Iroshw
Everything posted by Iroshw
For misfiring there can be many reasons like bad sensors (Camshaft/ Crank/, Idle, bad fuel filter, bad fuel regulator, coil set, spark plugs, etc. I had the same issue, the problem is with the fuel system.
Should be the fuel filter or/and the fuel regulator. When did you change your fuel filter recently? I have the same issue with my Picanto (Manual). I used to clean the fuel pump by myself before I drive but it is a headache. The issue is finding a fuel regulator in SL. Before replacing the fuel filter try to clean it once and see.
Hi, I have a doubt whether the problem is with the entire fuel pump or with the fuel filter or the fuel pressure regulator. It is 2005 Picanto (Kia) with 160k millage. Not changed the fuel filter for nearly 4 years (80,000km). The fuel pump is located in the fuel tank which is under the rear seat. Recently occurred this problem, after driving 20-30km the car starts losing power, knocking and misfiring, hard to pick up. Due to the fuel quality, I cleaned the fuel pump by myself. Noticed a lot of dirt in the filter and the regulator looks new (but I have not changed it during the last 4 years). After cleaning the car drove smoothly and fast but only for 20-30km, and started losing power, knocking and misfiring. I had to clean the entire fuel pump many times. And I notice the dirt (black color) coming out from the filter all the time. Used Liqui Moly Fuel System cleaner too but didn't work. Note: Though the car gets slow acceleration after 20-30km with hard pickup, knocking and misfiring, idle is stable and no issues when starting the car. But when I put A/C on, the idle drop and leads to off the engine. Even with the stable idle not picking up in the 1st gear (this is manual) and hard. Spare parts are expensive like hell, so one of my friends said the issue should be the Fuel regulator, but it is not available in Sri Lanka (checked almost everywhere in SL). Another friend said the issue is with the fuel filter as it has not been replaced for years, it's clogged and blocking the fuel system. A fuel filter is available for 6500LKR. Another said to replace the entire fuel pump (cost is 35k). If anyone has a similar experience, please let me know what you did to fix this matter.
HI all, I had to replace the Fan belt n my Kia Picanto 2005 recently, the mechanic said the Crank Pulley Damper (Rubber Seal in the middle) which balance the vibration is damaged and about the crash. After replacing the Fan belt the pulley is running unstably by shaking. The Mechanic said the new belt will damage soon (which is true). I checked for a new or recondition Pulley but could not find. The Mechanic said there are places to rebuild the Balancing Rubber seal. Seek advice from the experts in this forum.
Hi all, Any place to buy Lucas Stop Leak in Sri Lanka? I have two issues and one is a little advance. * Oil on Spark plugs after gasket replacement * A small leak
HI, Please let me know a place to buy Lucas Oil Leak Stop in Sri Lanka?
Hi, I have a Kia Picanto 2005 using since 2017, had minor issues until last month. Recently had to replace head gasket but did not change the Pistons and Rings. After a couple of days noticed a vibration specially when the car is idle and the performance is poor (not accelerating) also the engine light is blinking. And noticed a few oil drops on the floor. The leak is near the Dipstick, never had an oil leak before. One of my friends removed the plugs and noticed oil on them. He cleaned using Carb cleaner and put the plugs back and started. The engine light was gone, vibration gone and performance back to normal. But the oil leak did not stop. After a couple of days the same issue, not accelerating, engine light blinking, oil on plugs and the leak is as usual. Took the vehicle to the same garage where I did the gasket replacement. Now they says need to do an engine overhaul to fix the issue. This car has done nearly 160k. When I told this to my friends some suggested to use an additive like LUCAS STOP LEAK, and another suggested to replace the Gasket Valve Cover and the O-Rings which cover the Plugs, another said the time has come to replace the car or the engine Guys, please advise.
