Everything posted by Bugatti
Law On Beat Barrels And Sound Gadgets
Proper branded performance exhausts don't actually make a racket.. it is these after market local industry rubbish that wakes up the dead. I have tested tested the branded stuff for both my Mazda and BMW, and I tell you these are quiet at low revs. So I guess, if you have the real thing, you won't have to worry...
5 Series (E39)
VVTi, bout time you let go of the 3... she's not your anymore.. NEW BEEMER FIVE MEMBER:So you have your self a M52... nice. I believe I have the same engine (in a 3) (pardon my ignorance) in a different time zone with Capt. Morgan in the tummy. One more thing to note is that the E39 has a quite expensive to replace suspension. Oh.. yeah.. forgot to mention, I have VVTi's Ex... a '96 E36 with the M52 B25 VANOS. Have replaced almost all moving parts, to avoid the hassle of being stranded on the road. You think you don't need ASC in SL??? try driving angry in hard rain on a winding road...
Not really... A known person had his car confiscated cos he had a loud Fart Cannon on the car... This guy of course was supposedly driving like a cat with gasoline up the but. Hence the center of attraction on the street. This was a few weeks back. You can manage to avoid the cops, as long as you don't attract attention.
5 Series (E39)
From what I know, BMW uses ZF re-branded.. ZF has it's own branded oil in 1 ltr and 4.5 ltr cans. Almost bought it the last time in BKK. Next time for sure.
5 Series (E39)
Also, If you can dish out some bucks.. check and change to cooling system hoses.. rubber becomes brittle over time if the car hasn't run much. You can save quite a bit on having the car taken on a flat bed.. (if you know what I mean) This happened to me twice, before I changed all the hoses.. Once in awhile, give it a Italian Tune up..
Autolanka Funniest Moments
2500cc... whoa.. power weight.. this thing will rocket...! NOT...!!
Abandoned Cars ?
Can we apply the maritime law here...?? if found on common ground, finders keepers..? just thinking..
Swift Sports Supercharged Conversion
Our very own Peri had one and sold it.. MRM still has his.. I believe.
Express-Way Updates
Double wOw... I would like to get my hands on this..!
- Bmw E 36 325Tds
- Bmw E 36 325Tds
Mine came with the ZL-DE engine (1500ccc) and shares the same block as the ZL-VE which made the upgrade easier. I had to change everything except the block. (Sump, exhaust 4-2-1, entire intake, valves and wire harness etc) Cost me around 150k and took 24 Hrs of work.
- Bmw E 36 325Tds
My suggestion.. drop in a ZL-VE engine.. (SVT) it'll get you 130 bhp. Tried and tested. You can squeeze out more with a customs exhaust and a intake. Well within your budget, and you get to keep the car. Fuel economy will be bout 7-8 km/l and depends on how you drive.
Euro Auto Transmission Repair Place
Why did you need to change the Bell Housing?? 25k seems a very reasonable charge.
The video shows a Supercharged engine and by the looks of it.. it is modification done in Japan.. probably a special domestic edition.. you could clearly see the engine being tested on the dyno. will be cheaper to sell the Indian and buy a Swift Spots..
I did a complete re-build on my ZF auto box... Parts are more freely available compared to any Japanese.. trust me.. I know. I did it at a small garage in Rajagiriya.. got the repair kit from Thailand and some of the parts were stripped off a ZF box. You get the repair kits for each of the bands.. (if you know what I mean) 'O' rings and valve body packing kits too.. Make sure you use the ZF or specified ATF after the build. DO NOT use M*bil on ZF boxes.. (tried and tested and failed)
Express-Way Updates
Back to the topic.. was driving back from Galle on the E01.. doing the average 110 km/h. out of nowhere came a Black Alion, must have been doin well over 150, over took me with no signals.. then pulled up to behind a Prius on the right lane at the same speed... and there was hardly a 10 foot gap between the cars.. To the idiot who drove KN-0260...... be a bit more sensible when driving..
Corrosion
Yes... yes.. Japan cheap because it is Japanese no...?? England is Sudda fellows no..? ok laaa? understand the bus-stand?
Nylon Bushes For Mazda Axela
I guess that 'someone' would have suggested to use Teflon spacers between the strut and body, at the mounting point. Did that 'someone' also tell you that you might have to lengthen your strut to bolt it in place? I have a Mazda, and I lowered it by 2.2 inches.. and that wasn't a difficult mod. Are you driving a car that was modified in Japan? cos the stock Axela has a very good ground clearance.. You've got to be Dork to increase your ride height..
First Fatal Accident On E01
Ya I see airbag is very safe still inside the steering wheel...!
Bmw Automatic Transmission Reliability
Hi, I have an E36 with the ZF 5HP 18. It had clocked 69k miles, when it needed a rebuild. That too I guess cos the ATF had not been changed for awhile, or the first owner had tried some stunt.. I got down the repair kit from Thailand (OEM stuff) which includes all 5 clutches, 'O" rings and packing kit. I also replaced the D-drum and two tension plates. All cost me 55 grand for the parts, and another 30 grand for the oil. Point to note.. use either ZF branded oil, or BMW life time ATF. Stay away from Mobil or any other. Tried and tested.. they don't work. The agents not the other expert will under take to do rebuild.. I got it done by another guys who knows his way around the Germans. Been driving it for almost a year since the repair.. with no issues.. and I do drive hard..
Express-Way Updates
Not really... either stick to the speed limit, or divide the distance by the speed.. Or beg the cop at the exit...
Mixing Two Types Of Transmission Oil
Just my 2 cents.. I've had bad experience by mixing two types of ATF.. issue comes after about an hour of cold start.. the gear shifting ain't smooth and it effects the torque, due to temperature. My auto tranny is a ZF 5HP18 (BMW E36) when I re built my tranny, I used Mobil Synthetic ATF after having a chat with the guy at Mobil. Even though the brand BMW is specified on the bottle, this particular oil didn't suit my tranny. 35k down the drain. I had to use ZF branded ATF. Please ensure to use the ATF specified by your manufacturer. Else, it's a waste of time and money.
Express-Way Updates
Is it gonna be increased by 20 km/h every three months..???! Jst a loud wish..!
