Charith H Jayasinghe
Everything posted by Charith H Jayasinghe
  1. May be jack means Booruwa (J) from playing cards
  2. ROFL What is that "Thor" racing?
  3. Great thread indeed. @ VVTi Thanks for open it. Learned a lot. I'll definitely arrange that thing for you in Passikudah soon @Rumesh fan finally came on at half mark. Today I bought Wurth coolent and distilled water for a coolent change. Hope everything will be OK though I'm having a water phobia these days.
  4. After reading through this article what I feel is, even though how big the radiator is engine Temperature should stay normal instead of cold if the thermostat working isn't it Magnum?
  5. How it relates here? Please explain a bit If that is so, he will get issues with acceleration won't he? @kam.uoc what is the engine miss you experience when driving in traffic? Did you listen silencer beat after stop? Why did you change Fuel Pump last time? Did you check/clean Injectors with that tune up?
  6. OK I came back home again. On the way to home it disappeared after driving about 50km. This time did a Injector clean up with ultrasound (??). Cleaned the IAC Valve (there was a carbon built up) (can that be a time to time carbon dislodged and block it? ). Car was running smoothly but it is too early to tell. Agent's diagnostic run for ECU I've planned on next week. Thank you Don for suggestions and Thank you Rumesh for helping me since the problem began.
  7. Wishing you many happy returns of the day mate.
  8. Can there be an unequal cylinder wear due to this? This thing came to me after I decided to check my mechanic whether he is a Makabass. He said he doesn't recommend the removal and he has seen conical type piston wearing in vehicles which has removed thermostat because, considerable heat gradient exist from top to bottom for a long time in absence of a thermostat. Is it that bad?
  9. I did this to give a re learn yesterday http://www.nissanclub.com/forums/f-q-2002-2006/121664-idle-air-volume-learning-procedure.html 1) Drive the car to "warm up" temperature. Make sure your idle is close to 700 rpm. 2) Ensure any battery draining devices are off. Ie. headlights, interior dome lights, HVAC, stereo. 3) Turn the car ignition key to "OFF" 4) Wait ten seconds 5) Turn the key to "ON" (not start) 6) Wait three seconds. 7) Perform the following five times in five seconds or less. Fully press the gas pedal and release. 8) Wait seven seconds from last of the five releases. 9) Fully press the gas pedal and hold down. Within ten seconds the "Service Engine Soon" light should begin to blink. 10) Wait another ten seconds (while still holding the gas pedal) and the "Service Engine Soon" light should stop blinking. 11) As soon as it stops blinking, release the pedal, start the car and check the idle (should still be around 700 rpm) 12) Let the car idle at 700 rpm or so for about 25 seconds, rev the engine a few times and then let it return to idle. 13) Shut the car down. Seems it didn't solve the issue
  10. Thanks Don. Do I need to remove power from car security system to set the load sensor OFF when doing idle air volume learn? Thing also settled with removal of battery terminal to reset the computer (is it?), and re-cur after some times later. My gut feeling says( and I'm praying) ECU may be ok. As you suggested its time to take it to agents.
  11. About one month back I was fool enough to do high pressure wash in my car engine bay. Soon after that I felt rough idling and sense of engine was going to stall. Then my mechanic and I removed most of the sensors and connectors including MAF, ECU, Throttle body, coil packs, applied air and contact cleaner (Wurth). Problem was solved at that time but end up with a high RPM of 900-1000. (It was used to be at 700). Then did idle air volume learn from a place but it wasn’t operated by usual technician but it came down. But after driving for about 50 km ( after 2 days ) some kind of a jerky feeling started to feel while idle with specially AC on or while gear in D or R without AC. It also occur when cruising around 60kmph when OD engaged, torque converter locked and cruising RPM comes near 1400-1500 area. It doesn’t occur in RPM like 2000. Battery voltage didn’t dropped when this happened. After driving about 250km (I came back to work) I did a clean and removed MAF connector while engine was running (I just wanted to check MAF) and removed battery terminals for a while (2days) and allowed ECU to reset. Surprisingly it improved for few km and started again. After coming back (another 250km) did a sensor clean again and did a re-learn from a different scanner (x431) things got solved significantly and frequency of occurring went down and happened only at idle with lesser frequency. Later, in the scan report I saw load indicator was on while doing that even though everything was turn off (may be cabin light was on or car stereo panel lights stays on though it is turned off). I went over internet for read regarding this and saw “ Accelerator paddle release position learn and Throttle close position learn” should be performed prior to idle air volume learn. I changed MAF and O2 sensor later. Even though fuel figures came close to factory figures (16.2/16.6 kmpl) those symptoms didn’t improve. My next plan is to check fuel pump and AC (clutch or something) So, 1 What may be issue? 2 Is idle air volume learn is highly sensitive thing that need to follow exact procedure? 3 Is this condition relate to above thing or any other isolated condition? http://forum.autolanka.com/topic/15462-fb-15-idle-drop-issue/ this thread somewhat similar but not exactly similar
  12. They are not bad as you think. ( I'm referring to a kit with projectors.) it doesn't make any difficulties even with 8000K ( I do lot of night driving ) and its high beam is superb. You can have a ride on my car to check that out. Let's wait for comments from guys who are using HID.
  13. Oh nooo. I just recovered from a same GOOD WASH but it cost me MAF sensor and O2 sensor ( @ Rumesh88- that cleaning didn't go quiet well even after repeated Air Volume Learn and didn't run smooth so I decided to replace both from Agents)
  14. Thanks for the info.... Recently I did a scan ( I did it for something else) and got two report with 4 min apart. In first one coolant temp was 74'c and second 81'c. Is this alarming something? usually my temp gauge come to middle and stay there without change
  15. Great write up Davy..... I haven't gone this far in interior cleaning... wanna try this in coming vacation.
  16. Saw this while browsing youtube. unbelievable nerve and muscle speed, co-ordination and response. What will happen if he become a race driver?
  17. Yeh... it seems like that. good observation.
  18. Is this somewhere near Diyathalawa?
  19. Windscreen was cracked after parked under a tree. Though I get payment for windscreen I have to spend for Windscreen Tint the same amount of money as a windscreen as I haven't shown any of my modifications to Insurance company.
  20. "When you park, the best practice I'd say is to first select 'N", and then apply parking brake, release the foot brake for a second so that the wheels get locked with the parking brake, and then press the foot brake again and shift to 'P' This way, the weight of the vehicle is off the gear box when you park. Have you seen, if you just shift to P and then leave the car (with or without parking brake) the car rocks forward and backwards a few cm before settling down. This is not good for the gearbox in the long run if I'm not mistaken. " Good one I should adopt this. I used to do it, apply parking brake while keeping foot on the brake paddle and then put gear in to "P".
