kush
Everything posted by kush
  1. Last week a friend got down one for Rs. 3.050 Mn. (Personally imported)
  2. Not worth even considering unless you buy a 4 year old car use it for 1 year and import, in which case your tax will be based on the 40% valuation. If you want to get down the 1 year old car go and buy a permit it will be much cheaper and less hassle.
  3. I don’t think one should base the decision purely on this forum as most of us are petrol heads and therefore the views are biased towards performance, handling, driving pleasure where as for the rest of the population (95%) it does not matter. This is why the best-selling sedan car in the world is Toyota Corolla. Prius is a very good car it is comfortable, spacious, economical, has reasonable handling and is a very practical car. And when you look at the absurd tax structure in this county hybrids really make sense.
  4. Why dont you buy a Prius, will do 16 kmpl in city. Quality and space is better than Axio and in par with Allion. You should be able to get a 2010-2011 for your budget or little bit more.
  5. kush replied to dpbatagoda's topic in General
    I don’t fully agree, of cause if the brake pads are sticking to the disk this could happen. But also one should be aware that the brake pads are supposed to wear and generally after a long journey you will notice brake dust in your wheels. If you use inferior pads you will wear off the disks and also might experience brake fade.
  6. kush replied to dpbatagoda's topic in General
    20-25k seems normal especially on an Auto. Having said that driving style will also make a significant difference. More sedate driving could make your brake pads last longer and will also improve the fuel economy. I have been told that certain brake pads from third party last longer but may be with lesser breaking performance and as this could be a matter of life and death I would certainly not encourage anyone to compromise on the brakes.
  7. So in essence one could bring down a M5 paying duty for a 518, may be not at the same rate because of the engine capacity but same CIF for duty. What a country wish I had the cash.
  8. OMG all those poor souls who imported basic Monteros and pricing them around 10.0 Mil
  9. Since the vehicle is new I’ve been only using in eco mode with moderate throttle, When I took delivery it was indicating 4.5 km/l which has now improved to 8.5 km/l. Of cause this with mainly weekend commute with less traffic.
  10. Agreed, just got delivery of mine on last Friday. So far no complains ride is better than Koreans, handling may be in par, so far I didn’t have much time to put her through few corners. Fuel consumption indicates 8.5 km/l but this is not in heavy traffic. It doesn’t go like the Koreans due to less power so you don’t get the kick in the b**t feeling when you accelerate but it is a very relaxing drive. So far I didn’t floor the throttle as the vehicle is still in its running in period. Planning few trips during coming weeks will keep updating.
  11. kush replied to mensoft's topic in General
    Look at your user manual of the car. if not available may be you could download it. Most of the lubricant web sites carry recommendation for perticular vehicle / engine.
  12. Not anymore it seems
  13. You can get one down used/ recon or as some does get a brand new register overseas and get down as used. Due to the change in the customs valuation method there is only one value for a model no So technically the basic and fully loaded version will attract same duty.
  14. Check air cleaner, clutch slippage and for any diesel leaks from the tank or return line.
  15. New Montero sport is not sold on any of the above countries except New Zealand (and Australia) where they need tough SUV ‘s for farm use. The older one the Japanese build one was sold in developed countries sometime back. (You need to get updated) As for the ruggedness I have already agreed that the Monte Sport is tough. Prado is one of the few SUV’s that still deploy a ladder chassis whereas the Montero moved in to monoque few generations back. If you care to google you could get information on what that does for toughness and off road ability and also handling / comfort.
  16. Montero Sport, Toyota Fortuner, Ford Everest are made for lower income earning countries. They are not sold in USA or Europe. Safety, Comfort, handling, built quality has been compromised for ruggedness. If you are looking for a tough SUV you will not see anything better this side of a Prado. If you want comfort, handling and built quality go for a Korean or a soft roader like CRV, X-trail
  17. Go for the W124 even if it is bit older. More room, bullet proof build quality, best merc you could buy.
  18. Mollie engines did not come with this model, if one has then it should be a transplant of a new engine. This is one of the best Toyotas made and in my view better than 110. This model had the ECU under dash/ centre console therefore better insulated from elements and also independent rear suspension. Go for a 1993 upward model (face lift) which has white rear lights and R134a A/C the older model had R12. Since these cars are about 20 year old check for rust and electrical issues, check each light, window ,mirrors wipers are working. Good luck
  19. For me it seems like a clogged up CAT, why don’t you get it fixed (remove it) Best DIY way is remove the CAT get a broom stick and hammer it from one end and get the pellets out and refit it. You will get bit more power/ economy, of cause on the down side higher emissions (if everything else is ok I don’t think you will have an issue passing the emission test) And as for the oil consumption your assumption could be true, best tell-tale sign is blue smoke coming out of exhaust when you rev. You could also remove spark plugs and see for any burned oil / deposits.
  20. same old same old with a new set of jewellery By the way they have jacked up the price
  21. I tend to agree with Supra _Natural once I drove a W124 (300D) and thought what a wonderful machine, comfort handling at speed. After a while only I realised that the speedo was mph, and the car felt natural around (100-130 kmph) I wish they made cars like that.
  22. Golf has a big blind spot in the C pillar. but other than that i would say GOLF On recent models Lancer EX although the car is big it had the best turning circle (better than Suzuki Swift)
  23. Light green would be the best bet. You can fool people to think you’re driving a hybrid and saving the plant.
  24. Agreed, once in a while you should get the engine to the red line to get the VVTi of DVVTi to do their work. You don’t need to speed to do this, on an open road just floor the throttle let the engine rev. This will give a work out to your valve train and also to your auto box.
