Iroshana
Everything posted by Iroshana
  1. Oh god. Are you happy with the performance of 4DR5 for this long wheel base landy??? This looks really nice.
  2. I also never heard any 109 with suspension in rear. Even 166 also coming with rear leaf springs.
  3. As far as i know this problem caused by the "load sensing proportionating valve". Some people used to adjust the original height of the vehicle in different ways. If we change the height of the vehicle we must need to adjust the proportionating valve. If not brake distribution will not be in a proper way causing to drag rear wheels loosing traction. New Hilux manufactured in Thailand found a good solution for this problem. They fix a notice inside the driver's door saying if anybody adjust the height, proportionating valve also must be adjusted.
  4. We have one Toyota LN106 (3L) which has done 330,000Km. Overhauled around 200,000kms. So far doing well. Other one is Mitsubishi Pajero (4d56) also done more than 300,000km with one overhaul. So far doing well.
  5. Fargo steering box is better
  6. If this is 4DR5 / 6 original diesel jeep, conversion will cost around 30k (only for front wheels). Toyota CR30 brake assembly is compatible for this modification.
  7. Hey anybody have any idea about weather? just heard its raining at Diyatalawa. Is it true??
  8. I'm gonna ride my 250 on 17th early morning to Foxhill and planing to back on the same day. Wish me luck coz I know you also a good rider.
  9. What is the type of your battery? (Manufacturer) I'm not sure whether they will replace the battery because damages to the terminal is mostly due to loosen lugs. usually Its not a fault of the battery. Seems you have a 24V system on your vehicle.
  10. This could happen even due to faulty radiator cap. Check whether there is any signs of leak.
  11. Excellent work
  12. Machan u got the 4DR5 Manual?? Sorry for OT.
  13. Iroshana
    Toyota Bj43
    What u wanna know?
  14. As ripper said HID could not be standalone bulbs since they require separate system to operate the Xenon bulb. However I have seen most of ppl selling some bulbs saying its same as HID. Be aware when trying to find "standalone bulbs" giving more light since most of them are completely different from HID concept and consume more power than a normal bulb causing damages to plastic head lights, reflectors and the electrical system. Before looking for HID, just find some info about color temperature and how it affects when driving. HID are having higher color temperatures and when it reaching more and more high, it becomes useless.
  15. I'm with u ripper. I like cars but I love bikes. Bike become a shit only when its raining
  16. My first topic still active after more than one year
  17. Just mention your electrical requirement.
  18. Union chemists
  19. Its true for me too. Once I went from Colombo to Galle and came back without the radiator fan without any issue. I kept a good speed during the entire trip since it was in night. I think the AC fan is also doing some work for the radiator too. But this is only both are at same place.
  20. Thanks for the comment and I know it very well since I'm also in harbour. Anyway I'm looking for something like this Blasting
  21. Anybody knows a place where we could clean the engine parts with glass bead blasting in SL?
  22. Hey, anybody aware that etickets service has stopped? Their site (etickets.lk) is not working and its not in even Dialog 444 menu. I used to use this service many times and had a good service from them + dialog. I heard few complains for etickets but i didn't had any difficulties with them. However seems finally its disappeared. Anybody know the reason??
  23. Refer following web. This is having all info. http://www.autoled.info/
  24. No. My engine is MC14E which is common for CBR250RR. I'm using that manual. Its very useful.
  25. Machan I did it myself in last weekend. Its working fine. Honda service manual helped me lot. Now I'm having a water dripping silensor Seems no Hornet fan here.
