gayanath
Everything posted by gayanath
  1. @ramishkad Since you have used CE110 for 14 years and more than 200,000 km you will be one of a best person to explain the maintenance aspect for long run of same car. Could you little explain what maintenance and repairs done at which millage / duration briefly if you have time? It will be a great help.
  2. 1. English numbers started in 1999 or 2000 as I remember. So 65 is possible. 2. If it owns by your relative and since he is the first owner, then you could know about the full history of the vehicle rather than any other. So, if past records are clear, this could be the best deal for you.....
  3. Hope you are referring N16 or above
  4. 1. Did you replaced the battery or previous owner replaced it recently? (If so he could be given you the warranty card and please check the date) 2. What is the millage of the car (anyway do not trust our sellers)?
  5. Wait.. wait.... Is there any other running issues than this? If no, forget this for sometime and enjoy your car. Its too early to decide anything. Investigate the situation with various conditions. What is your exact idle RPM? Most probably this could be a normal condition.
  6. 1000 cc or 1300 cc? How much?
  7. According to the "calibration procedure with driving the vehicle", ECU may learn it automatically when the car decelarating from 60km/h for 5 seconds. However it may depend on your driving pattern. Same type procedure (not same but same system) like "calibration procedure during halts" is using for Toyota CVT boxes to confirm whether the required temperature has reached to adjust CVT fluid level. Therefore this may be true. Please try it.
  8. Did you removed your battery terminal or replaced battery without giving outside power? If so, when? At which millage? How about the millage now? If the case is above, 1. If ECU could learn, it may learn and adjust with the time or 2. If ECU couldn't learn, then it should be made with facilities to manually program with relevant parameters. However may need relevant instruments.
  9. Is this the normal behavior of your car since you purchased, or do you feel this is a resent change? Is this vibration a normal behavior of your car since you purchased, or do you feel this is a resent change? This three times are withing one or two days or withing long duration? YOM? Millage when you purchased? Did you replaced your battery? If battery replaced, when it replaced? Why you did a tuneup at 48K? Due to any issue?
  10. How you ensured the vibration is from CVT?
  11. You have nicely summarized every thing above. Great. Adding, - The risk of unnecessarily intervene of unqualified mechanics (in most of our service stations) to change transmission oils in frequent intervals also should be considered. If I explain it some other words, doing an operation to a patient is always a risk. Therefore, should do an operation, only his/her life is under threat by not doing it. (I know several engine related issues after unnecessary engine tuneups (cleanings) promoted by service stations but not recommended by manufactures).
  12. ATF change is not the main reason for Gear Box failure. Please go through below topic. http://forum.autolanka.com/topic/17782-toyota-allion-nzt260-cvt-gearbox-issue/?hl=allion Post #10 says the owner has changed CVT fluid always less than 40K. but it has already failed. Quote: Yes I am the first owner here in SL although the car had close to 30k mileage when I got it in 2010. I've been changing the fluid every 35-40k. Never ran it without changing it past 40. unquote. Any mechanical part could be failed due to several reasons in any moment of its service life. But our makabases are thinking GB's are failing due to not changing ATF in every 40K millage.
  13. Summerizing above, For manual tansaxle fluid Normal condition: Inspect every 60,000 km or 48 months Severe condition: Replace every 120,000 km For ATF Normal condition: No check, No service Severe condition: Replace every 100,000 km So no harm if you replace ATF at not less than 100,000 km (or lets say 60 months) in any condition.
  14. gayanath replied to Watchman's topic in General
    CITY :15-16kmpl - Bit hard to believe.
  15. Who knows about the vehicle better? 1. A*to Mi*** ? 2. KIA Service center (in SL)? 3. Manufacture (who prepare the service manual)? If 1 or 2 are manufacture of KIA, then you should follow them. No mate, those people are bullshit. They only bother about how much could they earn from you. Even with Colombo traffic, we (Sri Lanka) are well below the extreme driving conditions. Following the owner/service manual is the best practice. 40k for ATF is now obsolete for most of the vehicles. However normally the manual says xxxxxx km or xx months whichever comes first. So please refer not only the millage but also the duration mentioned in the manual. You have to replace fluids in correct duration irrespective of lower millage.
  16. Considering above highlighted items, why don't you go for B/N or 1-2 years used auto car like Peraduo Viva or Axia?
  17. Though you have mentioned ignition coil in your general list, you have suggested "First change the Atf, then do a tuneup. If it still persists it's probably your engine mounts. " which means you too went on wrong path.
  18. Now lets see, all above judgement are wrong. Why? You didn't investigated the matter. Dear car lovers, please investigate things before do and as well as comment. Asanka_rg has figured out it since he had same experience. Otherwise, the only valuable information cheths727 given was, "it happened yesterday" which means the issue started suddenly. So please ask more details before comment. Otherwise, you guys will also be just like our mechanics who remove engines for just a matter of replace only a fuse for Rs.25. Respect Rumesh88 who started the investigation in proper way.
  19. What is the purpose of low rate if claims are rejected or deduced more than 60% ?? We too love low rates until they pay our full claim. Otherwise, better to have 3rd party and repair the car by own money.
  20. I think its depend on Agent or any reputed repair center. If they confirms this vehicle is beyond repair, then Insurance has to pay. Otherwise, insurance has to repair the car.
  21. Below document having more details about DTC codes. Specially trouble areas. All codes are available except 655. Please check and it will give some clue. http://priuschat.com/attachments/2010-prius-dtc-codes-pdf.33416/
  22. Couldn't be still the leak is there.? Need to dry or identify the short circuiting point. ??
  23. Adding to rumesh88 reply, If code clearance also not working, propose to remove 12V battery terminal and keep some time to reset every thing. Then reconnect the battery terminal and try to start the vehicle. However, as rumesh88 also said, no point of doing those things before drying the HV battery pack area. Since the batteries are made to withstand for heat, propose to use hairdryer to dry battery pack area.
  24. Found below in priuschat. Quote ... I live in Northwest Florida where it had a flash flood yesterday. My car was in a parking lot where water backed up about wheel-high, and I got a bunch of water inside. I managed to get my car home safely, though I had to go through a couple places with some water buildup. I got out most of the water last night, and put rice inside to soak up some moisture. Today, my car won't start. The keyless entry worked, I got inside and went to start it, and then it flashed the check engine light and the snowflake light. I'm not sure about others, but I know those two came on. The check engine light stayed on for a minute or two, and then went out. Now the car is completely unresponsive. Does anyone know if I just need a jumpstart, or if something else might be wrong? I parked on a upward slope with the intention of getting the water to pool backwards, but I wonder if it did something to the battery? Any help would be hugely appreciated. ....Unquote. The wordings are almost same with your post except few and "He" has used alternatively for "I". Are you seriously referring true case or just post this to check the knowledge of AL users.? If your case is true, then sorry for misunderstanding.
  25. If any car has full insurance, then the very first thing should have to do is take the car to any nearest safe place without starting and call insurance. (BTW now this step has gone but still your friend can inform it to the insurance but I don't know how he could prove the incident). As I know, they will pay for not only electronics, mechanical damages, but also for cleaning and drying cost. One of my friend got a reasonable claim even for upholstery cleaning few years back.
