Everything posted by Ruslan
Self Tunning Or Ecu Resetting?doing Magcitystuff@home
You wont believe how much they (Toyota La**) charged for the new key and programmed it for my car, (I lost my key) it was 21,***/- i don't want to go after them for another reprogramming session. Thanks For Link Don. i will let you know the Results
i just did a Google search for my car, which is Corolla Luxel (122) so far i found this, 1. Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter). 2. Perform these steps within 5 seconds 1. Insert the key into the ignition (don’t turn it) Pull key out 2. Insert the key into the ignition (don’t turn it) Pull key out 3. Perform these steps within 40 seconds 1. Close, then open the drivers door. 2. Close, then open the drivers door. 3. Insert the key into the ignition (don’t turn it) and pull it out. 4. Perform these steps within 40 seconds 1. Close, then open the drivers door. 2. Close, then open the drivers door. 3. Insert the key into the ignition and leave in the ignition. 4. Close the drivers door Turn the ignition to ON (as far as you can go without cranking the engine), then back to off . 5. Remove the key from the ignition. 5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point. 6. Perform these steps within 40 seconds 1. Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds 2. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted. 7. Open drivers door problem is mine has only one button on key so i'm not sure how to perform the 6th step!! anyone who has done with it welcome!
Don, Can you tell us the procedure??
So by doing this do i have to reprogrammed my remote key again... (If i removed the Battery Terminals)
Cut And Polish
So guys? whats the Average Charges For Polishing (Including Cut) at one of those Joints??
Cut And Polish
Thanks again, i only wanted to cut the paint in bumper area (Thats where the most cracks are )
Cut And Polish
Thanks Don, but it doesn't say anything regarding "cutting the paint". is it safe to cut the paint using a chemical like "brass@"??
Cut And Polish
Guys.. anyone knows how to Cut and polish a car by ourselves!.. if its impossible to do, can you guys recommend a place to me. i've got some minor scratches in my cars bumper area.. do you guys think that by doing a cut and polish will give some results?
Gravel And Corrosion Protection
I used to cover those Plastic panels (In Corolla 121... since the interior beige colored, tends to get dirty all the time ) with thick polythene and blow it with hot air gun.. that will cause the polythene to wrap it around the Plastic panel. this way you can clean the plastic panels very easily. you can even get this done by those "cushion work" guys.. there are couple of shops down at near "Delkanda pola"(Near Nugegoda) area.
Corona At190 Or St190 (1.8)
If your going for an auto gear one, better look for the ST190. if not stick with AT190.. cos i herd the AT190 with Auto is bit underpowered...
