October 11, 201016 yr Do we have to put only 95 octane fuel for mitsubishi GDI engines??If not what happens??
October 11, 201016 yr yes you should... i pumped 90 by mistake once and i didn't get to travel 1KM before i got check engine light
October 12, 201016 yr Using 90 Octane is not good for the engine..The GDI has a very small nozzle that sprays fuel into the engine combustion chamber, Using lower graded fuel than the recommended would result in the nozzles getting blocked and would reduce overall efficiency. If you have used 90 Octane in a GDI Engine, Suggest you run the tank almost till empty, and then refill with 95 octane + Fuel System Injector cleaner - BG44k or Valvoline . http://www.mitsubishi-motors.com/corporate/about_us/technology/environment/e/gdi.html Cheers!
October 12, 201016 yr Using 90 Octane is not good for the engine..The GDI has a very small nozzle that sprays fuel into the engine combustion chamber, Using lower graded fuel than the recommended would result in the nozzles getting blocked and would reduce overall efficiency. 90 octane has a reputation for being dirtier (more "rodu" etc) than the 95 octane and that's probably why it mucks up the injectors. (using lower octane than recommended does result in poorer performance and enging knocking, but than in itself wouldn't block injectors)
October 13, 201016 yr Author Guys, any idea what the fuel consumption on GDI montero's are in city running? it's 5km per 1liter
October 14, 201016 yr it's 5km per 1liter I've seen the trip computer on a 3.5L V6 GDI indicate 3 Km/L, mind you it was a SWB one too
