Everything posted by KI4120
Become A Honda Owner (pls. Advice)
Bro, VTi is the export VTEC model...here ur refering singapore imports ha ? if that the case Singa imported VTi are the VTEC civics and also non vtec civics also imported from singa and its badged as EXi , jus as in sri lankan EXi models....there was a one RS converted EXi (once was advertised for sale also in Autolanka..bearing some H series number with 1111 on the digits...), with a vtec head, fuel pressure regulator but with the D15Z1 engine block....this D15Z is the engine which doesnt comes with vtec..but obtains a more aggressive cam...with normal cam Lobes...this D15Z comes in the EXi model.....not in the VTi model...if a VTi has this d15Z engine block...either it's being rebadged by a punk ass or a converted to a VTEC...
Ek3 Vs Es8
Well its simply a tip tronic option with higher gear ratios...
Ek3 Vs Es8
LSD doesnt come in handy at all in Sri Lanka....with these whether conditions and road condtions....LSD is useless...but on some occations like roads @ Kandy and some what at Malabe area.. u know elevated road condtions and hill kinda atmosphere....LSD does get better.... it only gives u more grip by converting the torque of the one side driven tire when its on skid or not touching the ground to enable the car to move....
Ek3 Vs Es8
Yep ...obviously yes...it has more aggressive fuel map....
Ek3 Vs Es8
Not all machan...it basically up on buyer's specification....so some came with LSD...even Vi also....but in Europe most Civic Vi and RS came with the LSD....even in JDM market....
Ek3 Vs Es8
to find whether the car has LSD, u will find a sticker tag at the driver's hand door stating "LSD INFORMATION" or else u really gotta drive and see...in a elevated road...
Ek3 Vs Es8
Machan, those specs are can be seen on mostly on USDM and EU models....wot m refering is JDM and Asian Models.....if u can find a good Shop Manual of a EK series u'll defa get a good idea of it....yep... ES3s come with D17A1 , D17A2 , D17B series is for the asian market and JDM also....similarly ES5 came with D16W7 motor which very unique for the asian domestic models...even this engine canot be found in JDM , USDM or EU markets....only appeared in Malaysia, Singapore, Thailand and Philipines only....which is a very unique engine specially developed for Asian country's enviornments....
Ek3 Vs Es8
Machan, but cant say Vi handles as much as ES5 , bcz ES5 comes with front and rear stabilizer bars in stock state where as the Vi never had that option. and also ES5 has ESP also together with EBD where the EK3 Vi or ViRS doesnt. So technically cant agree on that....but how ever i've experienced that Vi is slightly more comfortable with our local roads....over a ES... : ))
Ek3 Vs Es8
Yeah... ViRS comes with LSD ... ES3 (RS of the ES series) and ViRS with D17B comes with the LSD.....also some ViRS including Vi also comes as stock. I've test driven a Vi in SL was belong to a lady - manager @ HSBC wattala...she never knew wot her car had till i got da car in to my hand...it was a 1999 EK3,Vi with LSD and manual tranny. Luckily there are few Vi and ViRS in SL which came with LSD .....
Ek3 Vs Es8
Technically all the Honda EFI engines are PGM-Fi...
Ek3 Vs Es8
SpeedFreak has mentioned all the specs...but one thing...EK3 ViRS comes with a Higher Tuned ECU on the fuel map...as well as if its a Multimatic...it contains two "S" mode options with higher gear ratio outputs... Kaushama, with ur budget u can buy either ES8, ES1 or EK3 Vi or EK3 ViRS...out of these i personally recon u to buy a EK3Vi or ViRS... i personally have used ES1 for happy 3 years time...and it really didnt give any troubles...very good on fuel and as well as built quality and fun to drive. But i was the first owner and i was very carefull with the CVT Gear Box. as a result it never gave me a trouble cz i took care of the gear box and services on pormpt timings.....Then i upgraded my ride to a ES5 on two years ago. its a good ride same as ES1 but with a power full engine and a non CVT gear box.On fuel consumption... Not good as much as the ES1 but easily does more than 10Km/L in urban. Having said above...i have driven EK3 Vi (was belong to EVERGREEN ) lol...) and also ViRS.... but never owned a EK series....but i must say both EK3 Vi and ViRS models are more comfortable than ES Series. EK3 Vi / ViRS motors are D15B engines, are very reliable engines...but on the power train concerns...which means engine technologies and management....ES series engines came with advanced electronics and fuel management systems...such as ES engines came with individual coil packs and also with EPS and also VTEC management is solely on the ECU... But out of these..if u can find a well maintained ViRS having YOM1999 or 2000 , Manual Tranny with LSD...u will never wanna go to a ES or any other car...trust me....jus take ur time to find a good ride...u might come across on the autolanka if ur lucky..... good luck !
Ek3 Vs Es8
Can u pls PM me form where u have collected that info ? thnx...
Ecu Re-program/replace?
I think you have to re write the fuel map in the ECU...that requires ECU re-programming system. Zakie will save ur day...!!! PM me if u need his contact number...
98 Honda Integra
Common fault with VTEC ? hah....sucker..! forget about the car...he aint a Honda Inegra Rider....neither car knowledgable car driver....forget the deal....machan...i really like and very ancious to get to know the current owner of that car and teach him wot really a VTEC could do and how z it spills some oils....
Vw Passat 1.8t
Thnx bro for the info....defa ill PM u...or ill else if u have time v'll meet @ FB...
Accident At Gp
Anxiety....and to see...
Vw Passat 1.8t
Hi Guys Does any one have experience with VW Passat 1.8T , YOM 2000 model ? Wot about this particular model ? is it reliable ? any common issues with the make and model ? Wot about maintenance ? sourcing of spare parts ? Engine management specifications ? guys i look forward your valuable output and to share your knowledge about this specific model... thank you in advance !
Accident At Gp
can any one post some pix ?
Accident At Gp
Yo marla...glad to c u here bro.....i also wanna find out wot happened.....
The Most Reliable Jap Vehicle
Japanese Toyota - best reliable cars came in 1980 to 1995
Difference Between Lancer Ck 2 Mx And Glx
CK2 MX is the JAP Domestic...came with DOHC TRICS (some editions with MIVEC) and with Manual/Tip Tronic/Automatic Trans... and MXE is the Asian Domestic model.... CK2 GLX is the export full option model. But in Indian Made CK2 GLX its the 1.5 DOHC Semi Option model...Hence GLX-i is the Indian fully loaded model.
Waxing/polishing Machine
Wurth Tools @ Nawala
Sound Deadening Material
Isuru, who z dat Vasant ? if u have any details of Vasant..pls share with me or PM me...thnx...
M sure P$TCO lanka has done a good job...cz dey use this Sosche Acumat (refer: http://www.scosche.com/products/sfID1/151/...productID/1042) , and it really works....
What Is The Meaning Of Exi In Civic Models?
Honda made their cars from civic 3rd Gen to 7th Gen as Executive cars...dats y Civic VINs stats with "E" EF, EG,ES series...mainly they have made those VINs to start from E is to give prominance to Executive compact cars... (refer articles @ temple of vtec) but as u said..EX is for EXTRA ..dat expression mainly used in many car makes...like Nissans...Toyota...Honda...Mazda...