One side tire binding, low power sometimes, radiator reservoir boiling
Iroshw replied to Iroshw's question in Mechanical problems
Hi all, the issue is with the Brake Master Cylinder. After the telling the whole story KIA guys inspected the brake system and said the problem is with the Master Pump (Cylinder). They were about to replace the Crankshaft Sensor as I told them the power is losing. The only issue is this part is little expensive at Kia and they charge a lot as labor charges. I went to Panchikawatte today to find the Brake Master Cylinder but failed. Tried Ar..na, Aja...tha, Kore--___ La____ but they don't have it this is a 2005 model. Any other places I can try? except Mar_chi as I have replaced a few parts from Mar__chi and all crashed in a few months including shocks. -
Hi, I have a Kia Picanto 2005 (Manual), 135000km done. This happened recently, One tire get stuck when driving for a few KMs and noticed the pins and the tire cup is hot tempered (with a burning smell). Also feel the power is losing (not all the time) and sometimes misfiring. And noticed that the radiator water reservoir was boiling when stopped the car (not all the time). Only once showed the heat went up. When this happens I park the car and switch off the engine for 10-15 mins). Then everything back to normal until I run for another few KMs. Changed the brake pads, CV Joint, cleaned the caliper including the piston and pins, replaced the caliper piston boots and caliper pin boots. Sometimes the tire is rotating smoothly but sometimes getting stuck. Recently replaced the brake booster (recondition one). Only once or twice noticed the brake pad is little hard to push. The garage guy said need to replace the Caliper as there are some scratches inside the Piston hole. And, noticed a small oil leak from the sump packing but I don't think that it is relevant to the above issue, planning to replace them next week. No oil in the radiator and head gasket is also good (no leaks) Any idea? the radiator and the cooling system is blocked? Injector issue? or the caliper?
Know this post is little old. Is there a place to buy Philips Extreme vision +130 H4 bulbs in Sri Lanka? I need a pair.
Not sure, they used something like Cream/Gel with the machine. Also sprayed something when using the machine. They did part by part.
hello guys, I had the same issue. Driving at night and rainy days was like killing, I was driving like a blind person with a huge risk sometimes. I was about to replace my windscreen. Suddenly found this place near Moratuwa. Took my car at night and he did a small part of the windscreen. Result was amazing. Next day I took my car and spend nearly 4-5 hours. All wiper scratches gone. But small chip marks are there which no one can remove. And they applied a Nano coating to protect the glass from Rain (like RainX). Trust me, he did a great job. The cost is 5k for the whole glass (it depend on the nature of scratches and size of the glass). If you want to contact him, please PM me to get his contact details. Cheers !
I had the same issue. Driving at night and rainy days was like a bad dream, I was driving like a blind person with a huge risk sometimes. I was about to replace my windscreen. Suddenly found this place near Moratuwa. Took my car at night and he did a small part of the windscreen. Result was amazing. Next day I took my car and spend nearly 4-5 hours. All wiper scratches gone. But small chip marks are there which no one can remove. And they applied a Nano coating to protect the glass from Rain (like RainX). Trust me, he did a great job. The cost is 5k for the whole glass (it depend on the nature of scratches and size of the glass). If you want to contact him, please PM me to get his contact details. Cheers ! Irosh
HI Guys, I had the same issue. Driving at night and rainy days was like killing, I was driving like a blind person with a huge risk sometimes. I was about to replace my windscreen. Suddenly found this place near Moratuwa. Took my car at night and he did a small part of the windscreen. Result was amazing. Next day I took my car and spend nearly 4-5 hours. All wiper scratches gone. But small chip marks are there which no one can remove. And they applied a Nano coating to protect the glass from Rain (like RainX). Trust me, he did a great job. The cost is 5k for the whole glass (it depend on the nature of scratches and size of the glass). If you want to contact him, please PM me to get his contact details. Cheers ! IroshW
HI All, I had the same issue. At night and rainy days, I was driving like a blind person with a huge risk sometimes. I was about to replace my windscreen. Suddenly found this place near Moratuwa. Took my car at night and he did a small part of the windscreen. Result was amazing. Next day I took my car and spend nearly 4-5 hours. All wiper scratches gone. But small chip marks are there which no one can remove. And they applied a Nano coating to protect the glass from Rain (like RainX). Trust me, he did a great job. The cost is 5k for the whole glass (it depend on the nature of scratches and size of the glass). If you want to contact him, please PM me as mentioning a contact details n public is not allowed here. Cheers ! Irosh
Guys, I had the same issue on my Kia Picanto 2005. At night and rainy days, I was driving like a blind person with a huge risk sometimes. I was about to replace my windscreen. Suddenly one of my friends recommended a place. Took my car at night and he did a small part of the windscreen. Result was amazing. Next day I took my car and spend nearly 4-5 hours. All wiper scratches gone. But small chip marks are there which no one can remove. And they applied a Nano coating to protect the glass from Rain (like RainX). Trust me, he did a great job. The cost is 5k for the whole glass (it depend on the nature of scratches and size of the glass). The location is close to Moratuwa (Katubedda). Cheers !
