bpcd
1 Follower
  • Interests
    Autos
My Vehicle Details
  • Vehicle Make
    Nissan
bpcd's Achievements
  1. An engine compression test will tell you many things about the mechanical condition of your engine. The test can detect, for example, pressure leaks through rings, cylinders, valves, or a head gasket without taking apart the engine. So you'll save a lot of time and money in diagnostics.
  2. Nissan FB14, Toyota Sprinter AE100 you may consider
  3. March k11 might be a good choice
  4. try with a new battery (temporary) and see if the problem persist. otherwise it might have a ECU malfunction.
  5. check your battery condition, terminals and charging.
  6. it is better to give more details than just giving your trouble. i hope this is Y12 is it cvt or conventional gears?
  7. you do not need special permission or licence to go around with your foreign friends unless you work as a guide.
  8. bpcd
    Toyota Pixis vs Vitz
    there is no doubt Vitz
  9. yes, it is possible to get a driving licence for differently able people first you need to convert your car according to your requirement ( in Sri Lanka there are not much expert to convert vehicle for disabled as in developed countries ) then you register it as a invalid carriage vehicle next is go to Nugegoda and get a medical report from the consultant. ( if you are lucky you will get the report as a eligible to drive a vehicle, I am saying like this because we don't have specially trained medical officers or examiners so even if you can drive properly you may not get the permission due to thinking way of prejudiced) In Sri Lanka society where people with disabilities on the whole are regarded as less capable. so I wish you good luck..!
  10. Don`t worry WagonR is Japanese
  11. It`s looks like you have a rich mixture at idler, turn your idler/air screw clock wise to reduce fuel intakes at idler speed. hope this will help you.
  12. If you like something just go and buy it, nothing to worry about budjet. it might get worse.
  13. Sylvi you keep this forum active
  14. every thing clean and lubricate properly, inside the blead nut housing had lot of rust. normaly mechanics don't clean this they only clean the piston bore and apply grease to the caliper pin.
  15. I gave another try by removing a tini layer from the pads (about half mm) don`t feel any change right side is sticky than left.
