Buying a new smartphone
The fact that iPhone 7 has a single shared port for charging + headphones is a massive no-go for me. For a music lover who wouldn't opt for wireless audio, this would matter a lot. As for the risk of shattering glass panels, you can use a tempered glass screen/back panel protector. I'm on my second tempered glass screen protector after it was dropped pretty hard once. The glass screen protector absorbed the shock and shattered leaving the screen intact. My wife's phone (OnePlus X) has a glass at the back too and has two ultra thin tempered glass protectors that have been doing the job for over 2 years now. It doesn't ruin the look of the phone as well. Just my two cents.
Painting Roof Wings Using Chrome Paint
The ones we get locally (specifically TOA) is only slightly different from regular silver. In other words, they're not even close to "mirror chrome". This is just my experience. Maybe there are better chrome aerosols out there, but I highly doubt it.
Formula 1 - 2017
Lewis Hamilton wins Chinese Grand Prix 2017. A superb battle between RedBull and Ferrari for second and third places. Race highlights below:
What suits my need
Congratulations! Appears to be a well maintained one.
Happy New Year !!!
Subha aluth avuruddak wewaa to all members!
- Car won't go over 4000 rpm
16'' Wheels for Swift zc11s
A simple Google search says that the Swift Sport wheels are 17" and not 16" as you've mentioned in your original post. Size: 17" Width: 6" (AKA 6J) Offset: +45 Source: https://www.wheel-size.com/size/suzuki/swift/2007/#trim-16i-sport-eudm
Honda Vezel RS - Reverse Tilt Mirrors
Already discussed. Please search the forum before posting new threads.
The Swift Sport doesn't have flared wheel arches, so the 16" wheels would sit fine provided that your width and offset is within given tolerances. If I were you, I'd try to find a set of wheels that have the exact width and offset of the Swift Sport wheels. This means you can use the tyre size that comes with the Swift Sport. As a result, you will not have any issues with speedometer and odometer readings.
2000 March K11 doesn't Accelerate :(
Welcome to the forum! What's the mileage of the car in question? And how long ago did you get an ATF change done and a tune-up done?
Formula 1 - 2017
No worries @MADZ. Yes, I squeezed myself in near the finish line to watch the end of the race.
Services should be Provided by Fuel Stations
Buckets (plural). In case you haven't seen them, here's an example: http://www.imgrum.org/media/1100350149450090983_308480337 As to whether it will be adequate, the idea behind having sand or fire extinguishers is to stop a fire as soon as it has just erupted. if it has spread beyond control, not even the fire department will be able to stop it in time, let alone a couple of sand buckets or a fire extinguisher.
Interesting. So the regulations are there, but not enforced or the fuel station owners (being politicians and goons) operate above the law as usual. That's disappointing. It also looks like the regulations are not up to date. I mean "sand buckets" - really? What is this the 60s? I do remember that there used to be red buckets labelled "sand" (in Sinhala) at fuel stations. Surely they would have changed to fire extinguishers now.
I don't think we can expect "value added services" from local fuel stations that don't even do their primary function properly - delivering quality fuel to vehicles. However, I think most if not all Laugfs fuel stations have air free of charge. I know that some new Ceypetco stations have them, but not all. I guess it depends on the size of the establishment as well. But again, they fail over time and never get repaired. I doubt there are regulations around services fuel stations should adhere to. So as the popular saying goes... හුළං නොමිළේ මුහුදු වෙරලේ
Painting and repair
Welcome! Search the forum please. These places have been discussed before.
Formula 1 - 2017
Here's a compilation of some clips I managed to capture at the 2017 Australian Grand Prix. This was on race day - March 26th. Crank up that volume and watch. Although Hamilton started at pole position, his pitting strategy put him behind Vettel. Highlights below:
- Engine Swap - Volvo S40 Turbo Diesel YOM-2000 (Project Volley - Volley the Naughty Forty)
Nissan TIIDA High fuel Consumption
If the ECU wasn't reset after replacing the MAF sensor, you can manually reset it yourself by disconnecting the negative battery cable, switching on the headlights to drain the capacitors, and leaving it for about 15 minutes and and plugging the battery back in. At this point I think you're better off taking the car to the agent to have them check it out.
Mitsubishi Lancer RalliArt
Thanks machan! Appreciate it. Yes, the RalliArt is AWD and has Mitsubishi's All Wheel Control (AWC) and Active Center Differential (ACD) systems which allow you to select the surface you are driving on (tarmac, gravel or snow) and it electronically adjusts the power distribution based on which mode you're on. The only thing that the RalliArt lacks is Active Yaw Control (AYC) that the Evo has. I have no immediate plans of bumping up the power, mainly because I'm happy the way things are for now and because my wife drives it frequently. If I ever do, I'll probably go for an upgrade kit. Whatever I do, I will keep this thread posted.
- 108 replies
- 1
- cy4a
- twin clutch
- cy
- sst
Agreed. That's actually why I got one. But does a professional scan cost much these days in SL? It was only a couple of hundred rupees back in 2011. I use a D900 for personal use here. Only had to use it once on a friend's car. Got it off eBay and pretty good IMO.
I have a ELM327 OBD Bluetooth scanner and it never worked with my CS3. Tried Torque and Scanator Android apps but later found that the protocols are incompatible. You can search the forum in the DIY section and find a thread by Crosswind. It worked on a Toyota Belta though. It does give all the information, but just the readings. What I highlighted in my previous post is the fact that a good scanner can show if the readings are off and by how much.
Depends on the scanner used. Most industrial scanners allow for the selection of a make, model and year and sometimes additional information like the engine model. Based on the information provided, the scanner outputs and highlights values that are out of range. This is why some scans are better done at the agents. They have model specific diagnostic tools that indicate when a certain reading is off the scale. This a photo I took back in 2011 at my mechanic's place just before I was about to go for an emissions test. As you can see, the O2 sensor value is highlighted in yellow to indicate a marginal issue in the readings. Also the air temperature is highlighted in red. Both indicate potential issues, none of them output a Check Engine light. The values on the right within square brackets is the normal min and max range for the selected vehicle. Cleaning the O2 sensor connector solved the issue. The reason for the high air temp was a faulty AC fan. So a scan can give out a lot of information if done with the proper tools/scanner by a proper mechanic.
Toyota AXIO X LIMITED
Can you please stop opening multiple threads about this and ask these questions in one thread?
Mithsubishi Evo X
First of all, it's "MITSUBISHI". Like iRage said, if all you care about the Evo is the fuel consumption, I'm afraid it's not the car for you. Performance and fuel consumption are two things that do not go hand in hand. And no, there is no better Lancer than the Evolution X and there never will be IMO, now that Mitsubishi axed the Evo. If you'd like to know more about the Evolution X, search the forum and do some research online.
Could be due to many reasons IMO. But some of them are: - Blocked exhaust - specifically the catalytic converter. You will need take the catalytic converter out to inspect if this is the issue. - Throttle body issue. The butterfly valve doesn't open fully due to a mechanical fault - Leaking high tension leads (plug wires) causing a cylinder to not get a spark as you rev up - Insufficient fuel pressure (could be due to a bad fuel pump or clogged filter) - The factory fitted rev limiter in your car is faulty (it should not restrict revs while in gear) Get the exhaust checked out first. Inspect your high tension leads and then get the EFI system cleaned and a diagnostic scan done.
