Everything posted by Y3K
Pajero-Io Left/front Abs Sensor
Hi All, I'm searching for a Left/Front ABS sensor for a Pajero-IO, H76W. So far I have checked at many spare part dealers and all of them say the same thing. That they can't dismantle one from an existing, as the sensor seems to be brittle. Can any one of you help me in locating a sensor? I haven't checked with agents yet as I want that to be the last option which will be pretty costly. Thanks in advance for any help you can provide. Thanks, Y3K
Pajero Io - Alternator Belt Cuts Off The Engine
Hi All, This is something happened to me recently and I thought this might be useful for others as well to simply solving sudden engine cut-offs or misses that stops the engine and to get an actual understanding of the issue. My alternator belt was giving a shrieking sound here and there and since it was newly replaced at U***O, I just asked them to have a look. They identified the issue as the belt being too loosed and tightened it. Once the engine was re-started, it started to cut the engine off! As soon as the foot was taken off from the accelerator it stalled. The first thing they did was to connect the diagnostics, and run through the engine under the assumption that the fuel pressure was low. But, since the vehicle was running so smoothly without any issues from the morning, I just made an inquiry related to the alternator belt tightening, which turned out to be the real reason for the engine stall. When the belt was loosened somewhat, the issue got solved! When inquired, the mechanic said, the same symptoms were shown in another GDI they repaired recently, and that the issue was with alternator handling the load. Well I could not exactly make head or tails out of this answer on how it stalled the engine. How does the tightness of the alternator cable stall a well performing engine?
- Genuine Vs Original
- Oil Leakage Into Turbo Charger/engine - Pajero Io
- Brake Pads
Genuine Vs Original
Hi All, Can someone give me info on how these two differ? I have been doing a spare part search and came up across these two words. It's a bit confusing... (Read that genuine part and original part gives the same part number, but genuine comes from the original marketeer and original can come from any other!!! Is this true?) Is there a quality difference with the varied price tag or is it the same quality with different price tags? Thanks in advance for any info,
From Where To Buy, Tie Rod & Rack End For Pajero Io
Hi All, I would like to know about a place to purchase the mentioned items. So far I have checked UM and the prices they provide is very high. I'm going to Check a place call D.H.....K. Motors at panchi tomorrow, and would like to know about other places as well, if there are any other (Specific for Paj IO) PS: Forum post I found, http://forum.autolanka.com/topic/10240-pajero-io-spare-parts/?hl=%2Brack+%2Bend Thanks,
Engine Oil Level Drop
Hi All, Just an update to provide an insight/view to anybody else whose having the same problem as I did. The culprit in my case was worn out Valve Oil Seals. Once they were replaced, the oil issue disappeared like a charm. Thanks,
Hi All, I was finally able to locate the culprit for the oil issue. It was Valve Oil Seals!!! It seems that in the first overall the seals that was placed had a wear. The agents explained this as a cause of not using genuine parts! Also rough idling had been due to an issue with a sensor near Injectors! jdnet remember the reading you got related to the petrol mixture??? Once it was replaced the rough idling problem was solved! Thanks for all your valuable advice's and help Cheers!!!
Good Mechanic For A Gdi Turbo Engine, And Pejero Io Repairs
The Don: Sure mate. CJ5: Nah it was not an issue with the coils. I got em checked It was the filters for mine
Hi All, Here's an update of so far what I have done. 1. - Replace gasket and ring set with an engine overhaul. 2. - Service the GDI pump as many of you advice - It seems some horse or tube was broken. It had to be replaced 3. - Service and checked the throttle body 4. - Gear box mount replacement 5. - EGR valve blocking Even after everything the rough idling is still there with high oil consumption (1/2 ltr per 100km!).... Now the next target is the turbo unit
Hi All, Here's an update of so far what I have done. 1. - Replace gasket and ring set with an engine overhaul. 2. - Service the GDI pump as many of you advice - It seems some horse or tube was broken. It had to be replaced 3. - Service and checked the throttle body 4. - Gear box mount replacement 5. - EGR valve blocking Even after everything the rough idling is still there with high oil consumption (1/2 ltr per 100km!)... Now the next target is the turbo unit
Hi, My Paj IO (a 2001, turbo, GDI), was having some pickup issues, and it was consuming oil. (About 2 ltrs/month) As per the initial diagnosis by a set of uni** mechanics, the diagnosis lead to changing of head-gasket and ring-set. So the engine was dismantled, but at that point the real issue has been discovered as an oil-leakage into the turbo engine, which is a bit alarming since cost of repairing or replacing a turbo charger seems to be a bit high. Anyways, can someone please point me to a place that does turbo engine repairs? I'm also searching for 2nd hand turbo engine as a replacement. Once again any places to specifically check it for? Thanks in advance,
Hi, Don its around 32k for ring set and gasket. Hey did you see all those suppliers in alibaba? They offer a complete piston for 10$!!! Thanks NZer.
Hi All, jdnet, any recommendations for the job? Don, well when I asked from UM what they said it if the original part (exact oem) is used then there is no need of re boring or any other work. Just replacement would do!!!. They recommended me to get gasket, ring-set. Also ask for the following replacements: THRUST BEARING SET,CRANKSHAFT - 1052A442, BEARING,CRANKSHAFT- 1052A437, BEARING,CONNROD - MD343138 which is a sort of engine overhaul Thanks,
Hi, First of all, TCJ thanks will give a ring and see. BTW these are not the same guys who are from UM n have a workshop set up at kadawatha right? jdnet, well there are a set of problems. 1. recently while driving all of a sudden IO started to knock (no matter how hard i peddle the engine is not revving up, n it came to a halt once or twice as well, then it revs again, and in the next minute it goes down) My mechanic said it was a blocked fuel filter. And said fuel pump filter has to be changed but the in tank filter can be cleaned. So I allowed him to change the fuel pump filter. (nothing was done to the GDI filter: at least shouldn't he take a look at it?) and when I went for cleaning it to his workshop, he says that its dangerous to clean it blah blah blah.. and he wants me to purchase a new one to be replaced!!! 2. high oil consumption (burns abt 1/2ltr per 100km). This is due to a need of a new ring set. I have ordered this from UM n still waiting for this. 3. the idle issue (the one you checked) 4. gear shifting latency. As per my understanding, there's a sensor at the throttle which triggers the shift downs/ups Thanks,
Hi All, Can anyone please point me to a person, workshop that is actually good on GDI Engines & Pajero IO. No point in going to UM since the work they do is crappy!!! Also I'm not much satisfied with my present mechanic. He seems to be changing his word all the time 'n although he's from UM I'm beginning to have doubts over his expertise. (The guy seems to be ripping me off!!!) I'm getting fed up with the troubles that seems to increase day by day with my jeep and if I recall correctly everything started after the first injector clean up. Really tired of searching for places of GDI specialists, n am doubting if I can locate a person who has the correct knowledge on the vehicle. Please help me out if you can. Thanks,
Pajeroio Spare Parts
Don, jdnet thanks guys, I placed an order with UNI Mo today, they said the latest they will take is a month 4 gasket n piston ring set. Will order a set of head bolts as well,. jdnet, you still in SL bro?
Thanks for the info Don... Nah still was not able to locate em.. Thought of trying UM since amaya does not have the part!!! BTW, I was able to locate a couple of Chinese people who said they have the parts.. But am a bit reluctant to trust em Hmm.. you sure about 4G91/92/93 head gasket thing?
Hi shane6399. Sent you a message. Thanks,
