Everything posted by varotone
Project A72V
UPDATES Finally managed to restore the switch assembly on the steering wheel. Rear wire harness was restored. Had to replace the wires to the door switches. Switches themselves were working. Took longer than expected to undo all the thoughtless butchering by the previous owner. Next up is the front wiring. HELP NEEDED Can anybody identify what this is? It has two tubes and two wires connected.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
UPDATES Took apart the steering wheel and tried to fix the butchered wiring. Managed to get the switches working except for the PASS switch. So, I'm thinking about buying the whole switch stalk assembly. Shopping list: 1. Hazard light relay 2. Connector for hazard light relay 3. Headlight relay 4. Connector for headlight relay 5. Switch stalk assembly Appreciate if you could tell me where to find these and the approximate cost. There's a light named DOOR in the dash. But the slot for the bulb is sealed from outside. There are switches in the door jambs. But the wires are missing. EDIT: Looked around for the switch assembly. Came across 2 reconditioned ones. None of them had all the switches functional. So don't buy it. Next would be to look in panchi or delkanda.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
The manual describes some features like 'hold speed function' a rudimentary cruise control, seat belt warning chime, high speed warning chime, EGR, shock absorbing buffer attachments, and door open light. Are these features available in this particular one? YOM 1983 JDM version. Lookslike the Japanese automotive technology had achieved everything in that era (looks like today's cars just throwed in a bunch of electronics to just complicate an already existing, simple setup)
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
A very big thank you to @Davy for buying a Haynes manual for me. When I mentioned that I want to buy a workshop manual, he was very helpful in dropping me a PM about this manual being up for sale and offered to buy it for me. He even said that I can pay after I had received it! Davy is by far the most helpful person that I have met online. Sir, I don't know how to thank you enough for this favor. It's an unused Haynes manual. If anyone needs a photo copy, drop me a PM.
- 189 replies
- 4
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
UPDATES Our garages are notorious for cutting the wiring just because they are too lazy to properly remove them. Mine has also suffered the same damage. Instead of buying a reconditioned harness, I decided to restore it myself. I spliced one connection today. Here's the steps briefly. 1. Clean the area. You'll see the color coded wires, any damages well, and helps the solder and insulation tapes to stick well. 2. Figure out which wires go where. Note it down in a paper or label the wires with masking tape 3. Cut the frayed ends and strip the insulation. 4. Tin the wire ends. (Tinning means to coat the wire with soldering lead) 5. Slip in a piece of heat shrink tubing 6. Solder the ends. 7. Cover the splice with the heat shrink tubing. Heat it up. 8. Wra the wires with insulation tape. Remember this insulation tape is not actually meant to insulate the wires. The heat shrink sleeve should do the insulation. Wrap the insulation tape to keep the wires organized and tidy. 9. Check the resistance across the splice and for short circuits with nearby wires. Here's how the damage before repair. This is the result
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Some electronics shops have new terminals. But they don't fit mine. They look flimsy too. If I'm buying them, I'll have to get both male and female ones. Thanks for the info. I'll look at Japanese reconditioned parts shops. I'm not at all worried about the milage. It would be nice to know how many times the car could have traveled back and forth to the moon!?
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
17,346.3 to be precise. It has only 5 digits. I wonder how many times it could have hit 99,999.9 (Or how many times it was reversed) ?
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
UPDATES 1. Removed the fender mirrors. Both need some buffing. The passenger side one needs some restoration because the spring mechanism has failed and someone had drilled a hole and fixed the mirror with a bolt. Here's a pic. I want to fill out the hole and restore the spring mechanism. Metal looks like pewter. I'm searching for some blacksmith/jeweler kind of guy to fix it. If it fails I'll hut for new fender mirrors. 2. Removed the dashboard. The wiring is a mess. There were aftermarket lights in the front shell. The wiring was hacked to install it. That's why I couldn't remove it the other day. Now I'll have to check the meters and lights of the dashboard. Waiting for the Haynes manual to get the specs. 3. Replaced the fuse. Although they were shorted out, none of them except the 5th blew up. Maybe it needs a higher amperage. Didn't have enough time to hook up the multimeter and see how much current it draws. 4. Dissembled the AC/heating/ventilation gadgets because only the AC and blower were working. Will take a look them stepwise. BTW, where can I find connector terminals?
