Ruslan
Everything posted by Ruslan
  1. Ruslan replied to Susa297's topic in General
    Previous Gen 240, 121, IST (1.5) would be compatible but Intake manifold and exhaust manifolds would be differ. even though these share the same AT Boxes (U340E), there might be slight variations with in built sensors etc.
  2. Any idea about the price difference between 1300CC Model?
  3. And Some Early Vios's as Made in Japan.
  4. Did you do the Emission test at the same place on second time? if you did the emission test at Drive green, try to do it in a Laughs eco place. friend of mines 2016 Hilux (Brand New) failed at Drive green (Quite strange), but passed at Laughs Eco sri without any issue (Could be due to their testing tool malfunction or something else). on the other note, did you got a CEL? bit strange you failed the emission test without throwing a CEL.
  5. Familia is JDM (japanese domestic model) car. Usually JDMs doesnt carry a VIN. JDM models identified by their Chassis code.
  6. FIAMM which sold in panchi are made in Italy. Got myself a pair of AM80S which cost around 2500/-. Came with a FIAMM relay as well.
  7. Congrats, on the Buy. i guess the Price is worth it for a Fit. Since it's 1.3 how is it compared with rest of the 1.5 Brethren?
  8. Maintenance Wise Petrol will be easy to maintain, No DPF Cleaning etc. Newer Common-rail engines have issues with Local Fuel.
  9. There should be a another fuse box located in the dash (Probably under the steering). Check the "Tail" fuse in that.
  10. + for Baygon or Mortein, used it and it worked Nicely, Spray it inside boot, inside upholstery panels etc, and close the doors for a while (5-10Mins) and then opened the doors under the Sun.
  11. This is indeed a ex DPL car. which i would believe specially ordered by the Agents, and lately resold with Regular plates. we used to have Luxel but it's an Auto, nothing bad about 1ZZ-FE.
  12. Using XenonDepot 4300K Philips Kit in Family owned Premio 260. have to say well worth the upgrade. got it from kbcarstuff.com while i was in US. and Guys, have you seen the JW speaker Housings, interesting stuff. specially Rectangular sealed beam replacements from them.
  13. Found them Reconditioned from Dehiwala Ravindra Tire works. got them Painted in Gun Metal Grey. Rims without painting costs me 20K. this is the above shown 16" Genuine Toyota Rims Comes with 1.8 X LGgrade
  14. Even though Axio and Corolla (121) share the same Engine (1NZ-FE), most of the components in the Axio is totally different, for example Injectors, Head, ECU Map is totally different than previous Gen corolla. added CVT to that list you'll get a totally different car.
  15. I'm Driving a 2006 Face-lifted Vios, Cosmetically front Grille, Headlights, Gauge cluster and Tail lights has some subtle changes over pre-facelift model. did the intermittent wiper modification using Corolla 121 Wiper switch. it's a plug and play mod. and only S Grade models came with Folding mirror option. but easily swappable on E grades as it's pre wired and only Mirror unit and switch (With Folding button) needs to be replaced.
  16. Ruslan replied to lasa's topic in The Lounge
    So far so good, there's wee bit road noise which doesn't bother that much. comfort levels are ok as well.
  17. Ruslan replied to lasa's topic in The Lounge
    Got the Same tire brand in 175/65 R14 size for 10,500/- got the free alignment, balancing + discount coupons for spares and Oil (15% off) from wattala Toyota. This was back in June 2015 with 30% off.
  18. Cheap? and Reliability, since it doesn't need those Gaskets unlike Halogen Housings.
  19. Suggestion, replace the bulbs with either Osram Night-breakers or Philips Extreme visions. you wont regret it
  20. Yes, you can replace it with H4 Rectangular Unit. wire loom will be same. just look around in Delkanda area. we did the same for Family owned Townace Van once. plus, you don't need a mechanic, unscrew the frame around the Sealed beam, repeat it with H4 Housing replacement.
  21. In Mine too (Vios 2006) apparently it's cable driven.
  22. Isn't the Luxury taxes will get cancelled after April 2016??.. saw it on the Budget docs on web.
  23. Retrofitting is possible in Aqua as firmware has the feature already. Only need to install the switch stalk.
  24. I think 4DR6 is the same block of 4DR5 with Turbocharged with direct injection. So check the condition of the Turbo.
  25. 4DR6 would be straight forward swap as it will share among the J Series Jeeps (aka Safarai Model) as i herd, might want to swap the rear Axle as well because of the final ratio difference.
