jdnet
Everything posted by jdnet
  1. @ash and vvti thanks for the info. Will check it out.
  2. Hey guys, I was wondering if any one knows where I can find some jewelers rouge here. Basically it's a block of ferric oxide commonly used by jewellers. I need the red color bar.
  3. 'list member sylvi' Content noted. Do not appologize for same. JDNET
  4. Best place for tint: kleen park (3m stuff) Most affordable: any place on darley road (cheap tint) As for seat covers if you need custom made ones then nawala would be good.
  5. Ah ok I thought the holes were a lot smaller than 20mm..
  6. well then why don't you help the man with his question rather than whine at me?
  7. lol he should get a G grade badge too...
  8. Yeah they do come in useful on trucks. Can't argue with that, but, I've seen quite a few altos with both the sensors and the camera hooked up. Makes me wonder if the driver should even be behind a wheel. OT but do you really need a hole saw? A big bit should work right? the cut won't b e clean since you will be bumping the bit but the sensor should cover it up. Also never used a hole saw so I gotta ask...would a regular drill (regular speed that is) work?
  9. Jeez I told the man where to get it hooked up from. Don't get your panties in a wad.
  10. lol are you going to polish his windows for 15,000 a piece too? On another note. Op should try the places ripper mentioned.
  11. Well I hope you got a boost of atleast 50hp with the nitrogen tires .
  12. Well the best thing would be to learn to reverse a car properly without the aid of cameras and sensors. If you do feel you can't reverse a car using you mirrors then anyone competant at wiring cars should be able to fix it as it's a pretty simple system. Forget the name but that place at the end of darley road where those used bookshops are, should be able to hook it up.
  13. Well you can get a smaller air compressor and an air chuck. If you don't want to invest so much, the staple street food city had those little 12 v compressors that hook up to your lighter port, takes a while to fill it up though and you will need to let it cool down between uses. I think it costlike 1000.
  14. the difference you felt is from the car bieng slightly lighter as the driver was lighter due to less money in his wallet. Seriously there is absolutely no way you would feel a difference in handlig due to a less than 20% change of nitrogen in your tires. Some people say their car drives smoother after they detail or wash it.....
  15. oh look another axio/allion/belta fuel consumption thread. I thought you guys moved on to 50 KMPL hybrids.
  16. List member sylvi, Mistake made about how long this site was opened. Apologize same. My wife's mother's cousin's daugther is a long time member of said association. Not sure anymore because now she is married and has two boys and a girl. Don't know she can keep paying membership fees. jdnet
  17. How dare you insult Mr. Sylvi. He has been on this forum for more than 50 years.
  18. Why would you go to a mazda specific place to get a paint job done? there's plenty of good paint places around that should get the car back to you within a day.
  19. you couldn't get away with your looks?
  20. Wow just looked at wikipedia. That is really interesting. Good find!
  21. green color light appears sometimes? maybe when you pull a certain lever? does the grean light come on together with a yellow light on the outside of the car? Does it blink? You may be low on blinker fluid.....
  22. Cloudiness depends on how well the job was done. If you sand and polish it right you should be fine. While cleaner wax may have worked for you it will not work on a lens that has turned significantly yellow. I do fail to see how cleaner wax could work on a yellowed lens though. Maybe your lights were just dirty.
