jdnet
Everything posted by jdnet
  1. The flood water actually helped him keep the engine cool since his radiator leaks all the time.
  2. Oh my god you are so retarded. 1. The IO is not the x-trail's rival. The x-trail is a compact crossover whereas the IO is a mini suv. I hope whatever brain cells you have left will be able to comprehend that fact. 2. How is an x-trails problems related to that of the IO? It's two different companies and two completely different machines. 3. Have you driven or owned an IO or even sat inside one to offer your views on its problems? 4. If the guy had 6 million or so he would be out buying a brand new suv. The fact of the matter is that in this price range this would be one of the few suv's available. Don't worry I don't think people would take your posts seriously anyway. You seem to have gained the status of Autolanka's resident retard.
  3. I wouldn't say that there is a way to identify it early because there really isn't a fix to the problem other than replacing the unit. /the most common signs are; bad pickup, check engine light randomly switches on or stays lit, stalling, rough start. Besides making sure you pump good gas and keep your engine oil clean (it's lubricated with using the engine oil- if your engine oil was that bad you would have bigger things to worry about anyway), there really isn't much you can prevent a bad pump from getting worse.The best way to check the car is to take it in to the dealers and have them scan it and check the fuel pressure. Either way it's just a problem you will just have to forget about until it turns up.
  4. I wouldn't say that there is a way to identify it early because there really isn't a fix to the problem other than replacing the unit. /the most common signs are; bad pickup, check engine light randomly switches on or stays lit, stalling, rough start. Besides making sure you pump good gas and keep your engine oil clean (it's lubricated with using the engine oil- if your engine oil was that bad you would have bigger things to worry about anyway), there really isn't much you can prevent a bad pump from getting worse.The best way to check the car is to take it in to the dealers and have them scan it and check the fuel pressure. Either way it's just a problem you will just have to forget about until it turns up.
  5. screw that. I'm not donating my organs. On my U.S one I put in donor and wrote the specific organ I want to donate on the back of it. My penis. No lie.
  6. Hey sorry I didn't get back to you. Been all over the place the last couple of days. Here's what I have to say to you and I will post it here instead of a PM for future reference. Anyway, like every other car out there, the IO too has one main problem that unique to this car. The problem is with the high pressure fuel pump that runds the direct injection system. There are a few things that would cause it's faliure, such as water, bad fuel etc. and the replacement will cost you around 60,000 for a used unit. If taken care of well and filled up with 95 octane gas it is a fasntastic ride and well worth the price. Other than the fuel pump there are no major issues in the vehicle. If you are looking for a turbo version, which is a bit harder to find, get the car checked by a mechanic. Turbo chargers on any car tend to be abused from what i've seen. As for fuel consumption, I don't drive the IO around too much so I'm not really sure. It does however do a whole lot better than my v6 tribute. Lol. Oh yeah and make sure you check the spark plugs and make sure you have the correct NGK part number. This would give you the best fuel savings. From what I remember I think the non-mitsu packaged NGKs cost like 1200 a plus at dsl. Turboman, did you get your 4wd shifter problem fixed?
  7. as I mentioned before, I'm not having issues with the lighting of the whole thing. The only issue is with the guage needles. I believe that 4 led ones wouldn't solve my problem either.
  8. ahhh google is my friend. This is that it looks like but the bottom is different and the led chip faces upward. http://img.alibaba.com/photo/321073157/LED-with-Error-free-IC-BAS9.jpg
  9. Harshan, I'm not sure which type of LEDs these are but from what ik've been told these are the ones used in the allion and such. They are quite costly at 350 a piece and are pretty bright and the lighting is even, without any birght or dark spots. I will post some pictures when I take the speedometer out again today. The only issue they seem to product is with the actual channeling of light into the needles. If I were to put some sort of reflector to channel the light I worry that it may blobk the light out of other areas. I'm thinking my last option would be to solder a 4 leds and point them directly at the plastic that channels the light to the needles of the four gauges. I was hoping I had some other options as I would hate to mess around with a perfectly good instrument cluster.
  10. Thought this problem would apply to other cars too so I thought I'd post this in the general section. Anyway, my problem arose after I took out the old lights on my speedometer and installed LEDs. Everything worked out fine until I realized the guage needles were not getting any light. I believe this is due to the fact that the LED lighting has a smaller angle than the old lihgt bulbs, therefore the clear plastic that channels the light into the needles is unable to collect enough light. I was wondering if anyone have run across this problem and come up with a solution. Thanks.
  11. this deja vu thing is giving me a headache.
  12. rav4 if you car about kmpl and market value. It looks a lot better too.
  13. It's 93 octane. Whether or not it's worth it depends on what octane level fuel your engine is made for.
  14. sounds like a short somewherein the system. Never install a stereo simply by matching colors as some stereo manufacturers do not stick with the usual color charts. Look in your manual for the new stereo and look for an installation manual online that would explain the scecifics of the colored wires in your original harness. Make sure you match the wires by function rather than color.
  15. It's a chain if you have the following engines Nissan Presea R11 (01/95-08/00) Eng: GA15DE Nissan Presea PR11 (01/95-08/00) Eng: SR18DE
  16. It's a chain if you have the following engines Nissan Presea R11 (01/95-08/00) Eng: GA15DE Nissan Presea PR11 (01/95-08/00) Eng: SR18DE
  17. you would have to be more specific with your question. 3m products can be found just about every where, it all depends on what you need.
  18. huh? I wasn't saying that there wouldn't be damage to your car if the indicator libght turns on. I was saying that the reason for them turning on before you start the car is so you know that the lights are functioning. If you didn't know this and the lights were n ot functioning, when the times comes you would not know that you have a problem until it's too late.
  19. It's threads like these, where people can't understand simple concepts, that make me loose faith in humanity. The reason why those lights come on when your key is in the on position is so that you know that critical indicator lights are working, they go off when you start the car because you don't have a problem and when you do they will turn back on. Is this concept so hard for people to figure out? If the lights didn't turn on in the 'on' position then you would have no way of knowing whether the b ulbs are burnt or not.
  20. Look at the manual and it should say whether it's a chain or belt. Also, wise man says google is the best method for figuring out your problems. I forsee a favourable search result in your future. What is the make and model of the car you are looking at? BTW even chains need to be changed but at a significantly higher milage(something like 300,000 and up). Everything wears down and nothing in the automotive world lasts forever.
  21. jdnet replied to jdnet's topic in MAZDA
    on another note... anyone know where I could find motorcraft spark plugs for the tribute? I've heard that the ford engine does not like champions as much.
  22. jdnet replied to jdnet's topic in MAZDA
    ahhhhhh Just spent 75k on an alternator job thanks to a maka bass the previous owner sent the tribute to. Apparently he though it was a great idea to stick a 80 amp in a car that uses a 120 amp. Ended up with a burnt wiring harness and a destroyed belt. For those of yhou who don't know much about fords, everything is run through the same belt and the alternator is a bitch to get at.
  23. I guess your speaking through experience right? Once again here's another new idiot on this site putting out random sentences of bulls***.
