Everything posted by chamilka
Ti Carina At212
Can anyone please tell me the idle speed readings of the rpm gauge in a 1500 CC Ti Carina car , when AC is on and AC is off. In my one, in cold starts with or without AC rpm is 1000 but when get heated it goes down to 800 or 750 sometimes, which makes it so difficult to drive smoothly (it is a manual gear vehicle). As far as I know when AC is turned on the idling speed should go up. Please let me know if anyone have ever experience this problem Thank you
- Nissan Fb14 Wiper Blade Size
Fb 14 Cooling Fan
Yesterday I checked the problem again my self. But fortunately now it is working fine. When I start the vehicle fans do not work unless AC is On and even when AC is Off fans turn on when the temp meter shows more than half. So it is exactly normal now. Thing that I didn't mentioned in my question was that I got this vehicle a week back and it was not even started for more than 6 months before. So unfortunately I am unable to tell you what was the exact problem. But searching on this I found that there is a thermo switch for fans it is even mentioned in the service repaire manual which I downloaded. So I guess this thermostat and thermo switch can be confusing. Anyway thank you all, for your great suggestions.
Fb 14 Cooling Fan
In my FB14 (1994) car radiator cooling fan rotates its full speed immediately after starting even when the AC is "off". Engine does not get heated, even after driving for 20 km engine is so cold. Have anyone experience this problem before? Is it something wrong with thermostat and something?
Is It Safe To Change To 2 Or L While Moving?
Hi terrabytetango,If you have noticed when you turn off OD the gears from 1 to 3 changes quickly than there are when OD is ON. So it saves fuel in a traffic as well as going up a hill (In general when you can't drive in OD gear).And also according to my knowledge the clutch mechanism is different when the gear is in 2 or L. In that position only the vehicle will be slowed down by the clutch in D position when gas paddle released it is free to go as in neutral .
In a vehicle with automatic transmission in normal condition we drive in D position. And in my vehicle there is a button to turn off OD which I use in heavy traffic and when driving up a hill. And I have realized that there is no use of turning off this OD when we drive down a hill because the engine brake will apply only if the gear in 2 or L. Now is it safe to change the gear to 2 or L while moving in a speed like more than 40kmph? I have heard that in automatic transmission, vehicle should be stopped to change the gears otherwise it could damage the gearbox (I am referring to forward gears, this should be true for Reverse gear) So is this condition still there for vehicles like Nissan FB 14 (1997)? Also in Suzuki Swift (beetle) like cars there is no OD on off button instead the gearshift should be moved to position 3 or D-3. Then is it safe to change it while moving. Thank you.
Nissan Sunny B310
I am going to by a car a 12 sri or a 13 sri is my target. Found a 13 sri Nissan B310 car with good body and engine condition but less options, like, is not equipped with AC, fog lamps and 6 meters. will this worth 4 laks?
Ti Carina 1996 Idling Speed
Can anyone owns a Toyota Carina AT212 1996 model MANUAL car tell me the idling speed shown in the RPM meter when AC is on and Off. Because in my car when the AC is turned on the idling goes down instead of going up as other cars that I have seen. After an engine tuneup now the Idling speed is at 1000 with or without AC (just after cold start) but when I run for about 2 - 3 Km s RPM goes down to 750 which makes it difficult to drive smoothly.
Carina At212 Wiper Blade Size?
someone own a toyota carina 1996 model, if you could please tell me the standard sizes of the wiper blades? I need to replace mine but when I bought the car it had same size wiper blades which I feel like not correct. Thanks in advance
Carina At210 Vs At211 Vs At212
Are there noticeable differences in the Toyota Carina frames AT210, AT211 and AT212?
Can someone tell me the standard size of the front wipe blades in Toyota Carina AT212 1997 model. Are the two blades same size or diver side 21" passenger side 18" ?
