Ripper
Everything posted by Ripper
  1. Ripper replied to kmcsb's topic in HONDA SRI LANKA
    white smoke is generally steam. can be a case where the head gasket is worn and water is seeping into the combustion chamber from the water jacket.
  2. ahh...good times to me the best ride was through vilpattu jungle and the ride through lahugala. was doing 140+ on the 6th when and the xr maxed out. next trip we'll get them dominator 650's As for responsible driving... we dont speed in built up areas. neither do we speed just for kicks. When the road is clear for few hundred metres ahead with nothing to cross your path...i dont see a problem in going fast. We were on bikes and we all know all too well a knock at those speeds means nothing less than death. Especially in remote areas with little support. We have been doing these bike trips for over 10 years without any major incident. That's a far better track record than most motorists on our roads driving within speed limits and still getting into accidents. So save the preachings.
  3. Out of the three bikes... IMO...the most reliable is the XR. decent grunt and overall a great bike to thump around. Only downside on the XR to me is that the suspension setup is pretty poor for offroad or trail riding. For light trails and road commuting this isn't an issue. I dont know much about the KTM's but for competition and hard trail riding they are supposed to be pretty good. The yammie too is a great bike but if my memory serves me right both the KTM and the WR are two strokes innit? So you'd have lot more power at the top and and less torque at bottom end. Personally i like the power delivery of the XR. Especially if you can hook it up with a pumper carb. The stock XR carb's throttle response is a little lazy but a mikuni pumper should be able to sort that out easily. I'm biased towards the XR As i have been owning one for a good 8 years now I wouldn't worry too much about CDI's. at least not for the XR. you get these popping up on ebay often and they aren't expensive. Also in SL, they fix these nowadays a1. my older mtx200 too has a separate 2t tank setup with a pump. I've always used this setup on that bike and never opted to pour 2t into the tank. for one thing, the bike was originally designed to run in that setup and i did not see any reason to change without seeing any obvious benefits. Also adding 2t to the fuel tank means that oil goes through your carb too. possibly increasing risks of clogs. I have seen people adding 2t to the tank directly to either save up on 2t cost and reduce smoke (which i think is stupid and can make the piston run with less lube) or when their 2t pump is kaput and dont want to bust the moolah to fix it up a2. Top end overhaul mostly applies to two strokes i suppose cos on 4strokes it's not a very common repair. On a two stroke this involves re-boring the block and putting in new pistons, rings etc On a 4 stroke it's pistons plus the valve train depending on what needs replacement. Basically the top end repair of an engine usually means the bits you get above the crank level. piston and up basically Bottom end means whatever that comes below the piston, excluding the piston. generally bottom end repairs are more complicated since the engine cases have to be opened up. local lingo "engine eka palu karanawa" a3. Oil changes depend on style and type of riding you do. Similar to cars. If you ride hard, ride for longer times etc... changes will have to be done a bit more frequently. Duration change from bike to bike too. I'd say for basic commuting sorta thing you should be able to get about 3-5k. Unless of course the oil goes bad for some reason or the manufacturer has recommended shorter intervals Doing flushes dont make sense to me. On my XR, once a year or so, i open up the clutch cover and clean out the oil filter screens placed on the inside of the crank case. Some metal shavings and wear bits tend to get stuck there and even that cant be "flushed" out without opening the case
  4. well i hope the responsible bodies take proper action for these sorta incidents. you can't make any progress without setting standards and upholding them. If PP is guilty of what we all think he is of...there should be some sort of penalty put on him. Or else all of these rules and stuff will become just a bloody joke. Yellow flag is clearly visible as you say...so one can't overtake another. And to add upto that, you can clearly see PP turning to his left without any reason to do so. Except to maybe block ashan and eventually got him to slam into the other chap. anybody know which racing body is in charge of this?
  5. were the marshals properly coordinated? from what i have seen...they rarely are. If the race was under yellow flag and PP made this move.... there is nothing much to argue about
  6. gotta agree with CP here. there was no reason for PP to move to his left like that. the 2nd vid posted by PP camp doesn't show the race line as well as the CSN vid. That track bit can easily accommodate 3 cars and when that's the case, why would PP make that lefty move? Kudos to Ashan for running a clean race. There were many instances during the race he had to backdown to PP so both can run a clean race. It's a shame that this had to end the way it finally did. AS and PP had a good relationship from what i could see in their behaviour at the tracks all these years. It was nice to see talented two young chaps racing well and still being good friends. Completely unnecessary imho. you win some and you loose some. pointless tainting a victory with these sorta moves. PP is a great driver, it's always boat loads of fun to see him in action. This is very disappointing.
  7. a known party had got hurt. broke a leg and was knocked unconscious from what i heard.
