Davy
Top Contributors
  1. That's a bit scary. Did the pedal sink to the floor when braking suddenly (possibly activating ABS) or was it a regular press on the pedal? If it was the former, you might want to get your ABS module checked out. It might be a valve stuck open/closed that's causing the issue. It might also be a faulty wheel speed sensor detecting slippage and activating ABS. Note that these are all assumptions. Can you do a test where find an empty road, bring the car upto speed and slam on the brakes to check if ABS kicks in as expected?
  2. Davy replied to vitz's topic in General Automotive
    Hi, as I mentioned above, I'm not sure if UM handles recalls for grey imports (i.e vehicles brought down to SL by other parties). You should be able to call and ask them. Since UM also imports the Eclipse Cross, they should be having necessary equipment to work on the model.
  3. Hi. This topic is over 7 years old. Please check the date before responding to old threads.
  4. Davy replied to TBN86's topic in General
    Did you check if the cooling fans in the engine bay are working when the AC is engaged?
  5. Davy replied to vitz's topic in General Automotive
    Oh right. I thought yours is imported through UM. I'm actually not sure of the process of handling recalls for grey imports in Sri Lanka, but I reckon UM should still be able to find out information about your car using the chassis number.
  6. Davy replied to vitz's topic in General Automotive
    Right. In that case you should probably get it corrected by them before taking delivery of the vehicle IMO. If it's ECU software related the fix could be applied quite easily by connecting the car to their diagnostic equipment. Did you ask about this from them to determine if they are aware of the recall?
  7. Davy replied to vitz's topic in General Automotive
    Out of all agents in Sri Lanka, I think Unit3d M0tors is one of the best when it comes to handling recalls. So yes, they will do it for free if your vehicle is affected. Also, vehicles affected by recalls are because an issue was identified after they've been produced. So if your car hasn't been assembled yet, it wouldn't be affected as the manufacturer would apply the necessary updates from the factory. Nevertheless, once you get the vehicle down, check with the agent. Providing your vehicle's number plate to them is all you have to do and they'll check in their system and let you know.
  8. Davy replied to dilanb's topic in General
    http://lmgtfy.com/?q=toyota+aqua+site%3Aautolanka.com%2Fforums
  9. Davy replied to dilanb's topic in General
    Experts aside, there are plenty of people who can answer your question. It's just that we have answered over and over and over again to n00bs like you who are not willing to spend a minute to search the forum before asking questions the have been discussed before. So before making statements, try searching the forum.
  10. Davy replied to TBN86's topic in General
    If you purchased the car recently, it might be that one of the previous owners replaced the factory Variable Displacement Compressor with a clutch type one? As many Toyotas with VDCs appear to be having issues as their cars age, some of them opt to replacing the VDC with a regular clutch type compressor. If your car now has a clutch type AC compressor, it's normal for it to engage and disengage. But not too frequently. If keeps engaging and disengaging every few seconds, then you need to get a pressure test done to make sure refrigerant level is OK.
  11. I guess police will try to track him down using the bank account information he provided you. But yeah, transferring money to people with whom you've just had a chat with is never a good idea. Something similar happened to a friend of mine many years ago where he had the rental vehicle delivered to his home. He had told the guy over the phone that he is renting the van to go on a 3 day trip to Anuradhapura. Upon his return, his home was totally ransacked in broad daylight. The crooks came in, took their time and had gone through the entire house. When police did their investigation, it was traced back the guy who delivered the van. So either go pick the vehicle yourself (gives you the chance to pay and collect without transferring), and don't reveal too much information about trips you'll be planning on doing in the vehicle.
  12. The term "Made in Japan" only means "Assembled in Japan", and I think most people think "Made in Japan" means that absolutely everything on the car is manufactured in Japan from scratch. Most if not all Japanese car makers actually use parts manufactured outside of Japan (Thailand, Taiwan, South Korea, airbag impact sensor from Sri Lanka apparently etc.) due to lower costs. If you take apart a Japanese car that was assembled in Japan within the past 10 years, you'd notice how many parts have a "Made in <some other country>" printed on them. So this has been happening for quite some time now and is increasing by the day. Gone are the days where "Made in Japan" was an actual thing. So cars that are "Made in Thailand" are just assembled there. Sure, the sheet metal is stamped there, bodywork is completed there, but components like electrics, rubber bits and stuff come from the same set of companies that provide them for cars "made" in Japan.
  13. Oh my bad. I thought it was a registered car.
  14. The best way to check if the mileage is genuine would be to inspect the Emission Test Certificates over the years. This is probably the only document that has a date and mileage where owners don't have a choice but to get one. But yeah, I'd have to agree on all points mentioned by iRage above.
  15. Your clutch could be slipping. What's the mileage of the car?
  16. Davy replied to Jor-el's topic in MITSUBISHI
    Can you please search the forum before posting questions? This has been discussed before. Read this thread. Threads merged.
  17. You need to take the gauge cluster out. Swap it with a working bulb (door indicator for example) temporarily just to check if it's working again. If it is, then buy a new bulb. Bulbs are behind the cluster. Twist and pull. Take the blown bulb as sample. there are several types of bulbs, but my guess is that your new bulb will not come with the holder, so you'll have to carefully remove the old bulb from the holder by undoing the leads that wrap around the holder and install the new bulb the same way.
  18. Are you actually experiencing high fuel consumption or did you just assume because the ECO light is not indicating? If not, it may just be a blown indicator bulb. I don't know Japanese, but Google Translate says that text means "System Setting" in English.
  19. http://www.motortraffic.gov.lk/web/index.php?option=com_content&amp;view=article&amp;id=123&amp;Itemid=149&amp;lang=en Read section 5. For recon vehicles, it's mandatory.
  20. Yeah I got that. Hid it because I felt that post didn't add any value to the (interesting) conversation.
  21. Hi Safwan, Welcome to the forum. This has been discussed many times before. Please search the forum. I have merged your question with an existing thread.
  22. Hi Thilanka, Welcome to the forum. Both cars have been discussed. Please search the forum.
  23. @Thxrindu, please stick to your thread to discuss this instead of creating new ones. Threads merged.
  24. Your car is 18 years old, and with age and use, electrical components wear out and fail. This is normal. The best you can do is preventive maintenance. Not sure about the City, but some manufacturers recommend a 100,000km replacement interval for ignition coils, so check with the agent or a Honda expert to figure out if you should replace the coils. If there's no replacement interval, that means the coils are meant to last the lifetime of the car. So all you can do is replace if and when they fail. Some ignition coils swell up when they near their lifetime, so a visual inspection might help as well. "Will this happen again?" is something no one can answer. The brand new coil that you got can be defective. And a high mileage recon coil can last the lifetime of the car. This is the case with any electrical component. This is assuming that the coil failed due to a wiring issue on the car. PS: You really need to use meaningful topic titles." Engine Problem" is very vague and will not help anyone searching for a problem like this in the future. Please be mindful when naming topics. And use search tags. I've changed the title and added tags for you. In this thread and the other one you've just created.
  25. Please search the forum. These cars have been discussed in detsil and compared before.
