Lannister
Lannister's Achievements
insight Honda Insight, Mazda Axela or Any other
Lannister replied to Lannister's question in Car Buying Information
Thanking again a lot @Dee Jay.. Then what about Axela Series? Are there any issues? Common ones? And yes.. I’m running quite far distances .. I need to think about petrol too.. -
Lannister posted a question in Car Buying Information
Hello guys, I’m looking forward to upgrade from my Honda Civic EK3, My budget is 23lks-30lks. My mind fluctuate among Honda Insight 2007-2010 , Mazda Axela 2007-2009 or any other thrilling, fun to ride budget car ( u know what I’m thinking, like EK3) How about the battery and dual clutch issue of Insight and durability? How about Heating issue and Fuel Consumption of Mazda Axela? Or any other Suggestions? Thanking u guys a lot and really appreciate if u could give me an better suggestion on this.. -
One of my friend owns a Honda Ek3 ViRS Automatic one, & it got a reverse failure few months ago (couldn’t even shift the gear to reverse, even when put it to reverse, nothing happened except RPM rise), & then he replaced the gear box & the problem was solved. But now problem occured again & this time the gear shifts & can reverse slowly only on a flat surface.. can’t reverse to even a little hill. What may happen here, & what would be the cause for this.. Thanx
- honda ek3
- reverse not work
- (and 6 more)
@sira Thanx for the reply, Yeah probably it’ll be coming from the throttle body... Do u have any recommendation mechanic to get solved with? & to recognize exactly where the problem is... thanx again.
- 11 replies
- ek3
- vibration issue
- (and 8 more)
@tilvin yes When the gear shifts to 2nd .. The rpm is around 1000-1500...
- 11 replies
- ek3
- vibration issue
- (and 8 more)
@tilvin Thanx for the reply, When the car is in ‘Drive’ mode, RPM stays like 1100-1400 when on 1st-2nd gear. When ‘Sport’ mode 1500-1800 I usually on ‘Drive’ mode...
- 11 replies
- ek3
- vibration issue
- (and 8 more)
@Rumesh88 Thanx for the reply, No I haven’t checked the pcv valve.. & To check it, should I need to remove oil filter? (Coz I found a vdo on youtube doing so)
- 11 replies
- ek3
- vibration issue
- (and 8 more)
@iRage Thanx for the reply. Even if the RPM goes down like 300, it doesn’t stall .. It hangs there & vibrates & comes up then comes down.. so and so on.. Yes I have checked the water pressure to throttle body & replaced a horse too.. but I haven’t checked the fuel tank as u mentioned there.. Would u think, that this would cause from that problem?? Oil filter, Air filter are also new & genuine too.. & Does soluna had the same problem that I have in here? Thanx again?
- 11 replies
- ek3
- vibration issue
- (and 8 more)
Hey folks, I posted on Autolanka about this problem few months ago.. But nothing worked out. My Ride is Honda Civic EK3 1998 Auto. My Problem is, My Car has a vibration issue when it comes to idle, the RPM gets down over 500-300 sometimes.. & it doesn’t comes up 800-1000 . I did throttle cleaning twice including EAC Valve(IAC). When it cleaned, problem is kinda fine, but when rides over & over (specially long distances) it gets worse. Did a ECU reset, same result.. One mechanic said, one of my Mount is kind of hard, but there isn’t much to work with vibration issue. One Michanic said that vibration can not be fixed, since it is kind of a manufacturing failure. Replaced Air filter too.. Checked everything & all are fine. Went to Honda Waruna - Kesbawa, Honda Darshana - Pannipitiya, Honda Tharindu - Malwana, Honda Rohan - Kesbawa. since those are popular name on the thread. Now I think of going to Stafford. But I cannot spend much at the moment too.. I really badly need to fix this issue, coz my Car is everything fine except this. So plz reply here ur experienced suggestions... Thanx Again..
- 11 replies
- ek3
- vibration issue
- (and 8 more)
Hey, @PerfMad Thanx for being alive on the post. Yet it stays like so, Rumesh said to clean the PCV valve & yet I couldn't do it. Checked again with a Mechanic & calibrated ECU. Now it relieved a little & I'm sure that won't be a permanent solution. & the mechanic said to check the engine & gear box mount. Now I'm on to that.
- 14 replies
- vibration
- idlevibration
- (and 6 more)
Thank you very much @PerfMad
- 14 replies
- vibration
- idlevibration
- (and 6 more)
Hey, @PerfMad I did the tuneup with a Stafford guy, what he did was cleaning the throttle body & Changed Gear Oil, Engine Oil & Oil Filter as well. Checked & cleaned Spark plugs too. At that time, the vibration issue was solved. RPM stayed 800-900. But after few days, It affects once again. Today I felt it more. & RPM is dropping. What should I do. Where can I solve this problem?
- 14 replies
- vibration
- idlevibration
- (and 6 more)
Yes for sure!
- 14 replies
- vibration
- idlevibration
- (and 6 more)
Thank you very much for your co-operation dear!
- 14 replies
- vibration
- idlevibration
- (and 6 more)
No.. there are no issues with changing between gears.. but the previous owner said to change the gear oil since it already reached 25,000kms. Additionally I kindly I need to know when to change gear oil as well..
- 14 replies
- vibration
- idlevibration
- (and 6 more)