  8. Happy Birthday boys!!! Have a great year head!!!
  9. not all subs takes up a lot of space. i'm in the process of hooking up two 8 inch jbl subs to my truck. one sub only require 0.3cubic feet of space in an enclosed box. if you want to have a ported box or a bandpass system is when you need a lot of space. My two subs are going under the two front seats. made the boxes as small as possible and waiting for the wiring kit i got off ebay to arrive to hook everything up DIY
  10. Ace you have any idea what time the races will finish today? or at least what time we can leave the place if needed? I'm in a bit of fix after scheduling a fishing trip early morning tomorrow. gotta be on the boat at 5.30am... Got two invitations from CSN chaps for V*P spots near galadari. debating on going or not going
  11. Pila I posted a query on CSN fb page about the cam thing. turns out the rumour is false. you can bring cameras
  12. with that thing....i bet you can shoot from a few miles away without even ever getting close to the track
  13. well they did a similar number for the worldcup cricket matches. i did see people with dslr's in the stadium but didn't want to risk the hassle of carrying my cam and getting pulled up at the gates. smaller dlsr's might get away but large lenses surely will attract attention. I was thinking of going with my 70-200 but that white lens attracts too much of attention
  14. heard from a source that professional cameras wont be allowed in the viewing areas. anybody know if this is true? Just got my hands on two V*P passes courtesy of CSN
  15. Asian Hardware in panchi/armor street had them for 200 or 250 bucks a pop. this is the one that is white in color once it dries up. I bought it cos it was going inside a sub box and will never be seen
  16. i did my car up there some time back. not happy with the installation work and attention paid to detail.
  17. I too recently did a clutch master pump oil seal replacement at home. hate working with brake oil though For once i agree with Nilantha. Water is the best way forward to clean brake internals. If the surroundings are dirty...it's best to clean all that much up with diesel or something before starting the job. Any hydraulic related repair should be done with max amount of cleanliness. Also make sure the cylinder internals are clean. I had to replace the clutch master pump washer kit within 2 months cos the previous garage guy didn't clean the master cylinder properly. having an air compressor makes the process faster.
  18. windscreen chaps use regular silicone glue...200bucks or so for tube. gives out an ammonia smell as it dries out and this is highly corrosive. It can also damaged other rubber bits if i'm not wrong. was making some sub boxes at home used silicone to seal the inner seams. the ammonia smell took a good 2 days to wear out. Im keeping it open for another few day before dropping the subs in as for color. there are different types. One type completely dries out maintaining some level of flexibility while the other stays a lot more gooey. I have seen the gooey type only in black. the one that hardens up comes in clear and in white. The black one, did not have a harsh ammonia smell if my memory serves me right
  19. gilbert and Pet#o are good places for high end stuff imho. price really depends on the quality you're expecting so best that you go to an audio joint and take a look at what they have. the other two bits can be done at places like sunlanka. also many shops along darley road too have all those bits. I think there is a shop called unique lanka closer to the exit gate of st.Joesph's college in darley road..they too have all those bits
  20. Ripper replied to knightowl's topic in The Lounge
    heh heh... love the humor :) but on a serious note...cycling in SL is not a bad thing at all. I do it myself quite often. Fellow member "Milindu" has a gang of friends who do somewhat serious trips. You just gotta select a good route and have some common sense knowing local conditions As for OP's question frankly i have little clue about gps apps on phones. i cant get my e5 work even in colombo. Is there a possibility of your app not working outside the uk?
  21. Thanks Andy. Finally some info. tad too late for me cos i gave away the two vvip tickets i bought to "carbon b4" Jehan When i called up galadari last evening...they wanted me to be in before 6pm.
  22. yep. i have a truck
  23. i have delicately removed it...only the white paint bits and not the embossed letters themselves. also using tyre black tends to get it out.
  24. i too was planning to take junior. if not for that, it's no big worry about locations and what not... from what i can gather...this peacock fellows are the organizers. the hotel chaps are just using their premises to make a buck and they are just sponsors to the event. peacocks haven't informed the hotel chaps much....not galadari fellow at least cos when i called them last evening...they knew less about the event than what little i knew. I think i'm gonna skip this one...far too many pea-cockups already... I've been to SLARDAR events and the likes...far better organized with far less support and money involved from what i can guess. If you want...you can have the two tickets i bought off anything.lk Opted for the pick-up and pay option so it will get cancelled if i dont pick up within 24hrs.
  25. Ripper replied to The Stig's topic in General
    I have Tuan Ossen's mobile number mate but dont think it's fair for me to share it without his consent. I'd say generally after 9.30am most bike garages are open. On saturdays they tend to work only half day. Closed on sundays.
