mensoft
Everything posted by mensoft
  1. mensoft replied to mensoft's topic in General
    Hi Rumesh88, can u give me a picture . on my engine head cover there is only one hose connected to air filter cover. from that oil spreading to the filter. so at the moment i have removed it from the filter cover .
  2. mensoft replied to mensoft's topic in General
    Hi Can some one tell me where the PCV value located in this engine. (Lancer A72 (Flight Light model))
  3. this guy have done really nice work. I have made few of these with the help of this site . just have a look . its really valuable . http://www.dinumadushan.tk/
  4. Hi sylvi. your correct . i did the job on this weekend . they removed alternator and took of the pulley from the alternator. and did some lathe work to just to remove damage burnt and polish the surface with some sand papers not it looks new . and fixed it the the car and adjust the fan belt tension also properly using some gadget and checked voltage and amp. had to adjust the cut-out coz after made the belt battery was overcharging. now it works fine same day after all had a long drive around 60km at a stretch to down-south was no issue and belt is fine. I'm sure if i tied it to this much early i cant run so far . any way again Thanks all the AL experts for the advice .
  5. 30000 Km. its a dream 4 my belt. Ya ill update the site after i do this repair.
  6. mensoft replied to Uditha88's topic in General
    not sure . probably more than a year . any way now once a year b4 green test I'm changing air filter.
  7. mensoft replied to Uditha88's topic in General
    Guys . Just FYI. Once I failed green test and went to a place to tune the carb to get pass. technician @ the place fixed some gadget to the engine(i think to check RPM) and another to silencer. after inspect for a while he just took off the air filter and and said go for the test now you can pass and change the filter later. it got passed .
  8. Its V Pulley . Even though car is older than me i never put any 3rd party parts on it. and i need to keep the original look as much as i can. and bets are original Mitsuboshi one. but sorry to say i cant run a belt at least 1000Km. . just waiting till this week end to do the repair.
  9. This i got from a mail . might be useful Try this http://www.fileswap.com/dl/5gn2YqzNn/
  10. Generally how long(km or days/months) a fan belt can be used .
  11. Hi Sylvi, Thanks for the info and answers. Can you give the year of manufacture and how many kilometers done. it is 1976.(1st Gen) but i cant remember the exact KMs. When did you overhaul the alternator last. What made you to change the last battery. Never. Its still original . Last battery almost 2.5 years old and charge want stay more than 2 3 days. battery shop check and said plates are now not in a condition to use . First of all get the voltage and amperage tested in your car. by a Electrician, This i did and they said alternator is fine but need rebuild the pulley. (waiting till weekend to do this ) There can be one thing the pulley of alternator is polished, due high kilometers done. YES. I think this is the case. because after start and drive few Km i can stop and start the engine so alternator is working and battery also charging.(day time)
  12. Rumesh88 Thanks for you answer . same question i ask on another thread too i didn't see you answer . My UPS is 650 APC and the battery was on it is 12v 7Ah . I'm not using this as UPS.
  13. Hi Rumesh88 Thanks for your advice and sorry to say i have not seen your reply. Im not getting the mail alert from AL threads. Thats why i have missed your answer. those have marked spam
  14. Hi All , Thanks for the valuable answers. remove battery terminal when engine is running i found it from one of auto related forum while Google. how to check alternator condition. but now i know how serious it is . again Thanks for the explanations. and expecting more advice from expertise. and can i keep battery connected to ups as trickle charger till i get it use in car ? this i asked in some other thread too but still didn't get a answer.
  15. Hi AL Experts , I need your advice again on some electrical issue . but i can't tell exactly this is electrical or mechanical issue . least week i drive may car around 25 km in the night and head lights are on . after next day morning my battery is not charge to start the engine. This battery is not even two months its a brand new battery. so i push the car and start and kept for few min and off the engine and tried to start again and this time its able to crank and start the car. And just to verify the alternator is working fine while engine is ruining i removed the + wire from the battery and engine is running. so i have no doubt about alternator. So i dive the car during the day around 10-12 Km and went to the battery shop to show the battery. during this ride i stop the engine 2 times to visit to some other places and when i went to the battery shop i have drive more than 10km. The issue is in battery shop when they check the battery they said it don't have the correct gravity on the acid and there is some charging issue. i explained them what happens and they check the charging also and while head lights are on and said alternator current is not enough to charge the battery. Next i went to my electrician and explained. he checked all the things and said there is some issue with alternator pulley.(this i can agree because i cant tied my fan belt it get damage) meany times i have changed the belt and Im keeping extra standby. My questions are , 1) if a battery dead and once do a jump start how long engine have to run to get it charge . 2) how the gravity can get high once it go down. ( as electrician explains it have to low charge for one day) how long it will take to run from alternator ? 3) what is low charge? 4) when head lights are on to charge the battery how much voltage should provide from alternator ? 5) what is the correct tension for the fan belt.(guy at spare part shop said when its tied it should have 1inch play up and down freely) I feel its too lose. 6) when my battery goes down can i charge it from a old UPS ? then how long i have to charge it ? My car is Lancer A72 (Flaght light) battry is 12v 45Ah . this week i hope to do the alternator pulley repair and will keep you guys update. Thanks.
