Switching To Neutral While Driveing An Autogear!
lol, that purpose will not be met for sure. Coz when you're cruising at moderate or high speeds, taking the foot away from throttle will reduce the engine RPM to idle, it's as good as going in N.
## Ward Place, Colombo - ## Scam
Yeah, it was explained by S_N as to why silvy got bashed for wrong English, grammar, punctuation and what not. Simply, if you dare find faults/ highlight faults of others, be clean and expect the same or worse in return. Done with OT I was asking the same question over and over and suggested to lodge a complaint even before posting it here, smelling something. There are two sides of every story, either this post can be an attempt of negative marketing, or a true incident which we don't know yet. So cannot accuse either party here. If topic starter can prove his point, yes members or forum readers will get alerted, else it will certainly be positive or marketing, brand name spreading for that venture.
Not really, autoboxes doesn't hold lock onto final drive and engine. Torque converter transfers power from engine to gearbox and not wise versa. That's why even in 2 or 1/L there's no 'gear braking' available on autoboxes. this will save some juice and will extend life of torque converter, engine/gearbox mounts at the expense of two operations in valve body from D to N and wise versa. Therefore that operation and slight wear/tear can be compensated, same cannot be applied if someone does it while driving.
+1 here, every change in the gear selector operates the valve body inside the gearbox, if you say wear and tare will be high by doing it frequently, yes it does.
sad to hear your bitter experience and good that you thought to educate others, but why straight away to this forum? surprised to learn that you haven't lodged a complaint or an entry to nearest police station. I think even before posting your experience in this forum that's what you should've done at the first place.
Catalytic Converter
if the cat is blocked, yes it could affect performance and hence fuel economy. Since it's a '96 car, chances are high that the cat is blocked. If you take it a generic mechanic he'll break the cat and take all ceramic parts out and that's about it. But with emission regulations are around and in the process of making them strict, I don't recommend it. Try to find out a second hand cat from japanese junk yards in Delkanda. Failing which you might have to go with what I said earlier. Break the CAT. All that is if the CAT is blocked, creates excessive pressure in the exhaust manifold. Therefore more important to isolate the issue, whether it's due to blocked CAT or failed lambda sensor. You might require to hook it up with a code reader, may be you should try agents in that sense, at least to diagnose the error exactly. If it's lambda sensor you can replace the sensor and be happy but this is more like excessive pressure on manifold due to blocked CAT but I'm not 100% certain.
Catalytic Converter
what's the make model of your vehicle? Does it has an EGR. It could be something like over heated exhaust manifold.
Import Tax Slashed By 50%
not healthy news for SL foreign reserves nor monthly fuel bill of the entire country.
Need Help - Lancer
tend to disagree with you here mate, you don't need a good mechanic to replace a faulty carb with a brand new one. Agree with the path Ck2 had chosen, trying to sort that out with 1400/= and two three days of wandering around and some labour vs 97,000/= even if that low cost attempt fails still worth trying to save 97,000 if not 18,000.
Need Help - Lancer
brand new? or used ones ?
oh talk about it, now its about time all those long waited imports to reach shores and sales. In fact sales are now filled with axios, vitz, belta's and what not. Still the prices remains more or less same. Reason is? Loan rates are down and it'll further reduce to single digit they say. So people continue to buy without bothering to wait till market crash one day. You got to see number of inquiries coming to banking and financial institutes for new facilities, they're overloaded. So this one fine day has not yet occurred even after 2 months. Lets wait more and more and see since no body can't stop a person from dreaming.
Need Help - Lancer
thats the packing kit isn't it? The complete repair kit should carry all. However if you can't find the original repair kit or original jets, needles better replace the carb. However give another try to take it to a carb specialist. Search this forum to find out directions/whereabouts of carburator banda's garage.
Need Help - Lancer
you should be able to buy the entire repair kit including needles and jets either from agents or from panchikawatta, your mechanic might know a place exactly. Not sure on second hand prices, that too again can be found from 'watta' near the canal between panchikawatta and 'bmc watta'. However try to repair if possible coz you never know the condition of the used carb until you fix and run
Cvt, Automatic Or Manual Transmission?
yeah, I made it very clear in one of posts that it depends on the personal flavour/taste/preference.. just that another avenue of experience/driving pleasure is open for you when driving a manual.
Could be mate, what I'm trying to illustrate is the main difference when you're negotiating a down hill on an auto on 2 or 1/L and the same on 2nd gear of a manual box. Where in Auto engine brake concept doesn't apply at all, as you said it's only limiting the speed.
means you can negotiate a down hill on 2 or 1/L of automatic even without using brakes like you do in a manual ?
China's Geely Completes Volvo Buy
i don't think old management or strategy will continue as that strategy itself made volvo to be sold to chinese. If chinese too continue with the same, they might have to pump money to volvo which is not the motive of chinese. Profits, more of them, volumes, more and more volumes. What i predicted was that thinking, intention doesn't go in line with quality.
don't waste your time bro. Old school thinking is metal cages that don't even bend slightly in most horrible crash are safe, which was proven wrong long time back and now the safety policy of any car manufacturer would be to return the man not the vehicle. And this is not known to some people still believes in safety is dealt with thick metal plates.
Nano Fuel
well said and I have enough and more stories heard from first hand experienced sources to say mentioned so called expert is nothing but a crook. Let's not get there and let die this useless thread.
only if you manage to save your a$$ from a 60kmph crash
good thinking and me wish the same would happen. But on contrary, Chinese are very very profit concern and volume concern. Safety and Quality doesn't go in line with that thinking. Whatever said and done on all expertise, R&D, plants what runs the show is that mindset and thinking behind the curtain.
Looking For A Car
great deal and congrats.. it's a great machine and the best thing is it's built on the Jaguar plat form. I can very well remember this incident about few years back where a mondeo came right behind inches length to my boot. Had to step on the brakes suddenly and so hard due to some stupid ignorant pedestrian and the next thing ran across my mind was I'll get a bang from behind. I was wrong, I only heard a small creek and mondeo made to a firm yet quick and steady standstill in a fraction of a second and driver didn't mind that at all as it was nothing unusual.
it used to be old folks vehicle... and now gonna be common man's vehicle yeah, more of affordability at the compromise of safety. I aint joking and that's the future trend in auto mobile industry from what I see. Indian, Chinese acquisitions and the models they're coming up with.
Heat Coil (orange)light Blinking
true, if someone removed the thermostat, engine might be running under optimum temperature and that can be another cause.
exactly, I'm sure there will be a helluva lot impact on the brand name.
