Everything posted by kush
- Wrist Watch buckle repair
- Market value
- KIA Picanto information
Hyundai Grand i10
yes and is cheaper with 5 year 150k warrenty
- DATSON REDI-GO Japanese or not?
Nissan "leaf"
I never get this in Colombo, maximum 135-150km indicated 80-100 km actual on 100% KWh of a full charge seems right at 20 units
- Toyota corolla 141 (3ZZ-FE) Engine Knock
- Lancer Cs1 Suspension
Toyota Corolla 141 ABS modulator
This could actually be a loose connection, I had a similar experience with lights not working, company fixed a new light switch stalk when it did not work only they checked the connections. Since I was present they could not charge for the replacement. Contact cleaner might do the job
- Toyota Corolla 141 ABS modulator
Renault kwid
Durability ??? material and build quality seems very flimsy. Do not have high expectations as this is a cheap car Go for Kia Picanto if you can stretch
toyota corolla 141 or axio
None of the cars came with sunroof, unless you punch a hole in the roof i don't see this happening May be the docs had sweaty head
-economical (yes you get more kmpl in Axio) -powerful (no unless you opt for 1.8 L) -comfortable (Depends on the road, 141 has more firm suspension with substantial ground clearance and bit more travel, more comfortable in bad roads, you don't need to worry about banging the undercarriage) -reliable (equal, 141 may have a advantage due to basic engine, transmission, i have never heard of a issue in a 141, although Axio engines are prone to sludge buildup) -well built (equal, 2008-2010 141s made in Japan) -range of grades to choose(X,X limited,G,G limited,Luxel vs LX,GLI) (141 will be more or less in line with X grade Axio, so most of the Axios will have more bells and whistles)
- Mitsubishi Lancer Recall due to faulty airbag
Toyota - Aqua
Try replacing smart key battery
Suzuki Swift 2008 Gear box malfunction (doesn't tick over)
What was the ATF used, 71S has a CVT, there is special oil for this gear box (expensive, they call it liquid gold, last I checked few years back when I had a 71S it was around Rs. 5k per lit.) My advise take the car in a carrier to the agent (A*W), they are not that expensive.
7.5 Km Per L Xtrail 2015 4x4 ?
Based on my experience last 3 years over 25k km, on a 2013 RM2 (4WD), city (Hokandara - Colombo, via Parliament Road)
CRV 4WD does 7-8 kmpl in CIty and 12-13 kmpl Outstation, best 16 kmpl, why spend on hybrid
Allion / Premio
My Toyota Sprinter CE100 1991 had independent rear suspension
Al*i*nz Insurance
My BIL is with them for the last 5 years had several small claims no issues. Last claim was for damage caused by lightning and they paid 85% (details in thread “Struck by lightning”)
- Struck By Lightning
Struck By Lightning
Finally Insurance made good 85% of the claim of Rs. 158K Replacements being ECU, ABS Module, Alternator, EPS and some other sensors.
