john cooper
Everything posted by john cooper
  1. Replaced the MAF (used parts) and clear the fault by disconnecting the battery connector and looking all good now. Thank you all for the any comment added to this tread. regards JC
  2. Over the weekend i had bit of a free time so spend time with the KIA even if it on the auction for $reserve. Done bit of a reading and video on how to as below i manage to isolate the issue to MAF, when i adjust the throttle values stay the same and won't change. Tested the TPS using the multi meter and it was functioning as it should, i am sure it is useful the above link to any of you guys. My Sportage engine looks like the below, Hoping to get a air flow sensor soon or sell this as is where is. regards, JC
  3. This is a common model here in NZ and most of them off the road and very easy to find them on every junk yard, sure that will explain lot to you.
  4. Hello dhoni, Both the models was well known in SL and i don't think this is a question to ask as we trying to compare apple to apple. (pretty much) Majority of them made to carry goods not the passengers, so no comment about which one comfortable. Townace: 2C engine - 1984CC Hiace: 2L model on early hiace 24xx CC and famous 3L engine 2779CC So hiace got better power over the town ACE but high fuel consumption. Hiace got more room and townace is small compared to hiace. Call is your, as we don't know your requirement about a van but they all good. regards, JC
  5. I have checked with a scanner which normally work for all the model (Launch scanner) and i can see my car listed but it wont show any fault code under ECM. I even tried bridging the pins to get a check engine blink to convert but it won't give any blink. (may be i was bridging the wrong pins)
  6. Good question, why don't i take it to a professional - paid only $1400, at least cost of fixing near the half of it.
  7. Didn't check, will that turn the "check engine" as i got the light.
  8. Hello SHIRAN, Manufactured recommended size indicated on a sticker somewhere in the vehicle (post 2000) so check the sticker and stick to that. My father told me y'day he replaced Vits RS with 4 x Bridgestone sneaker tyre 175x60x15 - 13.500 each they are Jap tyres made on 2017, which seems to me a good deal and that is the same size and the brad came with the car so he stick to that. They are Jap tyre made on 2017. regards JC
  9. Just an update, i have done bit of DIY for Sport"age" at the weekend. Cleaned the Air flow sensor with cleaning spray - it is surprisingly change the power loss and engine cut around 2-3k RPM but still rough idle and worse on fuel. Now 2 suspects - TPS or Air flow sensor (BOSCH made) I have done few test runs over the free way at 100km and drive without any issue, but when i stop at a light signal engine stall and cuts off if i didn't press the throttle. any thoughts?????? regards, JC
  10. i Would if anyone interested
  11. Any luck from any of you?
  12. "Recently I imported" seems like a Jap import so my gut feeling they won't cover under company service plan.
  13. Hello DonRJ, I had 2 of them made for 4WD recently sold (mistake) to build a better bigger engine truck which already in bad shape. I am sure this topic turned up in here few times? but ill give few information and rest for you to search here. Pros: Cheap to buy in SL as it is not famous as a family vehicle in SL (2 door) and it's "Suzuki" not a toyota for SL Power to weight ratio is high when you compared to most of the other solid axle (ie LC, LR) so good in off road cheap on gas - 1.3L engine (or some get 660cc not my choice) Solid axle - best for off road Separate transfer box - best for off road again. Ladder frame chassis - so you can do all sort of modification for lifting Cons: Not comfortable at all (Have a test drive with your wife/GF before buy a one) bit sluggish Not the beauty at the show Cheap Plastic interior King pin need replace pretty much every 40k Body parts might be an issue in SL???? Lack of power once you bogged or lost traction to 2 of the wheels (you can go with M16A engine transplant but it is costly) It is good truck for the price and surprise the 4WD capability that you get from such a small truck. Happy Jim hunting! regards JC
  14. I would advise you to visit the agents, they go with the service plan and check what's needed to be changed and start off with that place.
  15. It is very hard in SL as out boys are very good at hiding/fixing this kind of issues unless you ask from Devale Kapu mahaththaya.
