Everything posted by kmcsb
Car Warming Up
i means when i start the car and walit a few seconds a few water is coing out from tailpipe..t thought its like coolent..(but no colour similer like water)...yes machan new radiator is jdm and single core also...i think its better to buy a t-stat anyway...
Car Warming Up
machan my one is d15b only and jdm one ..ECU?? you mean tht box @passanger side behind the carpert...yes machan have..whts up??
Car Warming Up
<blockquote class='ipsBlockquote'data-author="H.C" data-cid="231613" data-time="1359470747"><p> most probably someone have removed the thermostat to prevent a heating issue. Take it to a proper mechanic and see weather thermostat is intact. If you put a thermostat, just check the condition of the radiator as well and as Rumesh said, drive her with frequent eye on temp gauge. Themostat comes first in my list.</p></blockquote> Machan do you where is FITV (fast idle thermo valve) located in our engine..i looked aroud but unable to find it.. I alredy cleand idle control valve..do you know where is it?
Car Warming Up
My car is eg8 single car with d15b jdm.. I inspect cooling system and feels my radiator like new maybe preivus owner had replzed it..and chked around for leaks and thank god coudnt find any... Perhaps i feel my thermostats life has expired so its not funtions correctly.. Also last year i just flush and replz coolent wth caltex brand .. Wht do you think guys may i go thostat first?? My garge guy told tht t-stat would be nearly 2000.. But teck askd me 4700..ohh do you knw any othr plz to buy cheaper around maradhana..???
Car Warming Up
yep you right..i have an issue of fuel consumption and searched for an solution..although more research i fairly finds out the temp problem...mentioned above i did several things carb cleanups,spark plugs ,wires ,rotor ,idle valve cleanup..but no use.ahh anyway macn i live in kotte,colombo. normally tmorning temp maybe 25c around...thn backto topic ,i fells my car gets more time to warm up comparing other vehicles.. yesterday i visited to garage to show this error and told him abut this problem..first he ignored thn i start car abut nearly 15 minutes..also its just took 25 minute's to drive to garage..so totally it's half an hour and still its just low on middle point...thn he accept there might a problem... and sometimes water coming out of tail pipe..first i thought it was in good shape(good tuneup)..now i think it was coolant.. he told me to rplaze both thermstat and sensore too.. (mostley maka bas arout here as H.C mentioned)asked teck they offered rs10000 both.. so guys waht you think which part should i afford first????
Car Warming Up
I chked when temperure needle comes 1/4 up the radiator fan become to rotate.. I think temp sensor gone bad too.. Today i travel 25km since morning but needle still @ little bit below in middle.. Thts means engine getting more time to heat..so is tht mean tht is delivered more fuel and air too...pls help guys..
Car Warming Up
imorning i chked both upper and lower horses of radiator are warm up at idle ....then wasi it stick open???
Car Warming Up
normally how long does it takes to warm up car for normal tempeture ( to approch needle in temp gauge to middle) ????or how many kilmeters should i drive....for eg8..??
Car Warming Up
my eg8 gets abut 5-7 minutes to warm to operation temperature (to idle)..alos even after 20 miutes my tempeture needle @bottom....to get normal temperature( needle as it for middle) gets more then 45miutes.... also when i parked my car and start it after 30 miutes its also try to warming up then idle in 2miutes..this is getting me a headache...and i feel im getting poor milage also.. i did throttle body cleanup and IACV clean also..but no sucess..is it a bad thermostat..????. if it is hw much it willbe??? or any fault...??? plz help..
Engine Oil
machan what about ur milage???? and hw much 4L can...and brand....hav u noticed any performance after swich into tht...mine 150,000kms passed...will it be ok to switch???
Engine Tune Up
mate do you kow what are the steps he did..does he do a full tuneup like compression test ,vacum leaks,timing,..????
D15B.. Chk Ur Engines Nowww
macho can u upload tht service manual (pdf) to the site..its very useful to everyone..
i refer net and found some information's ..chk these out ! D15B Found in: 1988 Honda CRX 1.5X (rare) 1990 Honda Civic 25XXT Formula (Japanese Market) Honda Civic Ferio MX (Japanese Market) EG8 1998–2001 Honda Capa GA4 (Japanese Market) Displacement : 1,493 cc (91.1 cu in) Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.33 in) Compression : 9.2:1 Power : 103 hp (77.23 kW, 105 PS) at 6,800 rpm Torque : 14.1 kgm (133.4 Nm) at 5,200 rpm Rev limiter : 7,200 rpm Valvetrain : SOHC (4 valves per cylinder) Fuel Control : Twin carburetor PGM-CARB/fuel injected D15B2 Found in: 1988–1991 Honda Civic GL/DX/LX 1988–1991 Honda Civic Wagon Wagovan/DX 1988–1991 Honda CRX DX 1992–1995 Honda Civic LSi Hatch/Saloon (European Market) 1992–1995 Honda Civic DXi Hatch/Saloon (European Market) 1990–1995 Honda Concerto (European Market) Displacement: 1,493 cc (91.1 cu in) Bore and Stroke: 75 mm × 84.5 mm (3.0 in × 3.33 in) Rod Length: 134 mm Compression: 9.2:1 Power: 92 hp (69 kW) at 6,000 rpm (US) 90 PS (66 kW) at 6,000 rpm (Europe)[9] Torque: 88 lb·ft (12.2 kg/m, 119 Nm) at 4,700 rpm Valvetrain: SOHC (four valves per cylinder) Cam Gear: 38 tooth Piston Code: PM3 Fuel Control: OBD-O DPFI and OBD-1 MPFI Redline: 6,500 rpm, 7,200 rpm rev limiter Head Code: PM5 ECU Code: PM5/P04 [*] D15B3 [*]Found in: 1988–1995 Honda Civic Shuttle GL 1989–1996 Honda Ballade 150-16 & 150 (South Africa) 1992–1995 Honda Civic LX (NZ model 1988–1991 Honda Civic LX/EX (NZ model 1992–1995 Honda Civic EX (SA model Displacement : 1,493 cc (91.1 cu in) Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.33 in) Rod Length : 134 mm Piston Code : PM3P Compression : 9.2:1 Power : 105 hp (77 kW, 106.46 PS) at 6,000 rpm Torque : 98 lb·ft (13.55 kg/m, 121 Nm) at 4,500 rpm Redline : 6500 rpm Valvetrain : SOHC (4 valves per cylinder Cam Gear : 38 tooth Fuel Control : PGM-CARB Transmission : P20
Manual Transmission Fluid
thank machan very useful..machan i askd from agents and they given mea 2l og honda MTF.. i asked them about weight and viscosity but they didin know and not even displyed on a bottole also..so im little bit confussed...so i came back..the bottle seems like this if im buying an anoter product of MTF wht weight should i go with????? as i said mine does 160,000kms.... will high W doing less fuel as well?? so mate wht d u think???
machan wht is ur car & how much its done ?...(km)
yes its recondition..
hello guys, My block is stamped D15B with no number following the letter. How do I identify what she is? my car is 94 honda eg8 ferio single carb.... if anyone ones more details post here..tht will be very useful for all of us... i refer my vehicle book its still same D15b and capacity 1499cc....guys i need more details abut it....fuel systems ,and obd-0 orobd-1 .....any details... i seen my one has o2 sensor with one wire and still it in factory fitted....but i surf net i've seen noramlly single carbs ared15b2 and they havnt got o2 sensor....so im little bit confussed..so honda guys plz help....
im going to replze my MTF for the first time after i bought it....its already done 160,000kms...so what grade and viscostiy u prefer...do i need to replze with honda MTF fluid or any ??? also mine eg8 94 JDM single carb I need to know wht are the part number for Belts also..eg- timing,AC.... i heard mitushuba ..will they ok?? should i replze geniune Honda timing belts or can i use mitushba ones also..plz help guys..... wht abut water pumps??? its very useful if u knows prices of each ones...... im going to use 15w-40 mobil1 for my next service with vic filter...is it ok no...
Short Shifter For Ek3
chk ur pivate massages..
Wireset
thanks bro bought a reconditon one...thanks bro
macho chk ur massage..plz
Honda Spoiler
anyone have OEM SPOILER for eg8 also
Best Rim/tire Sizes For Eg8
my one still have OEM sizes..175/70/13.. wht is the best size for handling,performance and fuel effiency.. if i'll going for 15" alloys should i need to put low profile tyres..wht abut 14" ????]
- Shock Absobers
Shock Absobers
yep don is right..i used tokico and im very satisfy...yeh before fitting u asked them to pressurized frst..also replze mounting bushes,damepers or even springs..if u can sty and inspect while they fit.. did..i had wait @garage and spend more the 10 hours...now im very freely... they suggest but yu hav to an idea wht for go on..ask and review from specialist also forum like this... thanks to autolanka and geinus aroundthere. !!!
