devindarocks
Everything posted by devindarocks
Panda crossed.............?
Advantages Of R-12 Gas In Your Car A/c System
devindarocks replied to devindarocks's topic in General Automotive
1Kg refill of R-12 gas costs around Rs.1,400/- freely available at a shop in kandy town. its a Chinese made -
Not the original AC, installed in here by A*W or a local shop -
Total nearly 30K Rs. 10k for compressor -
Guys, This is a small experiment that my cousin has done to his clients cars AC to get efficient results. It was a maruti 800, and was the owner was dying without AC, compressor was worn out, cooler was almost blocked, gas was nil. The cars AC system was designed like a mess. Except AC compressor and condenser all other parts are R-134 Gas parts. And was filled with R-134 gas too. Owner said it was cooling when he brought the car like one year ago and exact two weeks ago cooling stopped. Gas leak was due to leak from the pipe line to compressor After 2 days work managed to repair the unit (Compressor, cooler, ) replaced the drier(R-134), some pipes, and valves. And filled with R-134 gas. And got no result, system not cooling….! Re flushed the system, change the valves, replace the drier again and filled R-134. And the car was cooling in the morning hours and during hot time in the noon no cool at all, Now it took 4 day, having no option my brother proposed to change the system to R-12 Gas. And replaced the drier and pipes, valves accordingly. And filled with R-12 Gas, oh my god… car AC was Chilling…….!!!!! Temperature dropped in the cabin to 9c …….! Unfortunately after about one week compressor was making a noise, and its clutch was failing some times. After full two weeks it is not cooling. So we are now at the same bad position again. Now we have to replace the compressor and couldn’t find a R-12 compressor, only found a R-134 compressor (screw type) from a buddy van, it was fixed and filled with R-134 Gas after flushing system and changing pipes and valves. Result was again no cool at all….! And again we compelled to change the gas to R-12, over the R-134 Compressor with a R-12 condenser & cooler with other parts changed like pipes and valves changed again to R-12. and car was freezing inside after completion. Temperature dropped further to 7c in the morning and 12c in the noon. Now after like 3 months the owner says no change in the cool it is still cooling to 12c in the noon……..! Is it bad for the car AC system to run like this, does it affect the parts like compressor ?
Professional Only if "Chaminda aiya" does things,............. Try ISJ auto, Gampola He only takes one vehicle at a time for painting work, so we get full attention to our cars.........
Contact Breaker Gap For Maruti 800
devindarocks replied to devindarocks's topic in DIY (Do-It-Yourself)
Thanks bro, at 0.4mm situation is same, checked the plug wires as well. so kept the gap for 0.5mm, now things are ok seems............ -
Guys, any one of you know what is the Contact Breaker Gap for maruti 800 i had my distributor repaired today and the engin giving a miss....
sun L****A do have 3M tints, iv got my front windscreen done from kandy. Rs. 7000, results are good.
Try Sun L***A,
Guys, im looking for a good Bodykit manufacturer around kandy to custom build my bumpers. Know any?
Try Ebay. i orderd a four sensor set for $14. working properly so far, no complains..............
- 8 replies
- car reverse
- sensor
(and 1 more)
Thanks machan, Can u tell me where about mavilmada he lives? or any contact no?
- 97 replies
Nice work................really a beauty... This is my A72 http://imageshack.us/g/859/dsc001
- 97 replies
- 1
Guys, Pls let me know if any one of you know a good bodykit designer in kandy.... i need to design a front and rear bumpers set.... Thanks
where do u live, kandy, colombo?
consider 1.5mn after new tax increase....
contact isuru @ gampola 0777-298-298 he is an expert for your car.... (by the way u'l be amazed by seeing his trad sunny beauty.......)
For the people in kandy, u all can contact isuru on 0777-298298, he is a carb expert....
Contact "isuru" @ Gampola kandy. 0777-298298
well for the information i will share this, for all the guys in kandy i had my honda tuned by "Isuru" in gampola. it was a great job and im fully satisfied. after service is superb. il give his contact number 0777-298298. cheers....
plated using gold from dalada maligawe roof........!!!!!!!!!!!!!!!!
count me in, i need one toooo.
