Everything posted by kaju
Spare's For Mini's
Thanks miniace. I can wait till tomorrow evening. Thanks crosswind. Will checkout the classifieds. Thanks MasterDon
Spare's For Mini's
Figured posting on this thread would be better than opening another for spares. Hi miniace, Please could you tell me a place where I could get a mini boot lid and a rear bumper. Also I need a rear indicator lamp, a headlight and a fog lamp. A car came and knocked the mini really hard from the back and I hit the car in front as well. Thanks.
- Good Place To Buy Fire Extinguisher
- Turn Off A/c From A/c Button Or Blower
- Post Whoring - Part 2
Camera/electronics Repair Join In Colombo?
Similar experience here as well with Photo Technica. A friend took a broken 18-105mm kit lens for a D90. Only a piece of plastic was broken on lens mount. Said couldn't fix and it will be too expensive. Found the same parts online for less than 1000Rs on Amazon and gave it to them. Made a fuss and repaired it but it wasn't a good job.
Autolanka Funniest Moments
I took this in 2010 December near nugegoda junc. The right hand tyre of the "off-road" vehicle deflated by kohuwala junc.
New Corvette Callaway In Town
Here's pic of the wheel which I couldn't upload yesterday.
Mini Haynes Manual And Workshop Manual
This being an old thread and all that. Both the above links are dead. New link for the below mentioned Haynes Manual . The link is working as of 2012/05/20 Mini (69-01) (Haynes Service and Repair Manuals) http://carpdf.net/download?id=670 There are a lot of other manuals available on this site as well.
- New Corvette Callaway In Town
More pix, I snapped these today when I saw it near SSC.- Oil Pressure And More
@Sylvi: Thanks. Thanks will try that with some help. Scooter thanks for the previous post and this, will try and get a look at the oil leak like you have mentioned. I tried cleaning in the area which I can see but couldn't figure anything out. The spark plugs being used are Denso K16R-U11 put in recently. The idle speed is somewhere around 800-900 from what I can see. Is that too high? I saw Sylvi also mentioning that it was too high. Is there any space in the engine bay to put in an oil cooler as well?- Oil Pressure And More
Hi Guys, The idle speed somewhere around 800-900 from what I can see. I showed it to a mechanic on Friday evening and changed the oil pressure switch. Drove back home in somewhat heavy traffic and saw the light come on again once. But that was when I was going to seize the engine. Couldn't run the car yesterday but will run the car next few days and see. Fingers X'd. On a separate note, Is it normal on a mini to have the engine still idling even after it's switched of from the ignition? (I don't have a turbo ) Almost all the time the engine stops 1 to 2 seconds after I've switched off from the ignition. Sometimes even longer.- Oil Pressure And More
@Thanushka: Thanks for the feedback. I hope it's not something similar :S @Sylvi: When you say oil plug do you mean the sump drain bolt? If so it's not leaking from there. @Ripper: Thanks. @miniace: Thanks a lot. So do you mean I should get the oil changed again to low viscosity (30 instead of 50) again with a new filter or run with the current setup and switch at the next change? I'm just worried that this might be something like Thanushka said which will be a sorry situation. I've attached few more pics which might be a better angle.- Post Whoring - Part 2
@Ripper: Thanks will try that. Particular reason for using diesel? Asking all these questions because these things are new to me. @miniace: I'm in Pepiliyana. I went to Lucky to get the break issue fixed but seemed somewhat reluctant to look at the oil issue. Don't mean to dis him but that's what I felt. @Sylvi: Oil level is at Max so far when checking the dipstick and yes there is oil on the garage floor.- Oil Pressure And More
@jdnet, Thanks but I checked the drain bolt but it's not that. @miniace, The oil seems to be coming down from somewhere and dripping off the the black tubing (first pic). Any idea from what little you can see? On the other hand the break issue seems to be fixed after I got the washers changed on the break booster. - New Corvette Callaway In Town
