system providers offer models with lifetime updates. These cost a bit more initially, but they are less expensive to update in the long run. Cons : - These are easy-to-remove devices can attract thieves, so you'll have to make sure to hide yours or take it with you when you park the car. On the other hand, this portability can be useful for people who drive multiple vehicles. - If your portable navigation unit malfunctions, you'll only be covered for about a year or however long the limited factory warranty lasts.
  6. If your car is new then you should service, often as is outlined in your owner's manual. For older cars, you need to have at least an oil and filter change every six months or 500 miles.
  7. Over-inflating tyres is dangerous and can lead to excessive tread wear. Look for the nearest car service center in your area for more information so you will solve your query easily.