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Had a look at the ignition switch. Here's the connector. Exactly as @Davy described. But the key barrel looks alright. Here's a pic of the fuse board just to show how messed up the electrical system is.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
UPDATES Took the car out for a spin today and noticed 2 issues. 1. The passenger side carpet was wet. Yes, it was a rainy day but I'm sure there are no rusted out holes in the floor pans or the gutter going down for the windshield. The ac condensation drain line was missing and I realized it only today! No big deal. Just used a piece of PVC tubing. Will have to wait until next weekend to see how it holds up. 2. The key was heated after the ride. Only cranked the engine once and it started without trouble. What could be drawing a current from the ignition switch other than the starter motor?
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Thanks for the information gentlemen, My first consideration is a third party cover for Rs. 200,000 for which the premium will be about Rs. 2,000. I could also try undervalue the car if I'm going 3rd party. Just wanted to check if a comprehensive cover would be worth it given how frequent accidents are in these congested roads. Pros and cons of comprehensive cover, specifically with regards to vintage cars. @Twin Turbo Sir, I meant to say young timer cars. (Young timer cars are the old cars which are not yet considered vintage. My project car would be considered a young timer car. Old timers are vintage ones. Ford model T is vintage) I'd happily call myself young. But not immature, reckless, kind of young. I'm in my mid twenties Given how the comprehensive policies don't adequately cover older cars that well, I wanted to make sure that it's the right thing to do.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
- ## Post Whoring - Part 3 ##
Project A72V
ADVICE NEEDED Insurance for the car expires in December. So, I'm searching for a good policy now itself. I have not yet decided on to get comprehensive or third party cover. All I need is the best bang for the buck. First, I went to CE¥L!NC0. They refused to insure saying it is too old. Then I went to $R! L@NK@ insurance. A guy had a look at the vehicle and said it can be insured for Rs. 300,000. A full option would be around Rs 10,000 and third party around 3,000. They did not have any special policies for vintage cars. The comprehensive coverage will cover the full value if parts are replaced with reconditioned parts or 30% if brand new parts are used. Plastics and rubber are not covered. Since I'm planning to restore this (over 1-3 years), will a comprehensive insurance for this amount be worth the money or am I better off with a third party cover? I would like to hear your comments on selecting a suitable cover. Are there any specific insurance policies for vintage / youngtimer cars in Sri Lanka?
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Thanks for the help gentlemen, I still failed to remove the dashboard. Once all the screws are removed, I tilted down the steering column and gently tugged at the dashboard. It came loose. I unplugged the connectors in the wiring harness in order to completely remove the dashboard. Looks like some of the wires run all the way to the engine bay without connectors. So I could not remove it. The driver side AC went was not blowing when I bought the car. While removing the dashboard, I found that a part of ducting had removed and fallen in to a mess of wires. So I want to to fix it as well. I'll give it a try after I get the Haynes manual. The wiring system is a mess. All the fuses in the board are shorted out with a wire. I'll have to start from fixing the wiring. There's only an AM tuner in the stock radio. I'm planning on stripping the "innards" of the AM tuner and putting in something like an Arduino with Bluetooth, FM, GPS, voice recognition function in to the stock AM tuner "shell" and remap the buttons and volume and tuner knobs to function with the Arduino.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
UPDATES 1. Brake liners replaced. I might as well say brake liners inserted give how worn out they were. Had to replace one pair of shoes as well. Surprising the hubs wer good. 2. Passenger side front wheel didn't roll smoothly it was very tight to turn. Problem was not correted with greasing the bearing. So I had to replace it with a reconditioned one. 3. Topped up brake fluid. Again, these are not exactly part of restoration. Removed the seats and carpets to detail the interior. Wan to remove the dashboard as well. I'm stuck at removing the dashboard. Appreciate if anyone can describe how to remove the dashboard. There's quite a lot of rust in the floorboard. So I will repair this before putting back the carpets and seats.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Yes. With a 0.9 big head. The rubber washers were missing in the old one. Thank you.
