Everything posted by gayanath
Prius 3Rd Gen Market Price
If you need to know the market price, please read the post no 22 and 23. I don't know from where you both guys (BuBi & Rjivi) came from....... Despite of given crystal clear facts, figures and information (including market prices, values, the differences, the similarities, technology improvements in both hybrids and non hybrids, reliability information, etc) by others, still telling same story....... No point of continuing this with you. Both you and we will not learn anything new from this...
The Inverter failed at 19,000 km and it's probably a manufacturing fault. Any 6 sigma company would be have 4-5 defects for 1 M products so no need to worry. There are enough Aquas done more than 100,000 km without any issue in other countries and even few in SL. Environment is not much issue as Prius C (international variant of Aqua) has manufactured for all whether conditions which is sharing same engine and transmission.
Do you know how many inverters replaced in Sri Lanka?. I know one guy who replaced his inverter with coolant pump (Toyota Aqua 2013) for Rs. 160,000 (total bill)and parts imported from Singapore. According to him he got 1 year warranty as well but don't know whether the parts are BN or used. Even though power electronic parts are depreciating there performance with the time, this is the first time I heard the rate is much higher than mechanical parts. There are + and - things on both hybrids and non-hybrids. But my point is, the fear for the technology is useless. We use to live with technology. Whether hybrid or not, we have to face lots of problems while repairing those things. Now you are thinking only cars. But there are lot more things in the industry. Buses, trains, ships, cranes, planes, building services like AC, etc. Everything consists of electronics and the technology is changing day by day. You cannot repair even power window switch in your car sometimes now and you have to replace the entire thing as its links with ECU by CAN communication system. Do you recommend buying a car without power windows for ease of repair? For your next query, every car buyer who purchase new car is trying to use the car less trouble for him and pass it over for next guy who has to replace each and every worn parts (starting from bearings, shocks, CV, ………. And finally the engine and body). It’s common for all (even for you) and not specific for hybrids.
My intention was to drive you towards which you told now. Yes, we cannot do proper repair for both of them present in SL (lets expect positively we could do soon by the way). In our context, our people are experts to replace parts with recon (kadapu badu) parts imported from Japan. So, when those parts are popular, price will come down. (I could purchase CV joint which for Rs. 8,000 where original one Rs. 75,000 and used for around 50,000 km until I sold the car without any issue). Your 2 laks CVT box cost less than Rs. 75,000 (two years back, my friend replaced CVT box of his car) and expect HSD could buy for less than Rs. 150,000 near future.
Good question. Please answer this before answering your question. Please let me know any place which can repair CVT gear box (lets say pulley replacement or even internal bearing replacement of Toyota Allion car).
Nissan Leaf Hack Vulnerability Disclosed
Whether this is applicable to SL or not, thanks for sharing the information.
Toyota Prius 3Rd Gen Vs Toyota Allion A18
Curb Weight - A15 - 1200 kg, A18 - 1230 kg, Prius 3rd - 1379 kg. Prius is 12% over weight than A18. If you go in to deep, though power-to-weight ratio give some scene, it's not enough to do sensitive comparison between prius and allion due to the difference in transaxle. Belt and pully CVT has good feature that its good for acceleration than conventional auto which I have experienced (however its depend on the driving pattern). However, prius eCVT which highly depend on its traction motor and battery charge level at low speeds cannot compare by engine power to weight ratio if you go in to deep. Though I have driven Allion A18, Allion A15 and Aqua, still I couldn't drive a Prius 3rd gen. So assume asrock is correct. I too agree with you regarding the wiki matter. There are several people (even on AL) who just follow sources we cannot trust and provided by non technical people who depends on rumors. IMO, Auto Lanka should promote the discussions with more in technical, due to unavailability of proper technical staff in Sri Lanka as highlighted by all in most threads.
