Everything posted by Ripper
- Left Foot Braking... Is It Good?
Temperature Gauge
in my case, it was in fort during rush hour traffic with no chance to park... after the traffic died, and with few mega bottles of water...managed to drive to my office in col 3. Got the new radiator plugged in there. A second DIY and this time i made sure everything was hooked up
Any Motorcycle Fans Here?
IMO...a very very long time provided your engine and air filter is in good shape. I dont bother to replace it unless i'm doing one of those long trips or the bike starts showing signs of the sparky going bad.
Good Mechnical Workshop
I think he meant a Mitsubishi L200 double cab! As jD said, replacing a shock aint a biggie. Most decent garages should be able to handle something like that.
Paint
you do get a heat resistant TOA branded spray cans. I used one recently on an air compressor cylinder head. Paint is holding up despite the block heating up.
Under Compression Engines In Kia/ Hyundai Dieasel Models
suppose we aint getting answers from "Flash_Bang"
Temperature Gauge
once i did a DIY radiator replacement and forgot to connect the radiator fan motor wiring. drove to work and close to the harbor in fort, the car was boiling. noticed the power loss, knocking a little too late. Even when steam was coming from the engine bay, military folks dint allow me to stop the vehicle as this was during the height of war. A gentleman security guard at SLT finally allowed me to park there but it was too late. The moment i shut off the motor, heard a loud "pop" from the engine bay. Radiator top tank was bust. Thankfully, other than a heavily bruised ego and cost for another radiator, no other harm was done! From that day...i always double triple check my DIY work, always ALWAYS glance at all the dash indicators
although mine is mechanical injection and runs fine on normal diesel, used to pump super whenever it was available until the recent price hike! Now pumping super diesel is like pumping petrol
and what's your source for this info?
- Paint
Autolanka New Site 2012
no matter what you do... there will always be new types of trolls, weirdos, whiners etc
the two ends that have those metal balls sorta things attached to the cable Overtime as the cable is used, the two ends will get damaged. The cable will start to unwind and the individual strands tend to break off. Once this happens, your clutch adjustment gets buggered up and wont engage properly.
Temperature Gauge
ECT stands for Engine Coolant Temperature As for mechanics, whatever that goes beyond my repair skills,i take the truck to a guy in Seeduwa. He is good with mechanical, Electrical and AC repairs. One man show so sometimes it takes sometime to get a slot. Most electrical stuff, i do by myself
Temperature Gauge
not always machang. the ECT sensor is your coolant temp sensor. It's wired to the ECU too. Some vehicles have a separate heat sensor that's hooked up to the engine block itself. My ford has a sensor like that. Almost all aftermarket sensors sit on the engine block
How To Clean Alloy Wheels
I spent a few hours with armorall wheel cleaner and 4 wet wheels of my truck yesterday Removed all wheels, pressure washed the rims to get most of the muck out and used the foaming cleaner on em. Followed instructions and left foam for a bit and brushed it off. It did a pretty decent job on more cleaner bits of the wheel but didn't really do much for the inside part of the wheel that had lots more discoloration, deposits etc I used it like 4-5 times on each wheel, used a plastic bristled brush to clean but the more stubborn marking didn't budge. But the outside wheel bits are nice n shiny now IMO, if you're wheels are not so busted up and dirty, armorall wheel cleaner will do a super job. If the wheels have marks and have more stubborn stains etc...this product alone wont cut. You might have to use a steel polish of some sorts with an abrasive pad of sorts... I think next time around, i will use a scouring pad and some brasso!
Temperature Gauge
A good digi gauge will be more accurate IMO Chances are that you're gauge hasn't been wired properly. Fuel tank level shouldn't have anything to do with the functionality of a temp gauge. It's just a heat sensor mounted to the engine and a digi display with a processor for displaying temp. Very simple wiring too, just tap to ACC power, place the sensor on the motor and display on the dash and you're good to go. I would check the wiring first before opting for a manual gauge.
Nissan Alternator
5k is a good price IMHO. I once refurbed a busted alternator at Pala and it was north of 6k if my memory serves me right.
Paint
if you mean "tappet cover" you'd need to use heat resistant paint. Toa has a variant like that and it will hold up against heat while normal spray will chip and flake off. Make sure you clean and prep the surface properly before spraying. Most paint jobs fail due to bad prepping
machang check the two tag ends of the cable and see if it's flaring off. Usually the clutch wont be fully engaged once the cables are stripped. If the two ends are fine, chances are that your clutch might be worn out! As for replacement cable, one from a 250 should cut it. It's just the length that really matters and i doubt there's a big difference between the two models. Chances are, it's the same cable. Last time i bought a clutch cable it was around 2000 bucks. This was a thick cable and one of good quality. This was about a good 3 years ago though.
The Best Roads For Driving
hell yeah. must get two supermotard wheels for me XR.
Place To Buy Electrical Wire
shops in panchi have em!
Tips On Filling Your Vehicle
Obviously you know jack about anything and want to see the worst of everything. Although we do know quite a few of the regulars, all of us fall in line when Peri asks us to do so. Plenty of us have got warnings and even temporary suspension of accounts! Just ask VVTI, Masterdon, Pradfred etc etc You know nothing mate! And it's best to dial down things a bit before making a bigger joker out of yourself.
i dont want to waste my time with you but leave forum moderating to Pericles and Madz. it's not your job to judge what's right and wrong for the forum. By all means do that in your private life. There is a report button appearing under every single post, use it and let the moderators do their job without trying to be drama queen.
dude, there were like 3 or 4 people who got all excited over JD's comment. If you look at those few people, almost of all of em haven't done jack here other than whining and cribbing. All your posts so far have in that category. Mind you JD's reply was not for the OP but for the second guy "Ayad". And he was man enough to take a punch and not get rattled like the girl gang who threw a hissy fit. Also if you think google can give you all the technical info you want, there really wont be any use for forums like these yeah? AL gives a local perspective to many things your google can't really give you. And i dont think i'm alone when i say that we dont need your "Moral Policing" here mate. This place has worked for years and years without that sorta thing. And for your last point. As watchman said, you and your lil gang is new here. This is community that has worked and helped thousands of people when googling had failed. If you think you can just march in and "moral police" us...you're sadly mistaken! In any forum, the pulse lies with members who regularly comment and help people out. Not with fly by night cyber white knights.
- Fixing A After Market Cruise Control Kit
