evergreen
Everything posted by evergreen
  1. late registration would always be a puls point in sri lankan market. try to go for a 300 or above.
  2. ae100 would be the best bet after starlet if you are looking at japanese cars.
  3. this is odd !! did you buy the car recently? if yours is manual and you have this switch on the steering, either your tranny has been changed from CVT to manual without changing the steering wheel. or your car could be originally manual tranny and the previous owner has changed the steeering for some reason.
  4. riddle, these aftermarket headlights are availble in sri lanka. i bought a pair for my ae100 2 years ago. i spent only 8k after trading in my originla head lamps t them in kandy. place was charlton motors. but you should remeber that these head lamps are not of very good quality as they tend to discolor after some time. and you should not expect the same build quality like your original factory lights since you may see some gaps in between and head lamp aligning issues after you fix them. or else try fixing a jap used pair from a 110 facelift model but im not sure they are a direct fit for the pre facelift model. hope this helps.
  5. brother i have a good news for you!! go to St. Judes Kandana, they have a L300 nose cut for sale. or try calling them before3 you go. sorry i dont have there number.
  6. usually this after market products tend fail when water goes in. that alarm unit is not expensive. best is to replace and don't let the high pressure apply to the area where its fixed.
  7. you got options!! go to agent and buy. you cn get it fixed too. will cost you around 30k or even more. or else try the famous bodykit guys. they wil fabricate a one at a lesser cost. let me know if you need contacts.
  8. evergreen replied to lasa's topic in The Lounge
    Try Falken. i hav been using them for a year now. pretty muc impressed with handling and comfort being low profile.
  9. i suggest you fix the recon visers. you should be able to find them either in delkanda or negambo/Katunayake area. recently i came across a set of ek sunvisors with clips just for 2500/= gave it to a friend who has a ek Vti since i had the factory fitted ones.
  10. prices seem to be going up for second hand cars. specilly between the 1.0 - 2.0 Million range. on top of that now its even harder to find well mainatined cars. most that is for sale are utter rubbish.
  11. evergreen replied to mosh's topic in General
    get the gear box lower valve body cleaned by the agents and make sure they replace the oil strainer underneath.best is to replace the CVT oil at the same time for better results.this would most likely sort out the issue.
  12. evergreen replied to mosh's topic in General
    have you changed the CVT fluid recently? if not change the fluid immediately. that would sort out your issue.let us know the progress. this jerk is a common issue in multimatic boxes. if the fluid change doesnt work, there are a few more steps you could follow.
  13. evergreen replied to mosh's topic in General
  14. Guys, i'm planning to fix the Vi Rs Lip kit to my 99 civic and heard there are few places around to get the job done. my questions are, 1) are those locally made lip kits exactly similar to the OEM kits/ original factory lip kit (in terms of weight dimensions, Build quality) 2) what is the price range of front and rear set including the fixing? 3) who are the best guys who can do a decent job out of N2o ,Asxnka or any better place u all can suggest? appreciate your inputs.. thanks in advance.
  15. Waja is built on Galant Chassis and a heavy car compared to wira. its got a 1.6 L Mitsu engine. not good on fuel.
  16. No!! all 95 and above super saloons are going above 1.2 Mil. was searching for a one for my frend and got hold to 96 one above 1.2 thats also after searching for days. i know the price is too high but he was on a hurry to own a one.
  17. this has been discussed. please search the forum.Good Luck.
  18. is it a Vi or Mi or Exi? need more information to justify the price mate. looks like an EXI since 1998 and 300 plates.
  19. dont bother about the parts if you are using it for 2 years. there shouldnt be an issue. true that AE 100 has a better second hand market than FB14. but well maintained AE 100 are rare to find these days. you have to do bit of searching around.
  20. i preffer AE 100 since i used it for little more than a year. but if you can spend 1.25 million i suggest you to go for a FB 14 since its a newer model and has ample spares in any corner of the island. AE 100 body parts are not that common compared to FB14 these days,
  21. ya im talking about the same car..didnt know its ownd by Wilxxs Automobiles. :-)
  22. i have seen that too. the ugliest i have ever seen.
  23. no there is a white SiR in kandy. H plates. dont knw the owner.
  24. you must be referring to the white SiR in kandy..
