kmcsb Posted March 6, 2012 Posted March 6, 2012 i decide to tuneup my eg8 single carb....when i gone to buy spark plugs to stafford , they gave me ZFR6J-11...but i refer my manual its says ZFR6J-11 -for hoy climates and high speed driving ZFR5J-11 for normal driving.... im looking for ZFR5J-11....my problm is its ik to put no 6 and will it doing fuel ... i ckd 4m tech thy are givin denso...but i dnt like them.... what do you think its ok to put no 6..????.im much care about fuel and idiling.... and im lokin for new spark wire sets for tht..hw much they will be...??? wht abut ngk.. Quote
Komisiripala Posted March 6, 2012 Posted March 6, 2012 So hot climate and high speed driving? Good no, for an eg8. Wires will cost around 4000. Here or on ebay Quote
blkr6 Posted March 6, 2012 Posted March 6, 2012 its the same plug and the the number part represent the heat rating. there wont be any difference in fuel economy at all. It will make a difference in longevity of the plug if you run your engine at higher rpms but if you are doing normal driving there wont be any deference. NGK wires are pretty good wires. Quote
Watchman Posted March 6, 2012 Posted March 6, 2012 I presume you dont live in nuwara eliya and so its safe to assume you live a hot climate. And they just group high-speed driving and hot-climate cos they both cause the engine to work at higher temp. Hence, the '6' is the suitable one. I would think the '5' is not able to handle the hot climate temp. Quote
shanX Posted March 6, 2012 Posted March 6, 2012 dude just replace them with ZFR6J-11 or ZFR5J-11, both dint make a big difference in my car. I have PZFR6J-11 now, so i think you can run ZFR6J-11, its not gonna break your engine Quote
kmcsb Posted March 6, 2012 Author Posted March 6, 2012 (edited) what about fuel consumption.....i thurully looking for that>>>>> im looking ZFR5FGP also..its called G-power..its gets better energy and fuel perfomance trhan standerd ones.... do yo any ngk dealers around colombo area....so i can ask about directly.. Edited March 6, 2012 by kmcsb Quote
The Don Posted March 6, 2012 Posted March 6, 2012 The difference to fuel economy figures by tweaking the spark plug type would be minimal, if all spark plugs in comparison is in good working condition. Get the manufacturer specified spark plug and you will get optimum fuel economy possible from a spark plug. But there are many other factors that affect fuel economy, not just spark plugs. Quote
kmcsb Posted April 4, 2012 Author Posted April 4, 2012 i currently installed ngk ZFR5F-11.......that was coming whn i buy my car.......now i need to change my spark plugs and wire set also..although i have to face emission test next month...my one is recondition......when i looked my previous year emission test certificate it mention as ENG NO d15b2... then i refer net d15b2 engines plugs should go with BCPR6E-11......but im littlebit confused... is it ok to put no 6...plz help guyz.... Quote
H.C Posted April 4, 2012 Posted April 4, 2012 i currently installed ngk ZFR5F-11.......that was coming whn i buy my car.......now i need to change my spark plugs and wire set also..although i have to face emission test next month...my one is recondition......when i looked my previous year emission test certificate it mention as ENG NO d15b2... then i refer net d15b2 engines plugs should go with BCPR6E-11......but im littlebit confused... is it ok to put no 6...plz help guyz.... D15b2?. I thought d15b3 is the single carb engine code. Quote
kmcsb Posted April 4, 2012 Author Posted April 4, 2012 D15b2?. I thought d15b3 is the single carb engine code. Machan anyway what do u use??? no 5 or 6.....ngk or other brand Quote
H.C Posted April 4, 2012 Posted April 4, 2012 Machan anyway what do u use??? no 5 or 6.....ngk or other brand Actually i got nippon denso plugs from tech motors for d15b3. Both NGK and nippon denso are mentioned in the service manual as stock plugs. Quote
kmcsb Posted April 5, 2012 Author Posted April 5, 2012 Actually i got nippon denso plugs from tech motors for d15b3. Both NGK and nippon denso are mentioned in the service manual as stock plugs. ok machan doyou have its part numbr......also hwmuch did they cost.....what do you think about irradim ones...??/ Quote
H.C Posted April 5, 2012 Posted April 5, 2012 ok machan doyou have its part numbr......also hwmuch did they cost.....what do you think about irradim ones...??/ Actually i dont hav the part num , just give a call to tech motors. Irradium ones will cost around 9000 at motorkade. If you are looking to save on fuel go with new set of stock plugs, new air filter may be a plug wire set and do a proper carb tuneup. Quote
kmcsb Posted April 5, 2012 Author Posted April 5, 2012 Actually i dont hav the part num , just give a call to tech motors. Irradium ones will cost around 9000 at motorkade. If you are looking to save on fuel go with new set of stock plugs, new air filter may be a plug wire set and do a proper carb tuneup. oops ..this is my friend no..anyway when will u come to nugegoda area???just PM ..OK Quote
kalinga Posted April 5, 2012 Posted April 5, 2012 http://www.ngk-sparkplugs.jp/search/adjust/car/sp_domestic/select.php?mkcode=HONDA D15B H3.9~H7.9 BKR6ERX-11P 94915 BKR6EIX-11 4272 BKR6EIX-11P 2574 BKR6E-11 2756 98079-5614E 4 D15B (VTEC) H3.9~H7.9 BKR6ERX-11P 94915 ZFR6FIX-11 3668 ZFR6FIX-11P 3064 ZFR6J-11 5585 98079-5614P 4 D15B (VTEC-E) H3.9~H7.9 BKR5ERX-11P 93228 ZFR5FIX-11 3145 ZFR5FIX-11P 4620 ZFR5F-11 2262 98079-5514G 4 Quote
