harshansenadhir
  1. Might have overfilled. Keep an eye on the level and make sure alternator is not over charging the battery
  2. Yay. my objective of this cropping was to deceive people to think that its' a Merc.
  3. There you go! Over to you.
  4. Some don't convert these vans to disks as they make use of the distinct advantage of front drum brakes (hence less requires the brake booster and therefore can run on even downhill with engine switched off !!!! ). This is the reason why L300 and even T120 (kichi kichi delica) were popular in upcountry.
  5. guess it's an easy one. Hence expecting the exact name of the model.
  6. visiting forums after ages and yeah it's DCM, they used DYNA U60 as the base/platform to build these busses and trucks.
  7. Toyota Dyna Bus
  8. Move to another category honestly. I've seen quite a number of build quality related issues in these and not to mention interior trims falling apart/wears out prematurely. If you really want a SUV in that price range, even a 30 year old Pajero would hold tight for longer than these.
  9. very subjective question here. Parts you would need for this conversion will be hydraulic power assisted steering gearbox (known as box) power steering pump fluid reservoir and fluid pipes (steel as well as rubber hydraulic type hoses) first of all you need to figure out whether a matching steering box is available for this model or if those are not available (most likely as this model didn't come with PAS) maybe you will have to do minor modifications and fix a power steering box of a PO5. Secondly you need to see what are the provisions available in the engine block to mount a power steering pump. If provisions are not there you might have to fabricate a bracket or buy a suitable bracket from a vehicle with power steering and with the same engine. I believe this is the Orion engine therefore you should be able to find a pump and bracket of some lancer model. if you managed to find a pump and a bracket, you'll need to see how to drive the pump. whether from an existing belt (using the same groove of the main pulley, in this case you'll have to change the belt) or adding another belt if your mail pulley has an additional blank groove. and finally the reservoir bottle plus necessary tubing. as you may understand the cost varies depending on what you'll have to source. In my gut feeling we're talking about a job not less than 35~45k easily.
  10. I doubt that's a standard fitting. No vehicle manufacturer would send a manual button to switch on radiator fans rather they install something call temperature sensor and that would trigger the fans at the correct working temperature of the engine. As for changing of radiator, it's subjective depends on the quality of the existing one and for some models prone to heat more, they install bigger, 3 core radiator and that will help if the vehicle tends to heat more. Removing of spare wheel isn't advisable as it might have been factored for frontal safety. Check how much of a block of the airflow to radiator it causes and decide based on that.
  11. I would still go with shock mount (front RH) worth a removal inspection I believe
  12. Good to see you after long time. Happy anniversary and wishing many more happy years together.
  13. did they not hear the sound during a test drive or heard the sound and could not diagnose what it is?
  14. What's the engine ? is it 4D56 TDI common rail? There are few engine designs of Mitsubishi ( Have experience with 4D56 and 4G15) the dipstick does not have an extended tubing and if you pull it out while running little bit of oil droplets will come out. This isn't a big issue to worry as long as it's with a lower dipstick opening by its design.
  15. I would narrow down to front right hand suspension. though you said the previous garage checked the suspension, still worth to try a second opinion on following 1. Front righthand shock mount 2. Front righthand sway-bar link
  16. I would recommend checking the fuel pump. However, this should record an error related to low fuel pressure if you scan with an OBD. What's the scanner you used
  17. Apart from Malabe means you have tried Throve already?
  18. Good choice compared to overpriced tin cans. But stay away from the AT as AL4 gearbox is inherited with a factory defect in valve body. Upgrading electro valves along with a firmware upgrade on the gearbox ECU can prevent this but too late for most of the cars running around. So best is stay away from AT. If you can source a good executive or 2.0 car with YOM 2002 or above (known as COM 2000 model) you would enjoy your ride. Make sure to get it checked properly by a professional and service records. Generally these cars are rust proof unless gone through metal fabrication as a result of an accident. Good luck with your search.
  19. No this is not normal. Since the condenser is fixed underneath the engine, emitting heat from the condenser does not contribute towards this. looks like the additional payload from the A/C contributes to excessive heating of the engine. can you answer following questions 1. With A/C switched off, how long does it take for temperature gauge to climb up to 50% mark. is it within 5 minutes or half an hour? 2. You said the gauge goes beyond 50% with A/C on. Is it when the vehicle stuck in traffic or when keep moving? 3. What's the mileage of the vehicle and when the engine was last re-built ? 4. Did it have this losing of coolant (and of course heating issue) from the expansion tank (Bottle as we call it) even prior to upgrading of A/C i tend to suspect a blocked thermostat but will wait for your responses. P.S- Also check the direction of the air flow of the condenser fans whether it blows air out or sucks air in.
  20. This certainly related to electrics and ECU is playing up. Primary suspect is a loose connector of the ECU. Try to get those pins tension properly and see before you get into complex solutions. What was the tool they used to diagnose the problem?
  21. didn't know that. However, still the same market perception is there for 61- vehicles. For some odd reason SUVs registered as dual purpose vehicles (50 series) has a less market value as well. Strange but anyone who doesn't give two hoots about it can enjoy a good ride for somewhat lesser.
  22. Yes. 4M40 has some bad reputation in the reliability quadrant. However, it has more power and higher end torque than 4D56T. I'm driving a MK1 series2 (known as turbo wagon) with 4D56T and quite satisfied for last 3 years. parts are freely available and prices are music to ear (being maintaining Peugeots for decades). There's a famous sticker on some SUVs " you can go faster but I can go anywhere". However, in my experience, it can go faster steadily. Went into Yaala trails and the journey up to the entry point in Monaragala, none of the other vehicles in the squad (including a montero sport and a ASX) could keep up with the Pajero (could be the driver :D) in terms of market value, I have seen some turbo wagons selling for higher prices than 61- "computer bodied" jeeps. Typical Sri Lankan market, hard to explain certain logics. I recon, going for a 64- or 65- one as oppose to 61- which has lower resell value plus some cops can mess with you as it's registered as light motor coach.
  23. 5008 looks so appealing and the features. Still hard to believe they have improved their service levels. They usually support the latest models but when your model get pushed back by a few years, all the issues arise.
  24. not an expert on Defenders or landys for that matter. But having heard this complain of clutch is being excessively heavy for usual city traffic. Could be a concern if you're planning to use it as your daily. Also avoid odd number series such as 40 sri / 28 sri / 31 sri etc. They hold a less market value and hard to resell.
  25. Could it be a screw up of AM* and they gave you a pre-warning and made up your mind so that you won't complain against them ?