Update: Went to Samarasinghe Windscreen on last Friday. They had two new Windscreens and one recondition one. All with some scratches and damages. So they said there will be a new shipment soon. One of my friends recommended a place near Moratuwa. Went on my way home on Friday. The guy asked to come at night as scratches are severely visible at night. He cleaned a small part of the windscreen to show what he got. I was amazed, scratches gone. So made an appointment and took the car on Saturday early morning. Took nearly 4-5 hours to complete the whole windscreen and my headlights. They have applied a Nano coat to protect the glass from rain. They took my headache off. And you wont believe the cost, only 5k for the windscreen. If you want to contact him to take all your wiper scratches out from your windscreen, just PM me. I will share his contact details (as per the Autolanka rules can't disclose contact details in public). Cheers ! Irosh
Hi all, Please suggest/recommend a place to replace the windscreen of my Kia Picanto 2005 as there are plenty of Wiper scratches. I tried a lot to remove them using different methods but didn't work. It is very difficult to drive at night with this conditions. I called Samarasinghe Wnndscreen and they said the cost will be 15k for a new Japanese Windscreen with fixing charges. Also said that there will be 10years warranty for the windscreen. Is this reasonable? or there are more options? And, I would like to know the performance of these windscreens available at Samarasinghe Windscreen. Do they similar to original windscreens?? What about the visibility specially at night and on rainy days?
A garage in Colombo to repair my Kia Picanto (2005)?
Thanks a lot, hope the place is reasonable... Just got the prices for Spare parts from Aruna Motors and Ajantha Motors (Panchikawatte). Compared the prices with the list given by Kia Motors, 50% cheaper at Aruna Motors. -
Iroshw posted a question in Mechanical problems
Hi Guys, Please let me know a good and reasonable garage/person to do the following repairs n my Kia Picanto (2005). Prefer a place near Moratuwa, Colombo 05, Narahenpita. Replace the Timing belt Replace the Clutch Disc Assy/Clutch cable Replace the Tapet cover/Gasket Rocker cover/Seal Oil Also please suggest a place to buy the following Spare Parts for a good price. Valve Timing Belt Timing Belt Tensioner Assy - VLV Sprocket Crankshaft Blade - Crankshaft Disc Assy - Clutch (V/HD65) Cover Assy - Clutch Bearing - Clutch Release Cable Assy Clutch Seal Oil Gasket Rocker Cover Regards, Irosh -
Kia Picanto 2005 Vs Honda City 1998 Vs Chevrolet AVEO LS 2008
Iroshw replied to Iroshw's question in Car Buying Information
Between 1.45m - 1.8m I bought my Picanto for 1.5m, -
Kia Picanto 2005, stopped suddenly and didn't pick up in any gear
It happened again yesterday twice. In the morning stopped the car for traffic lights. When moving forward changed to 2nd gear and acceleratored, felt like engine is not picking up. changed to 1st, moved slowly, then changed to 2nd, and 3rd didn't move. Had to wait for a while and changed to 2nd gear and moved very slowly. On the 4th gear picked up like nothing happened. In the evening,on my way home, had to break suddenly as a Tuk Tuk guy turned to the main road like a killer. I saw the engine indicator popped up (engine was running) but did not pick up the car. Tried 1st gear, did not pick up, 2nd slowly moved, 3rd didn't pick up... When it starts moving slowly changed to 4th gear, picked up and changed to 3rd again didn't pick up. It worked on 2nd and 4th gear. Anyway, I'm taking the car to Kia Motors (Peliyagoda) on this Friday. -
Good, nearly 12-13kmpl (in Colombo with AC) -
Hi, When I was driving in the night (both headlights and A/C on) I had to break suddenly. The engine got stopped but didn't have any problem when starting again. I forgot to off my headlights and AC when starting the car. Then I noticed my car is not picking up, tried 1st, 2nd and 3rd gear but didn't pick up. I did drive nearly 1km slowly then everything back to normal. This happened two days back but now seems ok. I checked my Accelerator cable and noticed that the cable has become thin from the pedal side. Any guess? Problem with my cable? or gear box? Anyway I'm planning to replace my accelerator cable.
