Everything posted by Sparky
Is This A Normal Behaviour
It's your idle speed. It's a simple adjustment if you know where the knob is. And Mazdaspeed, you're problem was the same. Your idle was set way too low. In both cases it's a quick adjustment that takes less than five minutes. If you don't have an RPM gauge then you have to adjust it by listening to the engine. Keep lowering it until the engine starts vibrating and feels like it's about to stall. This means that the engine isn't turning over enough to overcome it's internal resistive forces. Once you figure out where that point is, just increase the idle speed until the vibration stops and it feels like the engine is "comfortable". If your car still stalls when starting off then set the speed higher or check the clutch. Hope that helps.
Xenon Headlights
Swapping out the standard bulbs for brighter ones is usually the first thing I do. I stick with standard 100W incandescents. They're cheap and technically a drop in replacement, but because of the higher wattage replacing the relays is a good idea in the long run. It's a fairly simple procedure and can be done in less than an hour if the electrician knows what they are doing. And yes, these bulbs run very hot and any plastic in close proximity is going to suffer. This isn't an issue in my current car as the lights are "well ventilated". I believe these are technically classed as racing lamps and would not be allowed for road use in more 'civilized' countries, but I've found a solution to this... ... which I use on the morons who drive on high-beams all the time. I have them adjusted so that on low-beam they tilt downwards and illuminate around 10 metres in front of my car. They are pretty bright and more than enough to drive on and because they are tilted downwards don't cause any problems for oncoming traffic. But when some idiot comes at me with their high-beams on I light mine up until they get the message. Those things are seriously frickin' bright and useful for teaching people manners they should have learnt a long time ago.
Petrol 90 Octane Or 95 Octane ???
I've generally found a slight increase in power when using 95 octane over 90. This is over a couple of years usage on a carburreted and then an EFI engine. I also generally notice a lot of pinging at moderate to high RPM on both engines with 95. No noticable difference in mileage. Given the increase in power and the smoother ride I always choose 95 when it's available.
Link Between Value And Colour?
Okay. I've made my decision... I going with whi black. Told my mechanic this morning, which means he's bought the paint by now, which means it's too late to change my mind. He tells me he'll be doing five(!) coats of paint. One undercoat, one black with will be cut and then another black and then two coats of clear. This could get interesting. I blame Dan.
Good lord, are good painters that hard to find? I have issues about posting phone numbers on forums but mail me at [email protected] and I'll send it to you. Okay, making a decision about the paint tomorrow morning so any final comments would be welcome. I've posted pics so it shouldn't be too hard.
Really? Wow, that's a bit odd. No private messaging at all? Hm...
Milindu, sorry... didn't see your post. I own a Mazda RX-7 FC with a 13B-REW engine swap. Hehe, just kidding. I wish. I own an Astina from '89. Like I said before it's currently red but that's a pretty common colour for this car. Blue and grey looks too old fashioned on this car. Bright orange looks surprisingly good, though I don't think I could live with an orange car. This is roughly how the car looks now: This is white: And this is black: I'm trying to stay away from metallic colours which I don't think work too well with this car unless you're doing a lot more to it. So, what do you guys think? Oh, and PM me if you want my mechanic's name? I'd suggest that you wait till after my car's done if you want my proper opinion on his paintwork. I've seen his work before, but not on this scale.
Oops, double post. See below.
Pilawoos, the car is currently red... but I've just replaced my engine (crack in the cylinder block) so I will need to change the registration before I sell anyway. I believe this also means I can get a new number, is that true? Mihirana, the car doesn't have any obvious damage or warping, except on the bonnet which I've been assured can be fixed good as new. I've seen his tinkering work before and I'm inclined to believe him. Most of the "damage" on this car is due to a previous botched up paint job: single coat without an undercoat with some of it going on in wet conditions. I'm stripping the car down completely and whatever colour goes on gets an undercoat and a clear topcoat as well. By the way... does anyone know a good tuner for Mazda EFI engines from the late 80s? I'm coming up on 1,000kms since the new engine so I think it's time I got it properly tuned.
Well, I've done some checking and black and white both look very good on this car. The black is slightly sexier IMO. I would rather have the white because of the comfort and safety aspect, but it makes the car is a little too eye-catching... which is not something that appeals to me. I also might be selling this car sometime next year so I need to think about keeping the value up. It's an annoying dilemma.
Car's going to be painted end next week. Still haven't decided on a colour. Was thinking of a pearl white, but a friend of mine insists that black is the way to go because it will increase the value of the car. Another friend says that black would make it very hot, which I'm trying to avoid because it goes against my whole "comfort" theme. So, does the colour have an impact on the value? If so, how much?
2007 Skyline Gtr
Technically, it would be wrong to refer to this car as a "Sleeper". A Sleeper is usually considered to be a car that looks like any other standard or economy car but has been modified to perform at much higher levels. Check the Wikipedia entry. The point I'm trying to make is that you'll never really be able to mistake this car for anything other than a Nissan GT-R and you'd always expect it to perform as such.
Soundproofing Help
Thanks Ruwan, will check it out.
Soundproofing Help
Thanks Ruwan, will check it out. Do you know how much it costs?
Gravel And Corrosion Protection
Sorry, double post.
Soundproofing Help
Thanks, didn't see that before. Does anyone know if Dynamat is sold locally?
Hi Milindu, Where can I find this? Are these panels self adhesive?
Soundproofing Help
Hi guys, first post... though I've been visiting for a while. I've just put my car in for a full overhaul and painting and want to beef up the soundproofing. I'm aiming for as quiet and comfortable a car as possible and I want to cut down on external noise. So far I've checked with Pet#o who quoted Rs. 30,000 for soundproofing the entire cabin, using something called "Squash" (I may have misheard). My mechanic says he usually uses a material like felt, which cuts down on sound but can be problematic if it gets wet. I've had problems with a leaky sunroof before so I'd like to avoid that just in case it crops up again. I've also looked at importing some Dynamat, but that will run to about Rs. 20,000 including shipping. So, any ideas on what I should do? Are there better alternatives? Any help would be greatly appreciated.
