Magnum
Everything posted by Magnum
  1. Did all the LEDs die at once? or one by one?
  2. Did you drive through muddy or sandy roads? Sometimes dirt gets in between the pads and the disk.
  3. Magnum replied to sira's topic in TOYOTA
    If you want the best fuel economy then stick to the original tyre size and use an eco or low resistance tyre set. I'm current using a Continental Vanco tyres, I would suggest that for a comfortable ride, I'm not sure if you could get tyres that are comfortable and help provide a better fuel economy. On the topic of changing the tyre, well if you fix bigger wheels it will reduce the fuel economy for sure and some people claim that it reduces the wheel spinning issue but I don't have first hand experience in it. Mine is a KDH206 hence I don't have that problem. KDH requires 105/107 weight rated tyres or 8 ply tyres, although some people use 98 weight rated tyres or 6 ply tyres. Going for a lower weight rating tyres would wear them out soon. There are some all terrain tyres which are compatible with Hiace, they may reduce the wheel spinning issue as well. Some people claim that KDH series vans have more wheel spinning issue than LH series due to being lighter, this isn't true. KDH201 weighs roughly 200kg more than a LH172, but at the same time it has more torque and the peak torque is produced at a lower RPM as well which causes tyres to spin excessively when the rear is empty
  4. What's the new circular all about? I thought it was only the minister permit which was cancelled
  5. He had the van lifted up on a slope, I'm not sure whether it would be any safer to work under vehicle with jack stands while the vehicle is on a slope.
  6. Graphic content!
  7. Oh so that's what he was trying to say...probably it has an audio system with those big speakers
  8. You would find the answers to your question in this thread:
  9. Can someone translate 'sath & boks'?
  10. It's not simple as that, turbo engines and bigger engines drink more fuel is a false idea that's been around in Sri Lanka for a while. Let me give you a better example than CHR vs Premio example. The 200 series Hiace with 3000cc variable nozzle turbo(1KD-FTV) mated to an automatic gearbox does equally good in fuel as a 100 series Hiace with a same size engine(5L) but without a turbo. It's the same story if you compared KDH vans with 2500cc(which has a standard turbo instead of a variable nozzle turbo) and 3000cc. The reason why these engines are able to achieve decent fuel economy even with a variable nozzle turbo or having a bigger engine capacity is I believe due to better fuel injection or fuel burning technology( that is less fuel is being wasted). Mind you a variable nozzle turbo can kick in more and quicker than a regular turbo. As iRage already mentioned the Premio in question here is powered by the 1NZ-FE engine which still rocks the old VVT-I technology where as Toyota has moved on from this to Dual VVT-I and Valvematic. In the past the major problem with turbo engines was reliability, older turbo engines didn't have proper intercooler or had no intercooler which caused the engines to develop problems quicker than a naturally aspirated engines. Furthermore, the turbo units itself didn't have proper cooling as they do now. However, I partly agree with you, if you load up the CH-R to the max it would most likely sit on the turbo the whole time which would reduce it's fuel economy but at the same time it would be a similar story with the Premio as well, as it would stay mostly in the high revs. Also, I do agree with you that the influx of these new small capacity engines could be related strict emission standards.
  11. You are forgetting the peak RPM those figures you have mentioned are achieved at Premio produces 109PS at 6,000RPM and 136NM of torque at 4,800RPM CHR produces 116PS at 5200-5600RPM and 185NM of torque at 1500-4000RPM Hence the 200kg of additional weight would be combated by higher torque at lower revs and achieving a higher PS figure at lower RPM as well
  12. Are you specifically looking for an unregistered van? If you are alright with a registered van you could take a look at some of those 40 series Townace with Noah conversion. They'll fit into your budget and they offer 7 seats with dual A/C, most mechanics would be able to repair them with no issues, plenty of parts and if you find one with 3C intercooler turbo it'll have enough power to pull 7 people and luggage.
  13. I'm not an expert on european vehicles but even I can tell thats not a Defender 90 or a Defender at all. It looks like on of those Land Rover models which came out prior to the Defender badge being introduced. Probably a Land Rover series III as Tiv mentioned.
  14. Probably he got confused between paint and plastidip
  15. Is it safer to have the oil slightly below the high mark than getting it overfilled?
  16. Im digging this!
  17. Do you get transmission issues in Vezel in Bangladesh also? or is your issue a rare case?
  18. Generally all gasoline vehicles have a fair amount of engine braking
