Everything posted by wolseley
- Vehicle registration in srilanka
- Reverse gear not engaged with cold start
Need help to find Silvo to remove scratches from my Windscreen
I got 3M glass polishing compound (part no:60150) from 3M Lanka about 2 years back. Don't know whether it is available now. So check with them.
Toyota SUVs
There were not much RAV4 s imported during last few years because of high import duties along with luxury taxes. When I was searching two months back , found two of them up for sale. They were 2WD, zero milage, imported under permit from AU. Asking price was 10.1 mil each. However I have settled for a 2009 one for 5.5 mil Hope this helps.
Buying New Shocks From Which One
Go for Namaratne .Generally they give 20% for cash. Since Taa are the agent, they wont give such discounts as Nama does. But the stuff is same.
Borgward Born Again !
There were few Hansas around those days
- Where to buy a Torque Wrench and a Dial Gauge Indicator
FB 15 Splend 2000
Not frequently, but there are some... for example my wife's car Its 2008 B/N one.. still 58,000 on the clock ......
- Dihatsu charade1980 or mazda ford leser 1985
Corolla CE110 is it worth buying?
@PreseaLover Since I wanted to keep the car for some time I got the engine repaired as soon as the the early signs appeared. Otherwise you have to suffer starting problems, overheating, messy engine etc., So It was easy to rebuild even using the existing pistons unlike the totally abused engine.
I have used a CE110 manual one from 56000km to 285000km in 16 years. It is a very reliable and easy to maintain. Engine overhauled at 175000km and up to the time of sale doing fine. Almost all parts are available at very reasonable price. However I had to replace headlamps twice due to discoloration and steering wheel four times due to deterioration.
- Honda Accord 2013 as a first Car
- Toyota Corolla 'S Limited'
Rat Trap Cage (Without Killing)
I have tried many but TOMATO is the best
Tax Change On Vehicles
Totally agreed....
A Problem In Heater Hose Connector
If you want to keep it as original it is ok. But unless it has climate control AC there is no harm bypassing the heater core. Heater core itself will make trouble due to ageing.
- Good Electrician To Fix Dashboard Lights
Mini Copper Classic Mechanic
Luxman @ Model Farm Road
Quick Trivia 3
I thought you all are fed up with this trivia... anyway it's a mitsu
Irregular Brakes
No vibration at all felt without applying brakes.
Irregular Brakes
Problem solved.!! It was due to a warped hub. Bit scarce to find but fortunately found a good piece at watte. Pair of rotors were also replaced because the existing pair has been machined to the limit. Now the brakes are fine. Thanks for your help. specially you Davy .......
Peugeot 206/207 Vs Toyota Starlet/carat
I have owned starlet EP82 ,EP91 and currently EP71. In my experience starlets are very reliable small machines and are very easy to maintain. Go for starlet.
Abs Error
There is a toothed ring attached to the CV joint towards what the ABS sensor is pointed at. If that come loose the ABS sensor might not pick up the signal properly. Check it first. Davy has nicely elaborateded the thing..........cheeers
Irregular Brakes
@Davy/Terra Yeah it is somewhat pulsating but no pulling to a side or no sinking of pedal. my concern is after refacing the discs/drums why it is happening again wheel rims and tyres are all new
Irregular Brakes
Hello friends I have a problem with my starlet. Need your expert advice. I have restored an EP 71 recently. Brakes were overhauled. Discs and drums were refaced. There were only slight error to be corrected. Then brakes were fine. But after driving around 5000km it started to feel some irregularity on the pedal . Discs were checked and found some errors again. Refaced again and fitted with new disc pads. But after another 5000km the symptoms appeared again. I am clueless what is going on. Please shed some light on this. By the way the car runs very smooth, alignment is OK, No wobbling or anything.