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Nope. I did it myself. BTW, I don't call it a service. Just a flush and refill. There was nothing wrong with the radiator, at least nothing that I noticed. You can't fix it if it ain't broken. So, there was no point of taking to a shop. I just wanted to get rid of the water and use coolant.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
UPDATES: (I would not call these a part of a restoration. It is basic automotive maintenance tasks to do regularly) 1. Radiator flush and refill done. I used an ABRO 10 minute radiator flush and one gallon of ABRO green color diluted radiator coolant. I would like to share the following tips to make the process easy. The petcock is copper and unscrewed easily by hand. The only problem when draining the fluid is once the nut is fully removed, water shoots right ahead to the compressor. The stream of water wets the pully of the compressor and the belt. Take precautions not to wet the compressor. One solution would be to fix a plastic tubing to the drain plug (like you bleed brakes). I could not find a piece of tubing that fits. So, I kept a rag dangling from the radiator housing just in front of the drain bolt so that the stream of water hits the rag and falls down instead of hitting the compressor. Be careful not to get the rag tangled up in the rotating pullies and belts. If you ignore the stream of water hitting the rotating belts, you will end up spewing a warm mix of nasty chemicals all over the place. Always wear goggles and gloves when handling these chemicals. While running the engine and doing the flush, it is easier to close the radiator and run a slow stream of water into the radiator fluid reservoir instead of running water in through the open cap. Pouring water into the reservoir gives some space to work with and avoids the danger of touching hot radiator and splashing hot water. Make sure the radiator pressure cap is functional before attempting this. I had to use a little more than a gallon to fill the radiator and the reservoir. I also had some ABRO radiator leak repair powder handy just in case the flush had done its job too well. I didn't have to use it though. A leak may be difficult to detect at a glance. Radiator coolants usually contain a luminous pigment which fluorescence under UV light. Shining a UV light at the radiator in the dark will highlight any leaks as bright luminous spots. Mine had none. 2. Replaced the wiper blades. Used a one with a small plastic cover on top to protect from the elements. I didn't make much fuss about the original looks since this is consumables and I will have to replace them again. Because the alignment of the wiper blades was off, I had to remove the arms and re-align them so that the blades don't go out of the windshield. Hopefully, during the next weekend, I will attempt to fix the scratch marks on the windshield.
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
How were the door panels attached by default? Mine was fixed with numerous screw nails. Looks very untidy. I had to remove the panels from the tailgate to fix the lock. I plan on replacing the panels nicely as it was supposed to be fixed.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
I'll have to buy new battery leads along with the plastic caps that cover the terminal. And the battery restraining piece as well. I see only one metal pillar on the side of the battery. There should be two with a screw on top on either side of the battery. May be I'll leave it to the end to do with tinkering. I'll.have to resort to some makabas job for now. @Davy Thanks for the offer to help. I have PMed you. Two pairs of mirrors was the previous owners idea. I'm planning to remove the fenders for now. It needs a bit of repair. Will re attach them after tinkering and painting. Radiator cap, flush, coolant all in my shopping list. And wipers. Had to postpone the radiator flush due to bad weather.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Thanks for noticing that. Can you please share a photo of the battery fitted correctly? I will look at it and fix.
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Can you say what what I own from the pictures? LA LB or LC? I found a Haynes manual on E b a y. Considering buying it as option B.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
UPDATES: Passed the emissions test Idel HC=438 CO=1.17 @ 2500RPM HC=230 CO=0.45 Bought a repair kit and did a rebuild. Originally main jet was size 120 and changed to 80. The idel could be better tuned. There is a small problem. When the A/C is switched on the engine can't idle. It stalls. The mechanic said to replace the diaphragm first and then tune the idel. Here are the pics. (NOTE: Gentlemen, you may see this listed in classified sites. Please do not comment on the price that I may have paid for it. I know that you will be doing it in good faith to prevent me from being ripped off by a shady dealer. But, someone saying that I could have bought it for less just brakes my heart. After all, there's nothing that can be done about the purchase now.)
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Thanks a lot for the input and appreciation. #1. No. there's no blue smoke. #2. Spark plugs are still usable. All were carbon fouled to begin with. I cleaned them before the second attempt. Air filter looks good. #3. I didn't check the PCV components. But if there's an obstruction, that would increase HC in the exhaust gas and not CO? Please correct me if I'm wrong. #4. Thank you. I will check it tomorrow.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
An engine overhaul is my last option. I will start looking at the smaller, easily correctable faults first. When fixing a car (or anything else for that matter) one should start from the parts easiest to test/fix and work up to more difficult to test/fix parts. Correct me if I'm wrong.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
