Everything posted by Magnum
Upgrade head light to adjustable
2 years back before I got NBU for high beam I was considering LED but I stayed away from them mainly because I heard the light beam doesn't travel far. I guess they have improved since then. Would you say the color is white or blueish white? And these seem to be better than what you regularly find at accessory shops.
My Hiace has OEM HID for low beam using reflectors. It uses D4R bulbs, I think D2R isn't used anymore as it has has some dangerous stuff in it which could be harmful in case a pedestrian gets exposed to it during an accident. Also D4R/D4S bulbs require a different ballast. What kind of LED are you using? How's the throw of the light? Does it travel far enough to be used as high beam?
Is buying a Honda Vezel for personal use wise decision?
Been having driven a Vezel and been in it as a passenger I could second this. The rear seat is bit of an issue during long journey mainly due to the angle of the seat. Also the low profile tyres pick up small pot holes on the road but the suspension manages the bigger ones well. Fuel economy was similar Performance was alright too apart from the regular hybrid lazyness. It's worth for the price.
- Samsung smart 3D TV power bulb blinking five times
- Car Battery
- 2018 Budget - Vehicle import duty
Japanese Car News
Honda StepWGN Hybrid The Honda StepWGN has been refreshed for the Japanese market, with the Waku Waku Gate-equipped MPV receiving a range of updates to its styling as well as list of technologies. Starting with the latter, the StepWGN in Spada guise is now available with the Honda Sport Hybrid Intelligent Multi Mode Drive (i-MMD) hybrid powertrain. The system consists of a 2.0 litre Atkinson cycle DOHC i-VTEC petrol engine, i-MMD electric motor, e-CVT and a lithium-ion battery. The internal combustion engine is rated at 145 PS and 175 Nm, whereas the electric motor serves up 184 PS and 315 Nm. Drivers will have access to several drive modes, including an electric-only option, and Honda claims a fuel economy of just 25 km per litre (JC08 mode). The Spada Hybrid variants also get a special tuning for the suspension, and in its highest trim level (G EX Honda Sensing), performance dampers are fitted to balance occupant comfort and high-speed driving stability. the Honda Sensing suite also makes its way into the StepWGN, which includes a range of driver assistance and safety systems. There are eight basic functions within the Sensing suite, and all of them are standard across the range. hybrid variants get a Low-Speed Follow (LSF) function to enhance the ACC, which has a range of operation starting from 0 km/h. The system is said to reduce the burden on the driver when driving on congested highways. As for the styling changes, the StepWGN Spada receives new LED headlights, a three-tier front grille, a sharper front bumper, reshaped lower grille and a tweaked tailgate spoiler for improved aerodynamics. The MPV can also be had with Modulo bits, should customers want a to spruce things up a bit. Prices for the 2018 Honda StepWGN start at 2,455,920 yen for the base, front-wheel drive B Honda Sensing variant while the range-topping Modulo X Honda Sensing goes for 3,665,000 yen
- ## Post Whoring - Part 3 ##
Need an advice to change LED
In SMD based led generally higher the number of SMDs brighter it is. I checked couple of COB led on eBay and some sellers have mentioned quantity of chips/beads. I assume they mean the number of diodes Little bit of reading tells me that COB is an advanced led technology in comparison to SMD. They are brighter and spread the light better than SMD. I avoided COB mainly cuz I couldn't figure how one bulb is brighter than the next one.
1. First of all LEDs aren't pure white. They have a slight hint of blue, but it isn't immediately noticeable. There's also a warm white led option, which has a golden yellow colour. Most common type of LEDs are SMD based of COB based. Higher the SMD higher the brightness(there are some high power LEDs too). I have no idea how COB based LED works. 2. If you are buying from eBay you need to make sure you are getting the correct bulbs. That is they come with different connectors. Common ones are T10, festoon, ba9s and ba15s(I think this only comes from brake lights). Those LEDs which come as a panel have all three connectors except BA15S. 3. Try to get good quality LED atleast for the parking lights especially if your parking light sits in the same compartment as your headlight bulb(that is without a separation). As the heat from the headlight will kill the poorly made LED. You get good quality LED from Osram and Philips but these will be $20. However you also get high quality LED for parking light other unbranded manufacturers too which will be $10-20 a pair. 4. If you install led for signal light your vehicle will read it as if the bulb is dead due to lower power consumption of led bulbs. Hence you will have to use a load resistor as Davy mentioned or you won't be able to identify if one of bulbs actually die. No matter if you have a load resistor or not the actual turning on and off process of a led bulb is faster than a filament based bulb. 5. LED for tail lights isn't really a good idea as the light beam from an led bulb is sort of directional similar to a spot light hence the light wouldn't spread well around the housing. Which means you will have a bright spot of light in one area which in my opinion is ugly in comparison to a light that's well spread across the whole tail light housing Also the difference between rear parking light and the brake light of a led bulb isn't that noticeable as a filament bulb as brightness in the filament bulb doubles up. Hence there's a chance of someone rear ending your car. I per wouldn't take this risk It's a similar story with reverse lights as well. 6. For interior lights pick an LED bulb based on the amount of space you have in the housing.
You don't need to change the full headlight As mentioned by Stig you can get a ballast only 260 came with Denso ballasts if I'm not wrong. You can get a used one at spare parts shops for like 5k Even the Hiace ballast would be compatible as well which is made by Koito for D4R/D4S bulbs.
In the Hiace also the automic headlight adjustment came only in the HID equipped vans. However one of my friend has a van that has HID and manual adjustment. That's how it came from Japan. You need to put your face near the headlight after turning it on. I'm not kidding, you won't be able to hear from inside the vehicle. To be honest I have no idea how it work.
Was auto height adjustment available as well? Such as in the cars with HID headlights?
You will hear a noise for few seconds when you turn on the headlight, sort of like a buzzing noise. Btw why do you need this feature in hilly area? It's not used for driving with your light beam pointed upwards but instead for lowering the beam when the front of the vehicle raises up when you have load in boot
You have/had a 260. Does this come with auto adjustment?
I assume you are referring to headlight height adjust switch/lever on the dashboard. I'm not familiar with Allion, but in Hiace the ones with auto headlight height adjusting feature don't have that switch. Neither you can do adjustments on the housing. Before you mess with your headlights you might want to check if your car has auto headlight height adjustment.
- Toyota Aqua or Honda Fit
Toyota Corolla Thel Higana Edition (Or My Take On An Axio Hybrid)
Or maybe it doesn't like tropical climate
- Good tyre for Premio 195/65/15
