Everything posted by The Stig
- Conversions for STI 11
Japanese Car News
Close enough
Buying First Car
Country of origin is not the same as country of manufacturing.
Kenwood Car Audio - Bluetooth Set Up
Well the scientific way is to first take it out of the dash. Then take to your nearest library, the close proximity will make it get bored of books and it will stop reading. But seriously, first disconnect the cars battery terminal or force factory reset from the menu. Failing which take it to Pet#o, they are the kenwood agents.
Japan car DVD setup unlocking through Erc
- Engine tune up cost
What the heck is a "popping noise"- Nissan Serena c23 auto gearbox problem
Sound like the problem is with shift selonoids, in any case better get it checked out. Most of us here would recommend Nilwala motors in madiwela.- Bluebird sylphy
A g11 will do 11-14? Maybe downhill with the engine off- ## Post Whoring - Part 3 ##
- Toyota corolla diagnostic
Well cant really guarantee that any scanner would work since i have no experience with your car. But these are good according to others (i did some research previously when i wanted to purchase one) i ended up buying this (still on the way); Again no guarantees, buy at your own risk- Toyota corolla diagnostic
What is the model of this corolla? First of all obd 2 is a standard ecu operation protocol and not just a plug. Your cars ecu has to support the protocol. If your car doesn't have an obd 2 plug that means native support is limited. However it is still possible to get codes though it can't be guaranteed. Your car also has to support the obd protocols supported by the elm 327 adapter. They have the most common like iso 9142 and j1850 but if your cars protocol is different then there is no use. Your get what you pay for with these cheap elm adapters. A decidacted good quality handheld scan tool however will work since they support most of the obd protocols even with convertor cables. A good way to check before buying a scanner is to get the car scanned from a place and see if their scanner is able to communicate with your car. Also most of these cables don't work because the output pins in each car model even from the same manufacturer is different due to age, model difference, region etc. This is why when you plug in a hand held scanner it asks for your cars make model and year, so that it can recognize the signal lines. This is one reason why obd 2 plug was implemented, to standardise the output pinout. I bought a similar cable for my bj since it's a Jdm and doesn't have the obd plug, but it did not work straight away. What I did was to rewire the connectors based on information from others who have done the same and it worked to a certain extent.- Engine starts but stops immediately after tune up
- Looking to buy a car between 2.5 to 3.0 mn
Hope he doesn't forget to check blinker fluids and Flux capacitor charge. For something basic like cleaning iacv, EGR, throttle body cleanup, spark plug check, and injector cleaning it would cost around 3000-4500 ish depending on the amount of work that needs to be done. But if you replace any parts like spark plugs that will cost extra.- Help With My New Cs3
Guys i went to see another cs today, from the looks of it its a jdm unit from 2007 It has climate control ac and tweeters and some bells and whistles. However the center display is in japanese and all the controls on the dash are also in Japanese. Does anyone know if this can be converted to a double din ?- Car Exchange at Car Sale - Document Procedure
Like I said open paper transfers are illegal, I am no lawyer but any document issues in favour of an open paper transfer without actually transferring the car should be null and void now. So essentially his letters are useless. Best option you have is to sell the car like anyone else would and buy your new car. May we know why this is not an option?- Car Exchange at Car Sale - Document Procedure
Normally car sales people do this since they do not want to add an owner to the book. However vehicles ownership under open papers is illegal since the grace period is over now. If someone uses your car under open papers and gets caught you might also be in trouble. Also who knows what your car will be used for during the period of sale? He might run over someone and you might be in trouble since you are the registered owner still.- Engine Stop in the Traffic
I am not familiar with your cars engine but there is a common fault in Mazdas related to cam position sensor, this has been discussed in the forum and could be that. Also it can be something simple as a clogged idle valve. When was the last time you did a tuneup? Suggest you start with this. Clean iacv > EGR > spark plugs > check coils.- Resistor for LED Lights (72W / 24V)
We were saying that the wattage indicated should be proportionate to the power drawn. Watt = voltage X current (amps) For the light to output 72w the current draw at 12v should be 6 amps (assuming there is zero wasted energy). Which is not the case. Or are they implying that it produces a similar light to a 72w incandescent light.- Resistor for LED Lights (72W / 24V)
Good point, P=VI I think most of these Chinese light outputs are exaggerated.- Japanese Car News
Whats interesting is that they say "Fun to drive again"- Wisdom of buying a 1980s Mazda 323 Famillia for 400k?
It all depends on each individual vehicle, at this age almost every single model will have some repairs to be done. For checking the car you can take it to a place like carchecks. In addition to what iRage said find a car that has been in unmolested. What I mean by that most of these old cars have so called "modifications" on them. Stuff like bigger wheels, ride height adjustments only make things worse.- Kenwood Car Audio - Bluetooth Set Up
i have a kenwood unit as well, whats the model ? and post an image of the home ui - Engine tune up cost
