Everything posted by Sifaan
Manju Wanniarachchi……….
there was a coffee table book by MAS about the sports people they have nurtured; one of the stories was about a boxer (can't remember the name) who got caught using performance enhancing drugs and he relates how Dian was furious with him for using drugs. However, even if Dian doesn't agree with using drugs, the pressure to produce results may result in some athletes taking the risk... Let's hope the B-sample tests negative.
Nissan Fb 14
but all this is for the diameter of the tyre, which is not (directly) specified... diameter of tyre = 2*(width)*profile% + rim size but width is given in mm and rim in inches so you have to convert: 2*width*profile%/25.4 + rim size far easier to use an online calculator; there are those that show you the speedometer reading variation (recommended to stay < 3%) for new vs. original tyres based on rim/width/profile
Whats The Option
but in the first post the picture shows auto transmission and he says "my car" in that post
3Rd Party Insurance
the purpose of the money-rolling game is not to earn the interest on it. why it's called "rolling" is because you pay the first "borrowing" from another "loan" and so on... if you continually keep 50k rolling, you are 50k richer.
Whats The Option
If it is the Sport mode, and if it is working, then you should notice better pickup and especially on the tachometer you would notice the gear changes will take place at higher RPMs than without. great for overtaking but more noise, vibration, engine wear and fuel consumption
3Rd Party Insurance
the problem you have described seems to be more a problem of the agent and not the company (same agent in a different company could create the same problem). the "endorsements" section on the reverse of the cheque can be made use of to prevent this kind of situation (write the policy number). (I haven't done this for insurance, but I do it for payments to stock broker etc)
Problm With The Battery?
When you try a few times, can you hear the starter motor / engine cracking (but it is not firing), or it is not turning over at all? I don't know about starlets, but this is the kind of symptom I was having indicative of the fuel pump getting ready to die (I could here engine turning but not firing). I think what happens is that it can't provide the rich mixture needed when the engine is cold, but once the engine warms up it's OK. If a "thattu" on the fuel pump (no idea where it is on the starlet) improves matters then it would help figure out if it's the culprit.
Shelby Mustang Cobra In Sri Lanka
no, no... it hasn't been "used". that was a "test drive" to see how it handles, and then after the conversion there will be more test drives to confirm that the handling etc is as good as it was before
Get A 5V Dc Output From A Car
2 amps seems a bit much for a device as small as you describe... I don't know what the rated power for the cig. lighter is - see if you can figure out the fuse that powers it and that should give an indication but often the device power consumptions is much less than the rated output of the adapter so what you really need to ensure is that the actual power consumption is within the limit of the lighter. if you can get a unit you can take apart, you can solder the wires into it, without the additional mucking about with a USB cable. Some car phone chargers will give you 5V, especially if it's a phone that anyway charges off mini/micro USB (such as motorolas, HTC, etc) which will probably be cheaper to get hold of (but will probably be rated for ~600mA only). then you just need to splice the wires
A resistor can bring down the voltage, but the voltage drop across the resistor will depend on the current drawn (i.e. if the current draw changes the voltage drop would change) and this could lead to fluctuations that could fry your unit... besides which the resistor will be dissipating all that power as heat. A resistor / zener diode combo would likely work better (I seem to recall 5.1V Zeners being available) Depending on whether you're trying to wire it in to the dash, or place it in front of the dash, a lighter socket adapter that provides a USB connection (5v) may also work. Then you need to get a USB connector / cable and wire it to the input of your unit.
Peugeot 406 Coupe
Personally I like the look of the facelifted sedan (for better or worse the coupe was not facelifted), but it's one of the more common euro cars on the road today so I don't know if it's "unique" enough for your taste. Of course either the 406 coupe or D9 sedan will stand out against the run of the mill Jap/Indian cars The face-lifted cars got the EW engine series; I'm not sure if the coupe got the engine upgrade or still has the older XU series engine... spec wise there is not a huge difference (EW has incremental gains all round) but I presume that finding parts for the EW will be easier than for the XU (on the basis that there are much more facelifted cars than non-facelifted cars around). Like RangeRover said, Southland is known for high prices; on the other hand, they deal with slow moving luxury cars so they have more money tied down in showroom and therefore their margins need to be higher. If you're heart is set on a coupe it's probably not worth waiting around till a private sellers puts one up for sale For bargaining on the price, you could try saying you can get similar condition 406 2.0 Executive (all the bells and whistles) for ~1.8 and although a coupe is rarer it's also 2-3 years older, and so you are not willing to pay more than 1.8. Have no idea if it will work though, so don't blame me if he throws you out His willingness to bargain may be influenced by how long he's had it sitting there
Peugeot 406 Mechanical Repairs
You're welcome But do send a PM to Harshan (username HarshanSenadhir) who would probably be able to give you advise on dealing with the suspension issue.
A Toyota 121 Accident
let's just hope they build roads better than they build cars... had an opportunity to eyeball the airport highway construction @ wattala recently and even the backhoe operators are chinese... seems the only job for locals is driving the regular road vehicles and directing traffic.
Ae 110
wasn't debating the "logical" (or lack of it) part shall we say "The local price difference between the two models is purely built by our market due to one having the corolla badge, which has little to no logical validity" is it just me, or are corollas just getting uglier at each iteration?
