MV-5
Everything posted by MV-5
  1. MV-5 replied to MADZ's topic in The Lounge
    among our friends, he is very famous. in 2012 they were well organized (giorgi tevzadze (this driver) and giorgi kacadze and few more) and they ran the needfordrivers web site.they all are M5 lovers (his vehicle number is 00M-500).
  2. for most of Chinese and Taiwan coils ,mazda famila BJ throws CEL(so thismight be applicable to Mazda 3 and axela as well). technical reason might be that this coils have not met the specification(primary or secondary resistance, etc... ) expected by the ECU.
  3. just like "Moral compass",there is a concept called "car compass" (this is uncovered by me )
  4. one of my friend faced this kind of problem , as you said when driver release the gas pedal and fully pressed the clutch , car maintains some high RPM for 2-3 seconds and then drops to somewhat around 1000RPM. cleanup of the "air intake path components" solved the problem.then i think full tune up might solve your problem.
  5. MV-5 replied to MADZ's topic in The Lounge
    CodeGen and Electric vehicle??? strange relationship.
  6. yes, i think product is still available in ebay,but i couldn't remember the exact seller. but try to search "PRENCO ignition coil ZM" or "PRENCO ignition coil Protege" or with similar keywords. engine number starts with ZM , it does not contain letter "D". check the part number , it should be ZM0118100.some sellers refer this engine as ZMD. for your third question simple answer is YES. Ignition coil assembly produce very high voltage within very short time (if RPM 2000 , 1000 voltage generation cycles should be completed within 1 minute). if the coil is unable to handle this, result is that engine will make random misfires. if insulation is weak (at high temperature), then generated high voltage will be discharged through a different path than the spark plug tip. ultimate result is high fuel consumption and low performance. the other thing is vehicle manufacture has provided specifications for primary and secondary resistance (you may search Google and find out those spec ). coil should meet these specifications. I forgot to tell you, if your car has CEL, for most of non genuine coils , it will throw a CEL Indication. So best option is genuine, second option is high quality OEM standard coil. EDIT : i am not 100% sure, i think this the product i bought (directly from ebay) , tax was just 700/= LKR. http://www.ebay.com/itm/New-Prenco-Ignition-Coil-ZM01-18-100-/361046757704?pt=Motors_Car_Truck_Parts_Accessories&hash=item5410105148&vxp=mtr
  7. i would prefer e-bay (if you can find a genuine one for 100$ , shipping cost also should be taken into account here). I think genuine one will be around 140$ (without shipping cost) . part number is ZM0118100. if the product is not shipped to sri lanka, then try to contact kapruka. they will bring down it here for you. i bought 2 coils from e-bay. (not genuine) but OEM standards, brand is PRENCO (http://www.prencocorp.com/). per coil, cost was around 9000/= (including shipping and tax). i am still using that 2 coils, already clocked 40K+ Kms. ZM-DE is the mazda 1.6L engine which has been used in 323,protege,ford laser. ZL-DE is 1.5L ZL-VE is 1.5L SVT
  8. do a simple test,drive the car at 25-30 kmph, but try to run with a different RPM(higher or lower), if it is a manual you know how to do it. if it is an AT, then there might be ways like using overriding positions like 1,2 or N.
  9. while the problem is there and you turn the key, what was the observation, Crank sound or just "click" sound or no sound at all??
  10. if you can feel the misfire when only the car is idle, vacuum leak might be a probable root cause. Normally coil pack failures are noticeable even 1500-2000 RPM.(that means , not only when vehicle is idle). Again , when coil pack spark leaks are there , plug cleanup would temporally solve the problem (spark will be thrown through the least resistance path). as others said, good mechanic can analyze the scan result (not only for the random misfire code, scan tool can measure the performance data parameters ) and come to a conclusion. compression test, EGR,vacuum leak, then electrical path (plugs,wires,coil packs,ignition signal not propagation due to incorrect sensor readings ), then injectors. but good mechanic can cut-down this scope smartly through a full scan for performance data parameters.
  11. Thanks for the reply. most of the BJ owners have used this method. this is for new (probably non tech) users. using this method you can check not only ABS system but also few more subsystems. we have T pins and F pins to test and read subsystem error codes. T pin should be grounded to bring it to test mode.F pin will emit the error code pulse. Ex: test Engine. T pin is TEN F pint is FEN TEN should be grounded and LED should be attached to FEN and B+ ( B+ is actually +12V , so +ve of LED should be attached to B+ ). to control the current flow through the LED , LED should be connected through a resister (1K is enough, but 10K is also produce bright enough the LED). if your car has CEL, then no need to have LED. CEL will emit the error code signal (but only for EN test, for AT and AB test you need to attache the LED). Ex: test auto transmission system. T pint TAT F pin is FAT Ex: test AC T = TAC F = FAC SC = Cruise control WS = Four wheel steering system. BS = ABS
  12. If someone has recently replaced a ABS sensor (99-2002 famila/323) , it would be great if you can tell me the price for a genuine sensor (not from mazna ).
  13. Since yesterday my car throws an ABS problem.This is the way i diagnose that. for your information i recorded it and uploaded to YouTube. hope this will help mazda 323/familia owners when they faced a same kind of problem. Replacing the front ABS sensor is not a big deal, next week i am going to do that once i got a genuine sensor (might be from rainbow or asiri). hopefully i will be able to upload that video as well.
  14. MV-5 replied to MADZ's topic in The Lounge
    when i saw the photo, first thing came into my mind is maersk
  15. MV-5 replied to MADZ's topic in The Lounge
    http://www.dailymail.co.uk/news/article-2655098/Fed-businessmans-straw-Indian-owner-53-000-Jaguar-turns-donkey-power-keeps-breaking-down.html http://www.rushlane.com/jaguar-india-donkey-rickshaw-xf-12121317.html
  16. This values are correct if the air temperature is around 25 C- 30 C, so this is not valid for a area like Nuwaraeliya.
  17. No, this is not the optimum speed, if the air temperature is 27 C, if you maintained 87.294 Kmph, then the expected value is 21.6437 Kmpl. So try to maintain that speed , acceptable tolerance is 0.005% .
  18. when i use my laptop unplugged , it doesn't consume power (KWH meter doesn't run, that means it doesn't consume power from outside, right? ).
  19. "Return of snake" powered by 2015 ProtoType R
  20. at least Asanka knew that the indicator is something related to fuel. that should be appreciated.
  21. This "genius idiot" is always trying to make a mountain out of a molehill.
  22. People like to have fun.... Who thought that we would find a person like "Chatur Ramalingam" in this real world.
  23. MV-5 replied to dimdim's topic in General Automotive
    VVT vs {S-vt,VTEC,NEO-VVL ....} CVT vs {Multi matic,N-CVT,Multitronic,PST ...} is it a typo?
  24. MV-5 replied to Watchman's topic in General
    Ex: someone decide to save 100 rs per month from his salary. but in one month he had to lend 75 rs to a friend, due to that he was able to save only 50 rs. next immediate month he will be able to save 100 + 75 rs. if he is a Prius owner he will say that he saved only 50 rs in the first month (just like fuel figures in highway). but in fact he has saved 50+75 rs in the first month. but only 100 rs in the second month. for the first month "Effective value" is 125 rs, but actual value is 50 rs. for the second month "Effective value" is 100 rs, actual value is 175 rs just forget , i was just kidding!!!!!!!!!!!!
