Everything posted by Ripper
4Wd Rally Accident
Im in the process of hooking up the tow hook to my rear towing bumper. But found out the stock towing bumper is rated only for 2000lbs. Which is not even the weight of the truck. I suppose some people go beyond recommended ratings
- Triumph T R Restore Project
4Wd Rally Accident
was it the chassis breaking apart of low quality rear towing bumper coming apart?
Hid Xenon Lights
gotta say i'm very VERY happy with my two hella rallye 2000's works like a charm everytime and the best investment i made for the truck. I've aimed one light slightly higher so even bus/truck drivers get their share. But given the choice...i'd rather drive in my low beams happily enjoying some good music without having to stress over anything. that includes chasing monkeys with high power lights
4Wd Rally Accident
really sad news. I hope marshals and spectators learn from this incident
Hid Xenon Lights
I too went for high powered driving lights due to morons driving with high beams on. Almost never drive on high beam myself but when some d.head comes in with heads on, its a great feeling to have 460watts of payback So far, just one flash gets almost everyone to dip the high beam. As for people trailing behind with heads on blinding you...i slowdown, let them pass and return the favor for added pleasure, i will randomly flash the beams too once i trailed an allion guy like this all the way from maradana to peliyagoda untill he eventually pulled over and parked roadside
4Wd Rally Accident
it's the negombo 4x4 event. looks like a tow cable broke while a jeep was been pulled out. despite officials warning people not to get too close, loads of spectators who dont really understand the danger gets a little too close. A steel cable at such high tensions breaking alone is pretty dangerous. But in this case, looks like the tow vehicle was pulling out a jeep without using the winch and once the cable broke...it just ran into spectators.
Hid Xenon Lights
id say buying off ebay would be cheaper mate. since h3 is single beam, it's cheaper than the usual bi xenons used for headlights.
My Latest Idea Of Sub Woofer
The problem with the comp amp system is that generally, the subs are 8ohms. Not very efficient on a car system cos they tend to be 4ohms at the headunit and good aftermarket amps will offer you even 2ohms. Also using comp audio system means you gotta use the crossover/electronics built into that unit. Meaning you'd have to power it up with an inverter or something instead of being able to use the cars 12v system. Also headunits that offer direct subdrives too wont be able to "communicate" properly with a amplifier designed for computer systems. If you really want to try it out, i think it's possible. But looking at the hassle involved and not having the ability to really decide how you can get results the way you want...it's just not worth the hassle. I would snoop around audio installing joints and see whether they've got used subs, amps for sale on the cheap. When i first did a system install at advance, they had some used sub amps, speakers etc for sale with them. Also even the big name brands have their low end series products. If the car is small, you should be able to get an 8" inch single sub and a small monoblock amp to run it without burning a big hole in the wallet. I run a single 8" sub on my truck and it thumps fine to keep me going. Dont really burst the doors out but good enough bass
Restoration From Hell!
Good luck GTAm That sounds like quite the ambitious project.
Hid Xenon Lights
yes you can. as long as the bulb type and the wattage is the same as the chinese one you're replacing with.
Double Cab For Restoration
yeah. folks are highly passionate about it and modified class is a whole different animal now
Mechanics Specialising Mazda Models
what's the car and what are the symptoms? sometimes all you need is a good mechanic...not necessarily a brand specific "expert"
there is a mean ass gypsy that takes part in 4x4 comps. father and son team and that's a pretty mean machine. fully modded up though from seans place. the smaller length, lightweight body helps i suppose.
i'd say it would be cheaper to go for an older gypsy or something. something that haven't really been mainstream and dont have a second hand market. And what's the car you drive at the moment? I know plenty of people roaming around in their cars in pretty crappy roads. of course you gotta be sensible in the way you drive and plan your journey properly. VVTI took his P11 on some crappy estate roads without a problem and he also took his 164 to jaffna and many other places around the country. I bet there are plenty of people here who drive their regular cars on weekend runs. Unless of course you have some fancy expensive suspension setup and ultra low ground clearance
H3 Bulbs
well i listen to mostly house, trance and a bit of rock. shockingly in real life those highs you hear aren't there. it's a lot of mid range and lows with a bit of highs as fills. stupid nokia has really warped the sounds... strictly on lights, i too wanna change those fake koitos and either drop a pair of genuine hella h4's or bite the bullet and get a pair of PIAA's... Not on ebay, from a motoring site
H3 Bulbs
recorded this off my phone lil while ago. ignore the music phone cam has picked up only the high frequencies even when the sub was firing away at the time sounds real bajaj audio but its nothing like that in reality... The low beam is 90 and the high beam is 100. Koito and i bet it's fake. The bright high beam you see will be the hella rallye 2000's kicking in. that too is 100w, hella h1 bulb.
H3 Bulbs
Narva too has fakes i'm afraid I've got caught to it once myself... Had a set bought off motorcade and those worked brilliantly until i flogged the car off...
H3 Bulbs
unfortunately most koito's you get in sl are fakes. I was sold a pair that was supposed to be originals but both of em were llittle over rs1000 and their performance aint good at all. despite it being 90/100w. I run hellla h1 100w on spotties and those are leagues ahead. On an earlier post somebody was sharing a bad experience with PIAA's. Those bulbs too cost over 5000k SLR for a genuine pair. And that brand too unfortunately has a lot of fakes I've been running a genuine piaa h3 on my xr250 for the past 4 years or so. really good light. bought off www.bajadesigns.com
Alternator External Regulator
If the vehicle is low tech in terms of electronics and more importantly, you know what you're doing...hooking up an external voltage regulator is not biggie. I've done it a few times on my bikes without any issues
Car Mart No Longer Mazda Agents In Sri Lanka ?
I just hope whoever gets it, does justice to the brand and ensures mazda users get the proper support and service they should get. Most of these agents are just in it for the bucks and doesn't give a darn about after sales services like stocking parts, diagnosing issues properly and fixing them without over charging people.
H3 Bulbs
MotorCade has H3 bulbs in 100w. They had narva and hella last time i was there. no idea about low kelvin fog bulbs
H3 Bulbs
generally, auxiliary lights are wired via a separate relay so it shouldn't be a problem to the power switch. Running high wattage bulbs will obviously put out more heat so there is a chance of light housing, holder getting melted due to excess heat. I've done the same many times but never had any issues. just make sure power wires and light housings are of quality . installing HID's shouldn't be a problem on your plastic lenses but the light will scatter a lot more cos the housings were not designed for HID projection. Aim it low and you can reduce the chances of blinding on coming traffic