Two controversial ideas by asrock and sathyajithj99. asrock - acceleration of both A18 and prius same but Prius could slightly better with low end torque sathyajithj99 - even A15 acceleration is quite good comparing with Prius The reality, A15 - Engine 1NZ-FE - Output - 81.2 kW (109 hp) at 6000 rpm with 141 Nm (103 lb·ft) of torque at 4200 rpm A18 - Engine 2ZR-FE - Output - 98 kW (132 hp) at 6000 rpm and 174 N·m (128 lb·ft) of torque at 4400 rpm Prius 3rd - Engine combination 2ZR-FXE - Engine output -73 kW (98 hp) and 142 N·m (105 lb·ft) of torque, paired with electric motor/generators in the hybrid drive system; together the engine and electric motors produce up to 100 kW (134 hp) and 207 N·m (153 lb·ft) Technically, due to 60 kW motor support (motors are giving the max torque even in 0 rpm) Prius should be high in torque at low speed (need to switch off eco mode I guess) which need for acceleration.
Any new car whether hybrid or non hybrid are designed for shorter durations now. So, whatever you buy, you have to face same technology advancement issue. Otherwise you have to buy a car manufactured before at-least year 2000.
Better to come up with facts and figurs rather than just a statement. Just a statement will not give any sense.
Best Auto Service Center
Dear Davy, adjust idling RPM by scanner - 1. If you go through the paragraph again, its not a recommendation. Until he gives requested answers, I explained that, he may not receive valuable information by scanning. Then I explained what he could do for this issue by scanner but it too may be not possible due to explained reasons. My intention was to demote the scanning without proper clue as lots of makabases are doing several experiments with our cars when taken to the service place. My intention was well explained by my second reply (#7). 2. As you pointed out ECU reprogramming, then I mentioned adjusting idle is not a reprogramming and it's not a big task and what can be done by it. That's it. cleaning MAF sensor- As I explained previously, theoretically engine rpm should not go down while learning. Therefore, need some cleaning though. If you have some kind of technical background, you cannot exclude wear and tear (I have to write a full page to explain it) and I have missing one more word "deposits" while writing. However, his direct issue is not because of it (I mean - for him, he used the car without an issue sensed to him, then he recently observed and issue, and so on). The solution for direct issue is xxxx and then given yyyy for one of the the root-course but the easiest and low cost one required only 5 min work. Cleaning the throttle body is obvious while cleaning MAF by experienced mechanic and, but I have experienced with missing MAF cleaning by some people even while so called tune-up (though I hate the word tune-up) so I specially mentioned it. There are lot more things to be recommended by several others but not compulsory required to attend frequently and he has not even mentioned his millage or any other previous data to go further. Hope this will clarify all the matters and now its clear that no contradiction. P.S. - Don't be serious on any thing (not only technical, but also even words written because we cannot express every thing in the mind by words), always be simple, it will open several paths to think further. Dear Other AL members, Sorry for any inconvenienced to you due to this discussion between Davy and me, in an open forum.
Dear Davy, Actually, I didn't replied to you since no point of debating you and me while problem is with Ted. Now see below reply from Ted. According to him, he has reset the ECU due to some reason before the issue. The thing I mentioned as ECU learning is what he was told by other guy too and it needs to ride 30-40 km to re-learn the driving condition and related data. Start stop and slow speed running will quicker the learning process than continuous running becouse the issue is with idling (and more idling running is required to learn idling). One more technical thing - Theoretically, car engine should not stopped while this process, but practical scenario is, when ECU reset it will goes to factory settings. Since the car is used now, factory setting for idling is not perfectly matching with the current condition of the engine due to the ware and tare of components. While learning driving conditions/styles, ECU can adjust its parameters to keep correct rpm for idling matching with the current status of the components. I have experienced this scenario two times in one of my old car. (first time I didn't care about the outside power and replaced the battery by myself. other time I have intentionally removed battery terminals to reset ECU to observe any change) That's why we need to start from very simple thing first and need basic information before going to advice. Dear Ted, In my opinion, although you will get it solved next couple of weeks, its better to clean MAF sensor too (no need to spend for full cleaning - so called tune up by our makabass).
