Everything posted by Chris0628
Price Of An Ecu ?
Yup... got them cleaned initially by Zakie also
Price Of An Ecu ?
Yeah... did a injector & throttle body cleaning from P@tStop as well :-) no luck
Price Of An Ecu ?
:-) my ECU is not busted... the reason for the replacement is cos the fuel economy is bad & after getting the car checked by a few Experts (Zakie, Rohan, Upul) and finally the Agent ...the agent said the injector open time is far too much for this model and since the sensors are also working fine, it's a bug in the ECU. As you might know.. the EK3 ECU cannot be re-programmed... hence i'm thinking of replacing & the re-map is to get a bit more power (if possible) and i'm also looking @ getting the K&N air filter fitted as well. Hope this clears things up
K & N Filters
Called Motorcade... they only have the Cone filter... and they dont fit it either..... anyone know where i can get the full job done ?
Spark Plugs
Hi guys.... im thinking of changing the spark plugs... Honda Civic EXi 2000 (D15Z4 Automatic). What brand/model of plugs should i go for ?
Price Of An Ecu ?
Cool.. thanks guys... now the important question :-) cost of the full job (ECU re-map....etc) ... :-) any ideas ?
Price Of An Ecu ?
yeah... will try looking for one also.... but need some help on ECU model & what other details to check
Ek3 Exi Low Fuel Consumption
yeah.. that's what im thinking... i got one contact who has a ECU... stil awaiting a reply from the guy.... anyone else has a compatible ECU for my EK3 ?
K & N Filters
will it give the same effect as the cone ?
K & N Filters
DIY Job ?? :-) i have the stock box type filter... what would you recommend. ? box or cone ?
Price Of An Ecu ?
Thanks for the info.. i'll be awaiting the other info i asked ... :-) anyone else have any suggestions ?
Non Vtec Swaps For D15z4
Not an option @ the moment :-) guess ill keep what i have & do some mods like air filters....etc get @ least a few BHP's more :-) if possible..... thanks for the feedback guys....
K & N Filters
So guys... where can i a K&N air filter fixed .. could someone send me the contact details....
if i remember correct when i called him he said the EK Stock ECU cannot be re-mapped
Mine is a auto.... and the 1ms issue is still there... so im looking @ maybe remapping or replacing the ECU..... do you know where i can get the remapping done ? also cost ? :-)
Did all the tests you & the others suggested... still no luck... lately i have noticed a rough gear change from 1 to 2 & 2 to 1 sometimes..... Rohan said all this fuel efficiency issues might be the gear box all along.... guess i'll go with the Gear box replacement .... anyone else out there got any suggestions ?.....
Price Of An Ecu ?
Hi Guys.... anyone know the Price of an ECU ? New or Used ? Where to get one ? Car is Civic EXi (2000 - D15Z4 Engine Automatic )
yeah... :-) but what i want is to @ least get upto 120BHP's
Cost effective as possible :-)
Ecu Re-program/replace?
Hi Guys, some of you might remember ....I have an Civic 2000 Exi (Automatic with the D15Z4 Engine). Not much power but it's supposed to be very fuel economical. But mine isn't. So i took it to the agent and a few other experts to check what the issue was & finally the agent plugged the Diagnostic Computer & did a full check. They said the Injectors are opened for too long (when idling it should be around 2.7 - 3.1 ms) but mine is around 3.5 - 3.7 ms and there is nothing that they can do.... What are my options ???
Cool....now regarding the cost ...
Hi Guys... i did some research and read that the B18A1 & B18B1 engines are compatible. any feedback & cost ? the articles i found said that most B series engines will be compatible...
so the D16Y4 is possible ? ... any idea abt the cost for the complete job ?
Hi Guys, Just curious to know... which NON V-TEC 1.6 or 1.7 Engines can you swap with the D15Z4 (Civic 2000 EXi 1.5 Auto) engine ?? Also what kind of cost are we looking @ ?
Sound Deadening Material
Hi guys... im sure i called Sunlanka..... this is very strange... maybe they had some customer issues with it :-) anyways.. i will check @ P@T#O Lanka
