Everything posted by The Stig
Autolanka Funniest Moments
Madz, register for a google my business page (https://www.google.com/business/). They will send you a letter with a verification code and then you can control all the information shown in that preview pane. Its good for SEO also.
Engine Knock when accelarating- Nissan Wingroad QG15
There could be multiple causes but these are the ones i would check out first; First try pumping 95 oct and see the results, if the knock is gone its most likely carbon deposits. Overtime carbon deposits settle inside the cylinders so that causes the compression ratio of the engine to go up. When compression goes up detonation happens causing knock. if this is the case use a fuel system cleaner like wurth or 3m and see results. Also could be a problem with the ignition system components also. GQ15 has individual coil packs and one of your coils maybe weak, under load it may not be able to give proper current. Also check the state of the spark plugs and change them if needed. Sometime the spark plug gaps are incorrectly set by our so called tuning experts, check the manual and get the gap corrected accordingly.
KDH Petrol vs Diesel
Not exactly related to fuel consumption but you have to pump super diesel to these from my experience. We have 2 office vans used for promotions and our guys had no clue what to pump at first. When they used normal diesel both of them stared smoking so bad that we got complains to our corporate lines about the vans leaving a mini smog behind. I think they do dpf cleaning more frequently when using normal diesel.
- Toyota aqua power side mirror problem
The Mazda Demio Thread
If he doesn't know if the car is cvt or not he probably hasn't changed Atf throughout his ownership anyways, if it was upto me I would avoid this car. In fact avoid any car sold by someone who doesn't know what's in his car.
Throttle Prob !
Agree with above responses. I had the same issue since I bought the car, the throttle position was jumping. And never bothered to fix it until it became a nuisance. Just a diy weekend job really. What I did was first clean the throttle body butterfly valve with some intake cleaner cause that had some gunk causing the throttle to stick. Then I noticed that there is some sand stuck in the throttle return spring so cleaned that and put some 3m lubrication spray on it (wd40 substitute from 3m). Then sprayed some lube spray into the throttle cable and finally sprayed some oil into the throttle pedal springs.
- Post Whoring - Part 2
Cheap car engine swap
I think he gets the point Now can someone actually recommend this poor soul an engine
- Tyre Prices
That's does not look like the tire is disintegrating. You car has alignment issues, or tires are under inflated. When was the last time you checked wheel alignment?- Best used vehicle for 5.5 - 6 million in 2017 ?
They had massive issues and some even failed within the warranty period. Yeap http://performancedrive.com.au/audi-ends-multitronic-cvt-transmission-report-2415/ Actually the audi cvt wasn't technically similar to Jap cvts. They had complains from customer on how boring their cars were to drive so they got rid of the infinite gear ratios and moved to a stepped ratio in later models. Basically it was a cvt that worked like a 7 speed auto. I don't think there would be much economic benefit lost because of this.- Best used vehicle for 5.5 - 6 million in 2017 ?
They were on the b7 multitronics. Hard to say if the issue is there in b8 since most of the local cars are nearing that mileage. Find a Quattro if you can, they came with s-tronic (dct) boxes. B9 is from 2015 onwards, they skipped cvt all together and fitted dual clutch as standard. Get an indication from senok on the gearbox situation.- Mitsubishi is going to kill their Lancer line in August 2017?
- Suzuki Swift(2007/2008) vs Mazda Demio(2008/2009) and steering rack issues
Solution is simple. Call asiri/rainbow and check the price from them. Avoid Lalith unless you have a mazda specific issue, any grease monkey can change the steering rack of a car. Other than diagnostics and atf changes mazna should be avoided, you can get the same work done for half the cost if you did your research.- Best used vehicle for 5.5 - 6 million in 2017 ?
Decent B8s are in the lower 7 mil range. You can get a higher mileage one for your budget though. I think Audi fixed the multitronic issues in this generation but 60k ish is when previous generations started getting trouble, better get the car checked from senok before anything.- Heating signals appears
Excuse me miss, can you lift your skirt up when you are in my car- Honda civic ES max speed
- can't speed the vehicle.
- 2016/2017 Toyota Allion Vs Premio
Wow and apparently "The two models has come with significant design as well as technological improvements. " Redi mudalali's neighbours will surely be impressed.- Happy New Year 2017!!!
- Suzuki Swift 2008 Gear box malfunction
That explains it. However I have a colleague who has recently changed his Atf to dextron III on his bj3p. Seems to be okay for now but I did notice that my cars gearshifting is much smoother and up shifts much faster. There is some delay between 1st to 2nd and 2nd to 3rd, as in it gets out of gear but the next gear takes bit if time to engage resulting in the engine rpm going up. Can't tell for sure if Atf is the cause though.- Vitz Cvt Issue
Nope, what will cause wear is abusing the gearbox and improper maintenance. Staying in traffic for long periods is not only a Sri Lankan problem, be rest assured that manufacturers would have thought about this simple problem. As for kangaroo cab issue I am not an expert on cvts nor do I like them, so haven't really bothered to do any research. But AFAIK cvt gearboxes seem to be failing at much lower mileages than traditional autos.- Suzuki Swift 2008 Gear box malfunction
How much did you guys spend so far? You can get a decent 2nd hand gearbox for around 40k- Vitz Cvt Issue
Huh????? Cvt has a torque convertor like a normal AT.- Post Whoring - Part 2
- Tyre Prices