Toyota Corolla Axio 2007 Maintenance
Highly appreciate your professional approach for the matter. Yes, shorter interval method after first replace is also a general practice (40k interval is questionable though). As an example, it has mentioned for radiator coolant as follows. For SLLC, 150,000 km for first change and 90,000 km intervals then onwards. However, couldn’t find this for CVT fluid. If you refer Prius or Prius C(Aqua) manuals, under special operating conditions (Driving while towing, using a car-top carrier, or heavy vehicle loading - though it’s not applicable even for taxi in our context), mentioned to replace transaxle oils at 90,000 km and 180,000km, etc. or every 72 months. I too agreed that oil mixing should be considered, but don’t know what is the reason for their advice. Adding followings too for further discussion. 1. Engine oil drain plugs are normally provided in the lowest point for proper draining and frequent draining requirement. Why CVT oil drain plug is provided slightly higher than lowest point and need to remove 15 bolts to remove oil pan for proper draining? 2. According to Toyota maintenance schedule, 40K interval is also mentioned in their manual for old cars. The new cars using ATF WS, CVTF TC and WS can be go for higher intervals. Still we are using very old thumb rules. I think there is a knowledge transferring barrier for latest technologies in our context due to most of the service people here are not qualified and have no proper technological and IT background to grab the latest knowledge from the readily available sources. 3. My Aqua, there are several stickers pasted in the engine compartment. It shows the replacement intervals for Engine oil, Engine oil filter, Radiator coolant, Inverter coolant (though the interval is 240,000 km), spark plugs, and some information’s like idling rpm, angle for TDC, refrigerant type etc. But the interval for transaxle oil has not mentioned. Why do they give that much less priority for it? Above are strictly not for argue with anyone, and only for friendly discussion to improve our self-knowledge if someone wish to discuss.
When we do a diagnostic, the thumb rule is, we should start from the small things (but this is very basic thing which our Sri Lankan mechanics neglecting and their practice is removing engine at the first instance). If you go through again I have used word "could be" expecting may or may not be. No point of putting bigger headache on the owners head at the first instance. If you go to meet a doctor, do he tell you this is a big issue without doing basic tests? Please see what I ask from him for further investigation. The answers will drive the investigation further and the owner will also learn to do DIY diagnostics rather than going to service station in the first instant. The very minor thing could be happen is, resetting the learned parameters (by ECU) due to battery removal. It will give this kind of stopping issue several times but will goes out after 30-40 km start stop running due to learning again. This is only very first assumption as he told the stopping happened only two times which one is with AC, and other one is while reversing. The next steps could be clogged MAF sensor, idle control valve, etc. No any ECU reprogramming required to adjust idle and its very simple thing if the scanner supports . It's not for permanent but to investigate the issue (behavior of idle) as we do not need to dismantle anything for it. Always better to complete all soft investigations (I mean, which can be done without dismantling) prior to dismantle.
This could be happen due to several minor issues and most probably no need to worry. Need to clarify followings, What is your car model and year? Did you replaced your battery or removed battery terminals for any reason recently without giving outside power? Is this problem still exists. If no any malfunction indication is existing, I think scanning will not give any valuable information other than saved/stored fault codes like "low idling", etc. You could adjust idling rpm by scanner but most of the general scanners available in our service stations has no such write facility and also, though the mechanics know how to read fault codes, most of them not aware how to adjust idling.
How about your millage now?? 1. No issue running with 92 or 95. I have used both for my all cars. No any fuel consumption increase or decrease (I have all fuel records since year 2007 up to now for three cars which I have used). 2. Rumesh88 is perfectly correct. changing interval for severe condition is 90,000 km or 72 months whichever comes first. Severe conditions covers all Sri Lankan conditions like heavy traffic, start stops, etc by the definition. However, as Rumesh88 said, most of the service people will tell you to replace it far earlier (20k, 30k, 40k, etc) without a valid reason. (For me, "for safe" is not a valid reason as there are enough safety factors included by design itself. Why don't they recommends to replace it by 10k for safe if CVT oil replacement is that much critical). This 40,000 value is a general practice for old automatic boxes and now the oils and clearances are much more improved. Anyway, the full capacity of transmission oil is about 6 ltrs, but you can only replace less than 3 ltr (2.7 L as I remember) at ones. There is a tricky point when adjusting the level.
aruntantan, buying a vehicle paying lease or cash expecting return is no more a good decision for either hybrid or non-hybrid in Sri Lanka. The trend is towards buying new cars now and any car will depreciate by the age. While my friend lost 0.35 M from his Prius in 2015, terrabytetango lost 0.35 M from his Vios. I lost 0.25 M from my Vitz in end 2014. I think this is enough for understanding.
