Everything posted by nano31
Corolla Ce110 Driver Side Front Wheel Problem
I am using Corolla CE110 1997 XE Limited (Original Crystal Light). I have noticed that the distance between the rear end of the front wheel arch (A part of the fender) and the tyre is not the same; ie: In the driver side(R/S) it is less comparing to the other side (nearly half inch); in simply, it seems the R/S tyre slightly moved to the rear while the L/S remain the same or vise versa. There were signs of rubbing of the R/S tyre in the rear inner side but I am not sure of it as those marks were bit old I brought this few months back from the 1st owner, there were no signs of major accidents at all. Vehicle's original wheels replaced with alloy wheels (Original size), all four tyres are new (Slightly larger than the original size) and the same in every aspect. There were excessive wear of the L/S tyre outer edge and it was ok after the wheel alignment; during the alignment process the mechanic told me about the wearing of a "bush" in the driver side (R/S), probably at the lower arm where it fixed to the chassy but I later get it checked but it wasn't bad so didn't replace it. This was accidentally noticed while I was washing the car, there has NOT been any other problems like excessive noises, poor handling, excessive/uneven tyre wear; simply car seems perfect while driving!
Jeep Cj
http://www.autolanka.com/ad.asp?ID=34786
Steelmate 838M
There is small box with red LED and it has an screw and one direction was marked max while other direction was marked as min; I have no idea regarding what it is!
Steelmate 838M
Dear friends I am using "Steel mate 838M" security system in my car. It doesn't do automatic door locking (say if I forget to lock the door, it should do it automatically, aint it so?) Could anyone help me in this issue and I dont have the user manual as well.
Meter Panel Symbol And Abs Symbol Operation
If you have carefully look at a meter bord of CE110 1997, the ABS indicator should go off after few seconds just like the Glow indicator whereas the filter indicator only go off soon after the engine started.
Meter Board Unit
@ Isuru Udana, Ok, my dear friend!
Corolla Sprinter
I think the low resale value is probably due to lack of spare parts, regarding used spares;few days ago I just walk around Delkanda finding some fine interior parts (few plastics clips, etc) for my CE110 and just ask the sales guys from few shops regarding sprinter spares and they were surely hard to find. I have no idea about brand new spares.
Meter Board Unit
@Isuru Udana, Yeah Friend, but CE/AE 100 meter cluster will not be matching for 110!
Meter Board Unit
@ Sylvi Wijesinghe, Many thanks for your efforts! Actually I didn't wanna be having a separate RPM, as u might know corolla 110 SE versions do have it in the meter cluster. I am planing to find a matching meter cluster from a used spare parts shop and fix it to my car. I think it is a cable driven one but I wanna confirm it again.
Corolla Sprinter
Wat are the versions avilable in AE 110 Sprinter/CE110 Sprinter and what are the options in those versions?
Corolla Sprinter
I heard someone telling used (reconditioned) spare parts (esp. the body parts) are rare
Corolla Sprinter
Toyota corolla sprinter version seems to be having low resale value when comparing with "normal" corolla versions (AE/CE 110/100, etc.). Could anyone give us reasons for this low resale value? Is it due to some technical failure/s, Lack of spare parts (Brand new/Used)? Other than the different body style/lights/shells/badges the both versions seems to be the same!
Meter Board Unit
@ Sylvi Wijesinghe, He just said that he didnt do normal meters (Api Nornal meters karannae na)!he wasnt helpful at all! but thank u very much for ur support!
What Is The Best Engine Oil For Axio
Toyota motor Oil = Mobil
Meter Board Unit
Oh! I am gonna give a another try during this week. I ll let you know. Thanks.
Meter Board Unit
abiman, From where did u find Meter Board Unit for CE110? I tried around Delkanda but no success for CE110 but there were plenty of units for AE110!
Meter Board Unit
I have Corolla CE110 (Crystal Light) YOM 1997 Oct, XE Saloon Limited. I am thinking of changing the Meter Board Unit as it is nice to have RPM meter. My question is that if this new unit (from CE110 SE Saloon)) would just work when plug in to the connectors? or I might have to do some modifications as well? Esp in speedometer cable/sensors/speedometer drive gear?
Toyota Townace & Liteace
Aint there a difference in size, even in few cms?
Please let me know the exact differences between Toyota Townace & Liteace (CR 27 "Lotto", CR/KR 41/42)
Throttle Body Coolant Bypas
http://www.rotaryinsider.com/diy-tac38/throttle-body-coolant-bypass-gap29.htm
Corolla
Please let me know the difference between corolla 121 and 122
Toyota Hilux Vigo
Yeah I too awaiting to hear from experts. http://en.wikipedia.org/wiki/Toyota_Hilux
Hybrid Maintanence
It should be be the ABS sensor not the ABS unit
Townace Cr27 Superextra
buy 4 door, manual, flat roof, with 2c new engine
In simply a car with YOM 1997, odo of 110k is not possible n it should neraly be 150k ! My bro got CE110 1998 but odo is just ~80000km which could never be possible, we jolly well knew (before buying) it was fake but it was a really good car and he still uses it
