Everything posted by Ripper
Import Tax Slashed By 50%
well at least in that article in doesn't say taxes will come down further. just says that car prices would fall even more when more and more new cars come into the market... typical supply vs demand scenario
Honda Cbf 125cc
well that certainly doesn't come any where close to a proper "japanese" honda must be one of those indian junk bikes flame on!
Cavalry Supercross 2010, Rockcity ;)
thanks for the tip DD I bet GrandCivic will be in, DD is running, myself and VVTI will be going there too and hopefully take some pics for all to see... any more AL blokes going??? Sharkster? Devinda?
Ect Sensor
loctite is the just the brand name machang and they make quite a few products including a super glue kinda thing, the more commonly known loctite that make sire bolts dont fall off etc...and i think they also have a kinda anti-seize compound which is good if there's a risk bolts and stuff fusing with the nuts. no pun intended I've used an anti seized compound thing on one of my mo bike exhausts. a tube was supplied by the pipe company to keep screws getting fused to the pipe body especially at higher temps etc...
Ect Sensor
why would you want to use a thread seal in the first place???? have done a similar thing recently and the sensor sealed in properly without the need of any sealants
Subaru 600cc
Hwy Prad looks like the fiat has progressed nicely! metal work all done eh?
1+ i do feel this would be a temp thing to give a boost. once that's achieved it might be taken away.
Help To Buy
pioneer should defa have it. a friend had to get a MAF for his sky and couldn't with the agents and got it off pioneer.
Help To Buy
have you checked with the agents? if not try pioneer motors in panchi... for used ones...most of those breaker yard places should have em for cheaps
Fuel Wastage With Beat Barrel ??
it might do a bit better. also best to get the carb tuned, check the plugs and change if needed, check the air filter, ensure tyre pressure is kept up properly etc... do all the basic stuff and your car should give you it's optimal fuel efficiency as it was designed by it's creators good luck
free flowing pipes are put in for performance boost and that comes at the cost of fuel efficiency. even ad a performance booster...plugging on a free flow pipe alone wont do you much good. the engine would need to breath more easier and would need more fuel to burn and give you that performance you seek. If you like a loud car and think that's cool...by all means...a beat barrel is the way to go. just my 2 cents
more power almost always means it will burn more fuel! you can't eat the cake and have the cake at the same time...
i think you're wrong here the additional "noise" coming out of these "beat" barrels is due to lesser restriction in the exhaust gases and lesser sound dampening when you have free flowing gases from your exhausts it makes for less back pressure for the engine to fire against making the engine loose torque especially at lower rev range. Also when exhausts gases are moving out faster it makes the fuel mixture in the cylinder head leaner! meaning more air...less fuel... so if you have EFI system the sensors will pic this up and pump more fuel to the head to correct the air-fuel ratios... hence burning more fuel. On a carb engine this wont happen but you will end up fouling your plugs faster and running your engine too hot.
Tips On Saving Fuel
also it's best to time your journeys and plan them in such a way that you always have wind behind you
Nissan Primera Tp12
exactly! and this i true to any car...not only CVT's and certainly not only TP12's some people diss this car not knowing a lot about it... lame chaps! maybe they think it's cool to diss certain models
heh heh...you're welcome matey and Shai is a cool chap! looking at some of the other folks here...this guy doesn't have a glass chin and take a few punches so all in good fun mates
Installing And Wiring Led Strips
yeah...that thing looked weird as hell cos he had some bright blue neons and the ground clearance made the whole splash out a lot more. if i see it again with a camera in hand will snap a pic
i don't think its illegal. maybe it went a tad outta control when everybody started using it. even to date there is a canter truck near my place that has underbody neons quite a few tuk tuks too had them so putting those on now would make you look rather lame IMHO
i bet that flew miles over jnr let the boy have his LED's and learn the ropes himself as many have said..SunLanka should be able to sort you out cos i've seen hoards of people coming there to pimp up their cars I would advice not to have too many lights in the cabin cos it might affect your night driving abilities and VVTI...congrats on the 1k post mate been a good run eh
Alarm bells? With the amount man-hug pics you got on your FB profile, you should be happy unless you're a bit jealous ... so don't worry Shai! you're special don't be threatened ok
Engine Performance
that certain Z must've had a bad driver machang
- Engine Performance
Engine Performance
mine idles at 750~1000 depending on how hot she is change to 2nd at 3k and and 2nd to 3rd at 5k(2nd and 3rd have the best acceleration in mine) and the others are also between 3k~5k those days that you don't feel like it or have jnr in the car, i too keep to the left lane and change at 2k ~3k. and those morons who hog the right lane and do 30_40kmh....i hope they rot in hell!
if you need a ride....in a very non-gay straight sense...you're welcome to join us myself and VVTI will be passing that way anyways
cool! i think DD's running too.