  16. Carb, Cons: more pain in the morning, most of them need a warm up less responsive Outdated Pros: cheap/ easy to fix EFI: Pros: Turn the key and way off Better response (compared to 800cc carb) Cons: Bit expensive (if you had to replace throttle body) Go for the EFI I have a doubt about 04 carb model? anyway go with the technology don't go backwards regards JC
  17. Hi all, I need help form all of you guys, bought the 97 Kia Sportage (Gen1) with the MAZDA FE3 engine (dual cam), original intention to make this as my off road replacement but plans gone to custard as it's start developing an engine miss. This is fitted with a factory immobilizer and i have replaced the battery as i was not able to by pass the immobilizer because numbers faded on the key fob (manual shows how to bypass if i had the S/N) next day after change the battery car wasn't starting so i left it for few days and started all of a sudden. then onward it was showing the signs of engine miss and engine light indicates. What i have done, One of my mate got a Launch scanner and i got the Kia plug (guess odb1) and try scan the fault but it wasn't showing the fault correctly but seems to me t's identify the car. Done bit of a readings and i have decided to replace the Cam sensor as the most of the symptoms equal to mine (power lagging, unburn fuel smell, poor gas mileage, check engine light) So replaced the cam sensor but still no luck as the light still indicate (since i have no way to clear the fault, taken off the terminal for about 15min) sick and tired with the car i paid $1400 so if it's not resolved i will send this to wreckers as it's taking space and it's pain in the back BUT if any one of you would be able to give me and indication of what else for me to check?????? regards JC
  18. New model always good, because car manufacturers improve what they have missed on previous model (most cases) also when it's old it's getting harder to find the pare parts (specially body parts) Would be good to go for 14 regards, JC
  19. Please make sure cooling system filled with the correct type of coolant to help prevent the aluminium corrosion.
  20. Hi dantoddd, Are you talking about about Sri Lanka city or another country? coz i am not sure you can do fast driving in Sri lanka cites, specially in colombo. Get a Prius, you get the power mode to do fast when you can. regards JC
  21. Hello NFC, I have no experience with a defender (It's so expensive here), i had few PRADO's (LJ78, KZJ95,120 and KZJ150) and still using a 150 face lift as a daily drive. compared to the pajero vs prado it's way better build quality in prado. 4M40/41 sound bit of a canter lorry compared to 1KZ-TE or 1KD. 1 KZ you need to change the T belt every 150,000KM but 4M40/41 timming chain but still need replace every 250,000KM. PRADO no known issues also had no issues with Pajero too. Put a turbo timer so you can avoid a risk of blown turbo which is a big cost to replace. Do the correct service with correct parts for 1KZ and you get a good life with it. Prado would be the best out of all 3 but others may have different ideas. regards JC
  22. Hello Sam3449 Pajero V5x series (AKA Mahaththaya model) share the same characters from V46 model AKA inter cooler with a face lift + and added safety (dual SRS airbag, 4 ABS) use the same 4M40 Mitsubishi 2835CC engine in diesel model and 3500 CC patrol engine. Fuel figures should be same as V46 I am not sure if you could find a well maintained one but good luck. regards JC
  23. john cooper replied to chand's topic in General
    Hello Chand Welcome to AL, Trooper AKA Bighorn they are nice trucks, I am not sure if still able to find a decent truck below 2.5mil???? May be if you referring to UBS55. As per my knowledge if you are referring to UBS69 model with 32- number i am sure all of them should have a body permit as they manufactured from 1991 onward so they should start with 61- or 64- plate. One of my mate had a UBS55 Trooper (Previous owner transplant a flat roof) to make it as a Bighorn also put a bighorn kit including Recaro seats and interior. Which is fine as this is still with original chassis. I have seen another truck same body fitted to a same model chassis. I can't see anything wrong with that as no one could prove that's a new body or old body being repaired and repainted. They are good solid trucks 4JB1 intercool turbo engine has lots of power yet economical as your C90. Good luck with your hunt. regards JC
  24. Still the good old neutral gear to use at extreme situations.
  25. Heard previous Govt press pause for this, any one aware about this? Still need to sorted for wife. Let's not to worry about lands, how about vehicles if it's under your name and you loose the citizenship in SL? regards JC