I wasn't sure if I could post this given the "no advertising" policy (which I can't find the text of) but assuming Madz's comment - 4th post here - is still valid it seems OK. Ideal Motors - 2441715 / 0772293457 Indika; in the building next to the petrol shed near roundabout. imports from France through official channels, very helpful, can give you a VAT invoice if you want The following 3 are on Panchi between roundabout and railway station; all will import from Singapore on request (can be useful if your need is urgent). But there are some posts in this forum that some of the stuff in Singapore is not genuine (was in the context of BMW parts; so I don't know if it applies for Pug) Darshan(a) Enterprises (it says Darshan in English, Darshana in sinhalese, go figure) - 2438748; most likely place to have stuff, but can be expensive. Wanted 17000 for my starter motor solenoid (it's a mitsubishi part; the starters are usually made by Mitsu or Valeo) which is totally a ripoff price. he quoted 850 for Wurth coolant green but when I said it was 750 @ Imperial he agreed to match the price! But don't try this trick unless you can actually get it at that price! on the other hand he quoted 7900 for the drive belt tensioner which was cheaper than Ideal... but I got it from ebay UK for 20 pounds plus postage Euro Auto - 2433544 / 075 5076201 (Gamlath) - I "discovered" them recently, so haven't bought anything from them yet Golf Motors - 2438285 / 071 4242486 (Jayantha) - same as Euro Auto Finally, not in Panchi, Imperial Motors - 2679749 / 071 4159654; they've never had any of the parts I've inquired about, but they must have some Pug stuff (Harshan told me about the place). that I don't know... but I can't imagine him spending his time checking prices from 5 different shops (not all of which maybe possible with a phone call) for free.
Ae 110
isn't the corolla badge the reason ?
My 1St Post...:)
LOL... and he can also polish the headlights, er, windshields, for you
95 Octane Fuel For Mitsubishi Gdi Engines?
90 octane has a reputation for being dirtier (more "rodu" etc) than the 95 octane and that's probably why it mucks up the injectors. (using lower octane than recommended does result in poorer performance and enging knocking, but than in itself wouldn't block injectors)
Any Ideas On Pajero Io??
because no manufacturer builds cars thinking about the Sri Lankan market (i.e. the fact that your engine spends so much time idling in traffic and the particle impurities in the fuel) if GDI would sell well in Sri Lanka I'm pretty sure UML would've imported some! when I was looking for a used car few months back even a good friend @ UML advised against GDI (as in, "if you can get the non-GDI version it's better")
There are at least 3 ex/current carmart people doing Peugeot work - Lalith (did you mean to say Pelawatta Battaramulla? If so that's him...), Aruna @ Koswatta, and Rohana. Lalith has done some work (electrical) on my car when it was with previous owner and I'm not at all satisfied with the quality of the work (it looks like the work was done by trial and error, not by schematics) but that doesn't mean he won't do a good job on your suspension. Aruna was recently bashed in a thread (search (for Peugeot Koswatta) and you will find), but Harshan swears by him so I'm willing to give him the benefit of the doubt on some diagnostics/electricals I need done. Rohana came highly recommended by 2 of his clients but afaik he currently works @ Carmart and personally I prefer to avoid such people. Whoever you go with, you will have to get the parts yourself (or it will be cheaper for you to do so). Go register at http://public.servicebox.peugeot.com/ You can enter chassis number and find all the parts and numbers for the car. So when mech. says you have to replace such and such part, from the diagrams you can figure out the exact part (sometimes the official name is different to the locally used name) and the number. There are at least 4 places in Panchi that will do Pug parts, one is very famous but is the most expensive (and his price will depend on the car you have and what you look like!). If you can get parts hand carried from UK then ebay or a dealer is probably (*) going to be cheaper, but of course if it's a very heavy part that will likely not work. (* Probably as in there were some parts that I got for 9k that Mr. Expensive quoted me 27k on; but on the other hand the washer pump was the same price in UK as in one of the other shops in Panchi)
325-**** No
I thought (well, few people told me) that people with almost-english numbers (301- etc) could pay the new plate prices to get an english number and that they got FZ numbers? Intuitively it didn't make sense, but then, the way they managed the switch didn't make sense either (first in not making the reg. class apparent from the number; and also for going for a capacity that's only lasting ~10 years before it will need replacement again)
325-**** No
With the English number system, are 325- numbers still issued?
Nissan Fb 14
fair enough; no offense intended to OP, but I kind of assumed that people with those type of preferences don't drive a FB14
Nissan Fb 14
may i ask why you want to change the size? you'll have to pay to upsize the rims, and you'll have to get lower profile tyres than what you currently use, which will make the ride less comfortable and tyres are more prone to sidewall damage. and unless you're switching from 13" steel rims to 14" alloys, the unsprung weight will also increase. larger rims look nicer, but is it worth all the cost and inconvenience? unless someone is giving you a free set of alloys, or a free set of tyres...
How Can I Find The Oem Dvd Navigation For Pajero Io ??
don't know, but I thought Jap had NTSC so it probably won't work here without some kind of conversion. Was it you who wrote about removing TV antennas from the vehicle (I can't seem to find that post anymore; maybe it was lost in the upgrade) - if so then previous owner must've got it working somehow?
