Need to buy Special Plate Holders / Frames with Dealer Name
I'm going to add these to the list just to give him the benefit of the doubt: 4. That you are a student/researcher and studying the quality and/or other properties of the number plate frames. The deadline is close, hence the urgency. 5. That you are an entrepreneur and you are trying to develop the best number plate frame. And to do this you need to know the drawbacks of existing ones.
Fuel consumption
Yeah. The intake manifold is different in a GDI. It's not that GDI is unreliable. The low quality fuel in Sri Lanka causes the GDI fuel pump to fail prematurely. The rest of the engine is similar to the EFI counterpart. In Sri Lanka, where Priuses have diesel number plates, anything is possible. So I wouldn't be surprised if there's no mention of an engine swap in the CR. 7km/l is on the lower end, but isn't impossible given the right (or wrong) conditions.
License Plate Frame And Sticker; Help Please
Wurth
Fuel consumption
Yes, the original car would have definitely had a 1.3L 4G13 engine. Somewhere down the line, someone has changed it to a 1.5L 4G15. If OP searched the forums before buying the car, he would have not fallen for it. Having said that, there's nothing wrong with the car having the current engine. If the job was done properly, it's actually better because the new engine is of higher capacity than the original and doesn't suffer from the lack of pulling power the CS1 has. It's just that the seller should have mentioned that the car has a different engine.
Fuel consumption
That's right. But then again god knows what's the actual mileage of the engine that's already on the car. As for the fuel efficiency, about 8 km/l is average in traffic for an automatic CS2 (Can't call it a CS1 anymore ). It varies a lot based on how heavy-footed you are as well. Do a proper full tank to full tank measurement and see if it's still in the lower end. Since several tune ups and services have been done, I suggest doing a compression test to make sure the engine isn't too worn out. This is because the history of the engine is unknown. Were the injectors cleaned during the tune-up? Was a diagnostic scan done to make sure everything is okay?
Fuel consumption
Yes. Definitely not the original engine. Yes, you're right. Just wanted the chassis number because the CC was on the registration doc and I didn't see the chassis number on it at first glance.
Fuel consumption
No the chassis number. It says JMYSRCS1A. And the registration says 1468cc which is the displacement for a 4G15 engine.
- Fuel consumption
Fuel consumption
Again... I don't think you understood my response above. If the car is a CS1, then it has a 1.3L engine (unless someone took out the original 4G13 and dropped in a 4G15 engine).
Isuzu elf 150 1993 make
Dear Paul, Welcome to the forum. We seem to be having a similar thread on the forum, with no responses yet (see link below). The thread however, talks about "KSW holes" at the back of the gauge cluster. So I'm guessing you need to set a jumper or something to reset the light and it's behind the gauge cluster. Here's the thread Is this the same gauge cluster you have on your ELF? If not, can you share a photo of the reverse side of it?
Warning Light On The Dash Board
I thought it was an warning indicator because a photo of the image was not shared initially and the problem was described as an "Indicator". As soon as I saw the photos that were shared, it was clear that it's not a warning indicator but a label on the face of the gauge.
Coolant temperature sensor
The starter motor is not affected, so it will crank the engine as normal.
That looks nothing like a warning/error indicator IMO. Probably just a label printed on the meter face and the backlight is shining through the letters?
That's strange. So it's just a printed label and not an indicator? I'm confused.
Yes. Among many other possible causes. One of the inputs to the ECU to determine the proper air to fuel mixture is the ECT (Engine Coolant Temperature) sensor reading. Bad sensor means inaccurate values. This means the proper air to fuel mixture doesn't reach the cylinders. The car might not start due to this. Get the ECT sensor tested.
If the indicator is green in colour, it's probably not a warning or an error. But best get a diagnostic scan done anyway to see if three are error codes in the ECU.
Automobile Engineering
With all due respect, I disagree. You don't need all that if you're planning to start with a simple diploma first and then move on from there while working. We've got to work with what we have here, so I don't think Vihan should be discouraged just because he hasn't done maths for A/L. There are many options locally now. Government and private. See the links links and places shared by others above. http://www.icbt.lk/icbt/landpage/ ICBT HND in Automotive Engineering
O/D Light blinking continuously
Flashing OD Off indicator usual means an issue in your transmission. Get a diagnostic scan done and that will reveal what the issue is. Make sure you get it done at a good place or the agent.
Isn't this your uncle's Vitz you got a couple of weeks ago? Take the car to Toyota Lanka and get a diagnostic scan done.
Buying A Lancer EX GLX
Compare the price with other Lancer EXs on local classifieds and autolanka.com. Get an idea of the average price of the car and compare against them. At the end of the day, each used car and it's history is different. So the price is what the buyer and the seller agree upon. Also keep in mind that 50K mileage doesn't mean anything in Sri Lanka unless it can be proven through maintenance records (emission testing certificates done each year). Also the "lady driven" and "doctor owned" labels are just meaningless marketing. So they shouldn't be taken too seriously. The EX has been discussed before in the forum. So if you have any questions about the car, please search the forum.
Installation of the Bird's eye view for Toyota Axio 2015
Agreed. These bird's eye view systems are essentially 4 wide angle cameras, one installed on each side of the car, and a control module that processes the video signal. The control module outputs a panoramic view of the 4 video feeds by merging them together. I believe the system needs to be calibrated after installation so that the control module knows where the cameras are positioned. Other than the fact that there's a lot more wiring involved, calibration I think is the difficult part. The rest should be straightforward. An important thing to note is that most of the systems I've seen online don't have a monitor. So it plugs to an existing head unit/screen on the car. They are aftermarket systems and can be installed on any car. Like I've said above, it's highly unlikely that the camera system will come with a head unit.
Perodua BEZZA
- Fuel consumption
Good observation. I totally missed that. @Aj lancer, If your car has a 1.5L engine, it has to be a CS2. Also, if this is a pre-facelift CS, it can even be a GDI. So which one is it? 1.3L = CS1 1.5L = CS2 1.6L = CS3 Also, full tank to full tank method is to: 1. Fill up (full tank) 2. Reset trip meter 3. Drive (at least until the fuel gauge reaches half mark) 4. Fill up (full tank). 5. Fuel consumption = Trip computer reading / litres filled up in step 4 You need to perform this several times and average out the results in step 5 to get an accurate measurement.- ## Post Whoring - Part 3 ##
- Fuel consumption
How did you measure fuel consumption? Did you do a full tank to full tank method? Also, is this a manual or an automatic? If you're a heavy footed driver, 7km/l is quite normal. Especially if you're constantly driving in city traffic. If you don't have proof (service records) of the timing belt being changed, I just wouldn't risk it. Get it changed if you're not sure. Since you've already driven the car for one year, even if the belt was replaced just before you purchased the car, it wouldn't look brand new anymore. So no, there's no way to tell. - Fuel consumption
