luckey007
Everything posted by luckey007
  1. I am having the same problem in my maruti 800. It's not a big daka daka sound, but small tik tik sound from the back when running on a non carpeted road. I have replaced shocks and remove, checked,tightened almost all the parts not welded. But symptom persists. Finally I made my mind as, "I have checked all the parts and they are normal, and It wont bother me during a tour". The funniest thing is it always comes when I drive it and when my wife is driving it doesn't . Sometimes I think it may be the sound that spare wheel is hitting with the metal of boot. But I couldn't confirm it because it comes after some distance of driving and I am not much dare to go such distance without a spare wheel.
  2. There are 2 lines and it doesn't look like an air line.
  3. luckey007 replied to lasi's topic in General
    Yes, It is a moving flap with a rim and helps to control spilling when the car shakes during the ride.
  4. luckey007 replied to lasi's topic in General
    It's very difficult in Corolla and once when I was cleaning the fuel tank I found a big part of a garden hose in the tank most probably an attempt of stealing fuel. If you really want it remove back seat , open a screwed or bolted opening on the tank then insert a hose. BTW you may break the non returning valve in the inlet of the fuel tank when you try to get the hose back if you put it from the inlet.
  5. http://www.tpub.com/content/construction/14273/css/14273_188.htm
  6. Cooling from exhaust line???? I feel it other way.
  7. Hi friends, I have seen this thing in recon spare parts joint.It was in the position where the catalytic converter to be. But it is bigger than usual cat. And there are two sensors attached to it. And two fuel/oil lines are attached.It looks fuel line to me. One line may be to the unit and other from it. It has big mount to the body and fixed thoroughly to the silencer from both ends with big spring washers.They said its from new Mazda van -Lion Face -with diesel common rail engine.They are clueless what it is. Guys, whats this gadget and whats it purpose? Experts shed some light.Unfortunately I don't have a photograph. Thanks in advance.
  8. This happened to my car and at that time when i asking from garages most of them are recommending a replace with recon one. Their point is as the shaft is worn and usually uneven we need custom made oil seals and have to do lot of lathe work.As they are reluctant to get the responsibility and those repair kits are hard to find-I live in matale,checked in matale kandy dambulla and kurunegala- I replaced it with a recon one. My car is CE110 and it cost me 10k.
  9. Actually for riding this type of sports/racing like monsters you have to reach forward. This reduces the air resistance by the rider and increases the handling. Once you got used to it there is no problem at all. Your height seems pretty decent for this bike, but if you still feel odd about proportions, go for a Hornet. Even though I have seen riders use for longer trips, I personally believe these bikes are made for moderate distances and may cause some aches and pains in longer trips in bad roads.For longer trips Honda LA custom or Suzuki GN bikes more appropriate AFAIK.
  10. Have you changed ATF recently?
  11. :lol: :lol:
  12. Also Isuzu parana moona,tube light model,samanala moona....
  13. Right hand drive in the jap seems to be a bless JDM users. But other hand euro fans may not be pleased. Anyway thanks for the link.
  14. There are eight light galent also.Only differs from no of lights and I have heard that its signal lights are also red-not amber-and said they were made to States and Canada
  15. luckey007 replied to gobi's topic in NISSAN
    AFAIK both are normal.
  16. Hey.....guys I just mention that only otherwise someone may reply like "dude, M800 doesn't accelerate!and its normal" and I wanted to escape from that comment and I wanna stress this particular car is much lazier in acceleration. And I am 100% agree with Big_D and now my dear friends ignore the clause in brackets and help me to find a solution.
  17. I have seen "Akalanka thathwayen"...
  18. Thanks a lot for your reply.The stretch is shorter.that may be the reason for winning the drag
  19. Can some one photoshop the face? for comparison. Not for disgrace. Only if it doesn't violate forum rules.
  20. I think this sound is related to the engine as sound comes even vehicle is stationary.Not a belt squeak though.It is coming from the inside most probably something related to engine design itself .Expert may help.
  21. Hi all, My wife is using a Maruti 800.I have replaced the all drive belts(including timing belt)at odometer hits 50000km(sparking plugs also replaced at this time). Now odo reads 51000km.Once I was driving it I noticed its bit lazier in acceleration and stucked in a steep slope.(I was using M800 previously & it was not like this even odo at 89000km.Once I smoked a vitz(needless to say auto transmission )in a casual drag)She is servicing it at Udawat*a Motors at Maharagama & when she put it to regular maintenance there, asked about this. Then they have asked whether T belt is replaced and requested to do a tune up. Further they said while tuning up they use a special fuel so fuel circuit also will clean. Charge is 6500LKR. Furthermore this car is having a slightly large balloon size tires added by previous owner.Handling is not a problem as they rarely exceed 50kmph. 1.Will engine tune up will fix my problem? 2.Whats this special fuel? 3.Is engine tuneup is a regular maintenance or not?(If regular whats the interval) 4.This car's fuel consumption is slightly higher for M800. Is it due to engine fault or a visual effect due to the tires?(Don't bash me as a fuel-maniac ) 5.Do you have any experience with this garage. How are they?How reasonable the charge is? 6.If you can recommend a better joint it will also be highly appreciated. Please reply to my question paper and sorry for the longer post.Your ideas will be highly appreciated. Thanks in advance. Cheerz. P.S-The car is EFI model.And a lady-friendly garage will be more appropriate.
  22. Actually you can see the under carriage, springs,fuel tank ...etc when you see it from the back. Theres no need to peep.I will post a pic if I found one. It's not a 'face lift', i'ts 'A** lift' bro.
  23. Corolla 110 face lift model called as 'Crystal light' model.
  24. :violent-smiley-030: :lol:
