kmcsb
Everything posted by kmcsb
machan im suffering the same problem u get...my one also geting water but only doing 6-7 maxium..but i recently changed my air filter to vic genune one..now seems little bit improvemnt..maybe 8kmpl..i think its better to repair my carb first... and one thing i ddi ecotset last week..and as results wthn idle my hc 400 and 2500rpm its reduced 140...i surfed web and metion it was a spark and idle valve problem.... do you guys know any plz to buy IAC valve buy..??? hey guyz plz tell us a good mechanic to resolve thes problem...
yeh replzed spark tubesand gasket cover..problem sloved...thanks guys..
heyguys i looking for IAC VALVE for replacement..dou know where to buy it..and how much it willbe ?? iasked tech guys..unfortunaty.. they havnt got it...
How much willbe Iacv valve (autochoke)??
machan tht's the problem ...autochoke seesms to wrk...IACV valve..i just cleaned and replzed yesterday..but no good news...but i got a last time tune up report and tht was mentioned there was a vacum leak from brake booster and it repaired...i think maybe tht also rised up again.. even its do i need to replze whole brake booster...????
my eg8 got rough idle when i starts in the morning and tht keep on nearly 5mins while i'l drive also..it's little bit pain for me..is there any method to resolve this probem.. i hav just search websites and didi carb clean and IACV ( Idle Air Control Valve) clean up too..but stuill same..any suggestions.. th'ts feels my fuel consumption also getting worse..maybe 7-8.. but after idling car runs smooth and sometimes water comes out from the silencer....recenly i've just change my airfilter to vic one..my one is eg8 single carb.. plz help guys
i need to need wht this emiision report (eco test certiifcte)tells it.. i did yesterday and got passed ..but i need to kow more information about it...whter tht can need to change or upgrade to my car components though report...only i done change air filter.... .im having last year report also.. plz help guys pertol year 2011 year 2012 speed rpm idle 691 / 940 2500 rpm 2446 / 2590 HC idle 169 / 472 2500 rpm 169 / 182 CO idle 3.221 2.7 2500 rpm 3.162 3.23 LAMBDA idle 0.931 / 0.91 2500 rpm 0.935 / 0.91 02 idle 0.610 / 0.04 2500 rpm 0.650 / 0.19 CO2 idle 12.6 / 13.93 2500 rpm 12.6 / 13.72 WHAT DO YOU THINK GUYZ....???? wht points should be reduce and wht should i need to replze???any ideas....
macho hw much did you cost for toa can??? i askd hardware shop its rs 1500..isit ok??
my car is eg8 single carb...when i examine engine to change plugs,one of spark plug hole filled up with oil (2nd one)..others were ok.... wht's the problem??? but car doest hear a miss.... i askd frm mechani he told need to chang valve gasket cover & spark tubes.....i hav e changed those about 6months ago ang bought 4m t*** motors.... also i seen tht no2 spark wire has twisted...will it be a problem???? thn how much will be wire sets and packing set?? plz help guys....should i need to replze whole bunch @once??? (packin &wire set)
thats honda eg8 ...body colur -metlic green...i wish to paint trapet cover in red..wht do u think????
ooh brilient...thanks guyz..normaly hw much willbe the toa spray..?? is one tonic enough??
I wish to paint my trpet cover during my service..is it ok to do with normal paint or is there any special paint to do with it?? Pls tell me .. I ask 4m hardware store and they gave called TOA spray..is it ok..plz help guyz..
oops ..this is my friend no..anyway when will u come to nugegoda area???just PM ..OK
ok machan doyou have its part numbr......also hwmuch did they cost.....what do you think about irradim ones...??/
Machan anyway what do u use??? no 5 or 6.....ngk or other brand
i currently installed ngk ZFR5F-11.......that was coming whn i buy my car.......now i need to change my spark plugs and wire set also..although i have to face emission test next month...my one is recondition......when i looked my previous year emission test certificate it mention as ENG NO d15b2... then i refer net d15b2 engines plugs should go with BCPR6E-11......but im littlebit confused... is it ok to put no 6...plz help guyz....
machan can u give me ZAki's contct numbr ....and where he is????now how fuel consuption..is it a carb or vtec..can u PM to mee with full details with charges....thanks
machan what's the plugs did u used and number..is this v-tec or carb.. some of my friend says carbs can tuneup for 12kmpl in cities with A/C ..i need to need it tht....but i chkd one of my lugs get flouded with oil and its spark wire has twisted..others are ok...so i think i need to change tht wire set also.. did u chkd????hav done carb cleaning....
what about fuel consumption.....i thurully looking for that>>>>> im looking ZFR5FGP also..its called G-power..its gets better energy and fuel perfomance trhan standerd ones.... do yo any ngk dealers around colombo area....so i can ask about directly..
i decide to tuneup my eg8 single carb....when i gone to buy spark plugs to stafford , they gave me ZFR6J-11...but i refer my manual its says ZFR6J-11 -for hoy climates and high speed driving ZFR5J-11 for normal driving.... im looking for ZFR5J-11....my problm is its ik to put no 6 and will it doing fuel ... i ckd 4m tech thy are givin denso...but i dnt like them.... what do you think its ok to put no 6..????.im much care about fuel and idiling.... and im lokin for new spark wire sets for tht..hw much they will be...??? wht abut ngk..
Machan i need to know how ro clean my injectors in right way..plz explain hw..hw about STP fuel system cleaners..? I"ve used STP carb clean , it done verygood job.. What is the merhod??
Hw much willbe spark plug wires?? When i inspecing one of my wire covered with oil and it was twisted..should i need to replz whole wires and spark tubes also.. Then hw much they willbe???
i also need to do tuneup for my eg8 single carb...also need to change plugs..i need to know what should i need to change for gets better fuel consuption..so ho much will be noromaly does after better tuning and replacements parts..now mine does 6-7kmpl..so most of time i cannot put A/C and go..so i ineed to do it desperatly..also my mechanic said spark pugs ar not good.. but when engine starts some water coming out 4m silincer.. i did a carb clean last week also..but noting changed... what should i need to do?? live in pitakotte...plz help me also guys..great post chinthakahk
thanks machan plz can i hav tht switch...
nice to hear..howmuch did u cost to bring power mirror swtich..i need to bring tht also...