  16. Hi , I need a small advice on this . can i use a old ups as a trickle charger ? Does it harm the battary if i use ups to chard the car battary ? Thanks.
  17. Hi , I need a small advice on this . can i use a old ups as a trickle charger ? Does it harm the battary if i use ups to chard the car battary ? Thanks.
  18. Wow ! Great Work . Your car is exactly same looks like my one (Not a wagon). color and the two lines . can i have a very closer picture of the carburetor ? specially the choke linkage and the line diagram ? Again you proved "Old Lancer Never Die !" Good Luck !
  19. Hi Rumesh88, Thanks for your information . the link you have given is really valuable. i must try it and see. but im thinking since i didn't do any timing change can i keep with this current settings or your saying it can be adjust more . also i like "If not you can keep the gear engaged and rock the engine back and forth slowly to move contact points." this i never notice when i had the issue maybe that time i was bit confuse . so i had to get assist from some one to start the engine and look @ the rotators. sometime its not a good method . ill try it on this weekend and keep you guys update . again thaks from your information about timing . also how can i measure 0.5 mm ? is it the same gap we used to adjust spark plug gap ( axo blade ) ?
  20. Hi All , This is same issue related to platinum set i had on last Saturday I'm posting it here rather starting a new thread . to share my experience and get more advice from experts . the issue is suddenly my car engine have got started misfire in the cold start and it get enough of engine miss when accelerating after engine get heated . so i just thought it was some issue with the spark plug and cleaned but still the issue is same . so when i just went to a garage on the way they said its some issue with platinum assessment and need to adjusted but they cat do it @ that time. Fine. now i know where the issue is and then i wanted to try it my self . (i always like to DIY and go to the mechanic after i mes it ) any way i don't want to get tired with the adjustments and i want to the spare part shop with the car itself and ask for the platinum set it is 750/= witch mach to my car model but a Nissan part. and when buy it they ask to better replace condenser as well with platinum set that i got genuine Mitsubishi Cap. (Rs 450/=) . and came home and started my operation i just open the distribute cap and got noted in the paper the way it was. and a photo from my phone for my safe . and removed the platinum set and the condenser and fixed the new parts as same way . but when i start the engine after assembly it didn't start . i tried all what i can do but it want start . and then i removed the wire from 1st plug and hod it keep to near engine and ask assistant to start the engine . (this i have seen @ garage and it must spark when start) but it didn't . after search abut one hour in Google .again i removed the distributor cap and ask to start the car without fixing the cover . but as per the theory i found on the net it must spark the platinum contact when it rotate . but my one didn't. so i start adjust it little by little and start the engine after some point i can see it get spark and the contact points get disconnect. @ this point i close the distribute cap and check the spark wires get current when start. believe me guys engine got start in the first start itself and even i have not plug the first plug wire and i can see spark from the wire end so i ask to stop the engine and fix the plug wire and start again it get start like new. and engine run also very smooth and like earl don't have any miss or difficulty when accelerating . now my question is am i in the correct adjustment of the platinum ? is the issue is common one ? or is necessary to replace platinum set after some mileage ? and in the new platinum set cover they have mention to apply grease on rotating arm where platinum set get touch with this rotating arm after every 2000km. and they have given a small packet of grease . i apply that too . but this have never seen or done in any service ?
  21. Even though Im not much good in ectronic some how i made this found on internet . chan5 have explain it in very nicely now anyone can understand whats the theory behind it . Thanks chan5. any way i think if you use 8 leds will work for 24V. and I have made led bulb for 230v for home use. so it meens 24V led is posible Do google most of the things are possible if you can google :sport-smiley-004: try this http://ledcalculator.net/default.aspx http://www.hebeiltd.com.cn/?p=zz.led.resistor.calculator
  22. mensoft replied to mensoft's topic in General
    I had a same kind of issue in my mmc colt car wich i had early . previous owner have done somthing funny but its work fine . that is aditional switch have fix to the fan to on it after the engine start. but this no need all the time if you have good batary power to start. sometimes its difical to start so i off the fan and start then again on the fan . but its not good at all. meny times i have got stop midle of the road becz i have forgot to on the fan and engine have got overheat . once replase the gasket too then i got fixed it by a electrecian . but then its too late . had to replacse the gasket . so you beter get this fix soon.
  23. mensoft replied to mensoft's topic in General
    if its 700-800 do you think any one will post it in a AL rather than just add it and see?
  24. mensoft replied to mensoft's topic in General
    may be no harm . but product is nearly around RS.4000/= . that's OK if it works as it says. so i just wana know any one used it and how it is ? coz for that amount can do a full oil change.
