Everything posted by The Stig
Buying Car Parts In Ebay
Owwww then some service like UPS might be better than USPS cause they clear it and also pay the tax and deliver it home.You just have to pay them the tax value+their charges. Might be a little costly than USPS but no hassle at all.However if you are on a tight budget USPS would be the only option,but it will take about 2-3 weeks to arrive in SL.
Can You Get Copped In Sl For Having A Radar Detector?
Yep they are back and they are also installing cctv cams, soon they might install speed cams as well.
Most cops wont even know what it does, even if you get caught you can always say "It came with the car when i imported it, i dont even know what it does" BTW is it a good idea to bring one of these down by USPS or UPS without hand carrying it ? will the good folks in the customs give me any trouble ?
Kia Spectra Coolent Overflow From Reservior Tank
Well first of all i think the reason your mechanic told you to run without the valve was cause he wasn't sure if it was the problem, so if the problem still exists obviously its not the thermostat valve. Secondly there is a reason why the manufacturer installed a thermostat valve,if your car would run fine without it they wouldn't have installed it in the first place.so dont be silly and install the thermostat valve before your car erupts like a volcano !
Need Help Finding Some Butane
Did you try Main street ? i know some guys buy toluene and stuff there, you might find butane as well.
Depends on the item you are bringing,if its really small sometimes they just dont open it at all. But if you are planing to bring stuff like guages and stuff you'll probably be taxed about 40% http://www.customs.gov.lk/valuation.htm
Can You Get Copped For Having A Muffler !!!!
Guys i know this thread is pretty old but i think i might have found the solution for this problem check this out
Honda Or Mitsubishi
I would go for the Honda, even though it doesnt have killer looks its much better than the cs1 (personal opinion i guess).Ride quality isnt that bad either.
Fuel Efficacy In Toyota Vitz 1300Cc New Modal.
the car doesnt have a lot of weight so im guessing it will do pretty well.But mainly will depend on the way you drive it.
Is This The Right Part?
LOl, sounds like your cars previous owner was a "makabass" fellow hope you found the part.
I dont think fiberglass will hold if your turbo has a high boost level, any way better than nothing. BTW did you check if it was just the housing or is the whole thing in bad shape ? maybe you can try to find just a housing.
Replacing 60/55W Bulb With 100/90W H4 Bulbs
Head light reflectors are not made out of metal, especially in a maruti.they are made out of plastic and have a chromium or some other form of reflective coating on them, and this paint fades away when exposed to higher wattage than recommended. the best option for Mjayanath is to stick to the oem specs, but if he wants more the best option is to fit in a pair of aftermarket fog light so he can switch them on when needed.
is this the part ? if so its a wastegate actuator.If you are not driving in the car that has that part its better to take it with you, but if it is its not a good idea to remove the wastegate cause your turbo might over boost.
Pioneer Head Unit
It would be easier if we know your requirements, what options do you want ? dvd playback,bluetooth,usb input,i pod support ? Are you going for a TV unit or just a stereo ? BTW do you want a single din one or a dual din one ?
Mazda 2
ohhh did not know about the JDM thing
Car Accessories
Sounds like a DIY job, the best option is to buy the stuff from darley road cause then you will have a lot of options to choose from. Maybe you can even reduce the price of the product since there wont be any leighbour costs.
Mazda 2
Just to be clear, are you talking about the mazda 2 Hatch back or the sedan ? The hatch back is called Mazda demio and goes arround 3m. Haven seen the sedan version arround here though.
The Bigger, The Worse?
Yep and since lower profile tires have small side walls they tend to be stiff so when cornering at high speeds they dont sway to sides like normal tires, but sacrifices a little ride comfort. Also bigger rims means that manufacturers can fit in brakes with bigger diameter disks as well.