I have one of my friend who used two second generation Prius and now using Axio hybrid. I got this detail from him few hours ago and hope this will help to figure out the behavior. bought first Prius 2nd gen in 2011 (having no much options) - unregistered, YOM-2008/01, millage-65k, price-3.35 M sold it in 2013, millage 133k, price-2.775 M bought another Prius 2nd gen in 2013 (having several options including cruise control) - registered, YOM-2008/05, millage-60k, price-3.15 M sold it (trade in for unregistered Axio) 2015 - millage 100k, price- 2.8 M *he told me, he thought he couldn't sold this to even 2.5 M, but after the tax increase in 2015 he could value it to 2.8 M
- Does Anyone Having Sri Lanka Motor Traffic Act Latest Edition ?
Hybrid Battery Is Not Sending Power To Motor
There should be few things to clarify before spending 280 km visit. You cannot find a indication of "power from battery to engine", indication should be "power from battery to transmission". 1. Is there any malfunction indication.? Normally there should be some indication if anything wrong. 2. Did you switch off eco mode. (I mean you are familiarize will eco mode always previously and now it has changed) 3. Are your idling stop working? 4. Are your AC working? (AC is completely working using HV battery in Toyota hybrids, assume Honda is same) 5. Do you feel any increase in fuel consumption? First answer this questions and then decide. Otherwise, don't wast money.
Fuel Efficiency Of Hybrid Vehicle
65% coming while they are talking energy balance, but what I got is just before CO2 emission calculation (min 1.23) they are telling "Electric cars are coal powered cars". So assume they have used 100% coal for calculation. I don't know whether who is correct. Why dubious. Please go to CEB website for Sri lankan data. You could obtain everything cumulative up to 2014. You could even take daily data up to yesterday though. Go to wiki for US data. I didn't tell we are greener than USA. if you read again I told "No, Its not". My point is both US and SL are greener than calculation assuming they have used 100% coal. If they use 65% coal for calculation, still both US and SL at the margin. Yes, though the mining process is similar, you cannot compare CO2 emission values for a volume (or weight) of Ni mining with Lithium mining without proper data. Now Hybrid manufactures are also changing from Ni-Cd to Li-Ion (ex. Honda GP5). So better to compare apple to apple than apple to orange.
Don't let your life in trouble... You are living in Sri Lanka which has no strong policies. Everything will change when the tax structure changed. Further, when auto gear cars came to market, same kind of issues were there quoting gearbox is non repairable, so second hand market could be less, etc. But now people are recommending Allion with CVT gearboxes which are non repairable than auto box. B2Spirit could be quite right.
Just now checked the Autolanka and ik**n. No 2012 less than 4.65 M
I don't know what you mean about the adviser. However its his own decisions and I got to know week after buying it. I too thought the price is bit high and when I asked, he told me he couldn't found a good car for low price. Note: I saw first hybrid car in Sri Lanka around 2004 or 2005 at our university premises if my memory serves me correct. At that time, no one thought hybrids will flood in Sri Lankan market (due to the price, complexity in technology, etc). Therefore, the market is always uncertain.
No. its not. My point is they have assumed "electricity comes from coal" for their calculations and still the CO2 emission is less in the life cycle. But actually, the entire electricity demand is not supplying from coal. Its a combination of several sources including renewable and lesser CO2 emission. Please see below comparison for year 2014. This will explain the scenario well. Year 2014 Sri Lanka - Hydro 36.7%, Fuel oil 34.8%, Coal 25.9%, Other renewable 2.6%, USA - Coal 38.8%, Natural gas 27.4%, Nuclear 19.5%, Other renewable 13.2%, Other 1.1% Though I am positive for introduction of EV's, I too not agreed about the given amount of concession. But if we didn't give that much concession, we cannot popular electric vehicles due to various other factors (our attitudes, the way we consider about the society & environment, the way we calculate RR, etc.). Therefore, giving higher concession first and reduce it gradually withing 5 - 10 years is more practical.
